Patching small thru drill holes
homerjack
City/Region: Homer
C-Dory Year: 1988
Vessel Name: 49er
Photos: 49er
PostPosted: Sun Apr 30, 2017 10:05 pm    Post subject: Patching small thru drill holes Reply with quote
I need to plug a few small drill holes above water line (cockpit). Was going to use marine-tex. Should I glass the backside of holes?
PostPosted: Sun Apr 30, 2017 10:15 pm    Post subject: Reply with quote
I guess it would depend on the size and location. I have used West 610 epoxy on drill holes in the inside part of the gunwales (by the storage bins). On a hole I made in the roof, I used regular epoxy and a nylon hole cap.
On vertical surfaces I put painter's tape on both sides to contain the epoxy while it sets. On horizontal surfaces, just on the bottom side.
PostPosted: Mon May 01, 2017 12:39 am    Post subject: Reply with quote
For small holes MarineTex should work--but I have had some yellow with time. A small amount you can probably gel coat over, after sanding.
homerjack
City/Region: Homer
C-Dory Year: 1988
Vessel Name: 49er
Photos: 49er
PostPosted: Mon May 01, 2017 2:17 am    Post subject: Reply with quote
That's the plan Bob. Thanks.
Page generation time: 0.0271s (PHP: 59% - SQL: 41%) - SQL queries: 17 - GZIP disabled - Debug on
