homerjack
C-Dory Year: 1988
Vessel Name: 49er
Photos: 49er
Posted: Fri Aug 23, 2019 10:59 pm Post subject: Window leak |
Leaking port slider. What likely needs to be done to fix?
I ran hose over roof simulating rain. The water sheets directly into window channel despite roof overhang. |
Joined: 27 Oct 2012 Posts: 3563 City/Region: SW Michigan
Posted: Sat Aug 24, 2019 12:02 am Post subject: |
Clean the track drains. They are the little bumps or tabs sticking out of the lower part of the window frame. |
homerjack
C-Dory Year: 1988
Vessel Name: 49er
Photos: 49er
Posted: Sat Aug 24, 2019 12:11 am Post subject: |
Oh I've done that vigorously recently. Not that. |
wolfman
C-Dory Year: 1994
Vessel Name: Hunky Dory
Photos: Rowdy Runabout
Posted: Tue Mar 30, 2021 1:42 pm Post subject: Window leaks |
The most likely reason is the rubber window gaskets. My windows have 2or 3 inch gaps where the rubber shrunk I need to fix that as well.
There are other threads about that with sources for the gaskets. Steele rubber products, diamond sea glaze _________________ 22" Cruiser |
T.R. Bauer
Vessel Name: C-Whisperer
Posted: Thu Apr 01, 2021 12:00 pm Post subject: |
Mine was leaking from the seal tape behind the starboard window. I'm pretty sure they just did a marginal job on install, but I don't know for sure. I cleaned everything up, put in new tape, and now it leaks on the other side, which isn't mine, so I don't care. |
