nmitch2859
Joined: 28 Apr 2013 Posts: 71 City/Region: virginiabeach
Vessel Name: Delfin
Photos: Delfin
Posted: Sun Sep 18, 2016 1:14 pm Post subject: Water under water tank. |
I have a C-D 25 Cruiser. I do keep it in the water at Tidewater Yacht Marina. With rains and the bilge pump forward of the water tank. There is a lot of water that sits there and causes mold. Has anyone had the same problem. I was thinking about a using a primer bulb and hose to remove the water. Putting the boat on a trailer is not feasible. Thanks _________________ Neal J |
tsturm
Joined: 01 Nov 2003 Posts: 1134 City/Region: Soldotna
Vessel Name: JMR TOO
Photos: JMR-TOO
Posted: Tue Sep 20, 2016 6:17 pm Post subject: Re: Water under water tank. |
nmitch2859 wrote: | I have a C-D 25 Cruiser. I do keep it in the water at Tidewater Yacht Marina. With rains and the bilge pump forward of the water tank. There is a lot of water that sits there and causes mold. Has anyone had the same problem. I was thinking about a using a primer bulb and hose to remove the water. Putting the boat on a trailer is not feasible. Thanks |
I mix a little bleach in with the water that remains in the bilge area & algae, mold etc. all gone |
Joined: 03 Mar 2005 Posts: 3595 City/Region: Valley Centre
Posted: Tue Sep 20, 2016 6:52 pm Post subject: |
tsturm posted a good idea for keeping your bilge and gas tank area clean.
For more on what happens around the gas tank, read these two posts:
C-Dory 25 Cockpit Recaulk
C-25 Gas Tank Leak
This is the year I'm going to fix those cockpit hatches so they don't leak. That's where most of the water comes in. Several good ideas in the past posts, but I can't find them.
Boris |
