Window leak
homerjack
City/Region: Homer
C-Dory Year: 1988
Vessel Name: 49er
Photos: 49er
PostPosted: Fri Aug 23, 2019 10:59 pm    Post subject: Window leak Reply with quote
Leaking port slider. What likely needs to be done to fix?
I ran hose over roof simulating rain. The water sheets directly into window channel despite roof overhang.
PostPosted: Sat Aug 24, 2019 12:02 am    Post subject: Reply with quote
Clean the track drains. They are the little bumps or tabs sticking out of the lower part of the window frame.
homerjack
City/Region: Homer
C-Dory Year: 1988
Vessel Name: 49er
Photos: 49er
PostPosted: Sat Aug 24, 2019 12:11 am    Post subject: Reply with quote
Oh I've done that vigorously recently. Not that.
wolfman
City/Region: San Diego
C-Dory Year: 1994
Vessel Name: Hunky Dory
Photos: Rowdy Runabout
PostPosted: Tue Mar 30, 2021 1:42 pm    Post subject: Window leaks Reply with quote
The most likely reason is the rubber window gaskets. My windows have 2or 3 inch gaps where the rubber shrunk I need to fix that as well.
There are other threads about that with sources for the gaskets. Steele rubber products, diamond sea glaze
22" Cruiser
T.R. Bauer
City/Region: Wasilla
Vessel Name: C-Whisperer
PostPosted: Thu Apr 01, 2021 12:00 pm    Post subject: Reply with quote
Mine was leaking from the seal tape behind the starboard window. I'm pretty sure they just did a marginal job on install, but I don't know for sure. I cleaned everything up, put in new tape, and now it leaks on the other side, which isn't mine, so I don't care.
Page generation time: 0.0423s (PHP: 39% - SQL: 61%) - SQL queries: 18 - GZIP disabled - Debug on
