OK, I Am Incredibly Stupid Mechanically, But HELP PLEASE!!
PostPosted: Thu Sep 01, 2005 9:29 pm    Post subject: OK, I Am Incredibly Stupid Mechanically, But HELP PLEASE!! Reply with quote
All I want to do is grease the dang bearings on my trailer. But first, DO NOT LAUGH, NO SMART ANSWERS, I cannot get the grease cartridge into my grease gun so it pumps out, and I don't understand why...I pulled the plunger out and moved it to the locked position. I unscrewed the front part with the nozzle and the lever. I put the cartridge in, screwed the nozzle and lever back on, released the plunger...and - it is now supposed to pump grease, isn't it???? No she go...the lever pumps but no grease comes out. What am I doing wrong here?
doc
City/Region: Auke Bay
C-Dory Year: 2017
Vessel Name: Bella Rey
Photos: C-Alaska
PostPosted: Thu Sep 01, 2005 9:34 pm    Post subject: Reply with quote
Hey, these can sometimes be a pain. Is there a bleeder on the front of the grease gun? Might be air locked. Give that a try and stick the fitting on a zerk and give her a try.
C-Hawk
Vessel Name: C-Hawk
Photos: C-Hawk
Pat-
Do you have the notches on the plunger turn down so they will catch the trigger when you pump the trigger?
oh wait-- GREASE gun- oh well don't listen to me, I'm a bldg inspector, not a mechanic Rolling Eyes
2008- CD22- "C-Hawk" Sold
KJ6VVB
A Brat I am, At sea I be
Big dave
City/Region: Vancouver
Vessel Name: Raven Dancer
Photos: Raven Dancer
PostPosted: Thu Sep 01, 2005 9:51 pm    Post subject: Reply with quote
Embarrased Did you remover the foil off the end of the grease tube ?
Big Dave.
PostPosted: Thu Sep 01, 2005 9:53 pm    Post subject: Reply with quote
OK, worse yet...I fiddled and faddled and the grease finally started pumping, but I am clueless about what I did that made it finally work. Crap.
PostPosted: Thu Sep 01, 2005 9:56 pm    Post subject: Reply with quote
Pat -
If you removed the pull tab cover on the lower end of the cartridge and the cap on the other end, and got the plunger pusher plate inside the cartridge, then you have an air lock preventing the grease from getting into the pump that the handle operates. Oh crap - you're gonna make a mess. With plenty of disposable towels handy, unscrew the handle end of the grease gun again, this time with the plunger under spring pressure. When she comes loose, the first burst will be mostly air, and then comes the grease. Don't pull the end cap away from the gun barrel, just burp the little bugger and try to thread it back on there. Good luck. Maybe have Austin do it. If you can find a bleeder like Doc suggests, try that first, because it usually will work. If you got a cheaper grease gun, you got to go the messy route. Just don't let the end come too far away from the barrel, or you get all the grease on your foot. Please have Patty take pictures.
If it's any consolation to you, the more time I spend around them lawyers, courts and judges, the less I understand the logic.
Buck
City/Region: Lakebay
Vessel Name: greeniron
Photos: Greeniron
PostPosted: Thu Sep 01, 2005 10:06 pm    Post subject: Grease guns! Reply with quote
Air lock. tap the hose end of the grease gun on a block, kind of like how you tap a ball point pen to get it to work. Tap it on the edge, some times it helps to unscrew the hose end almost all the way off to purge air.
PostPosted: Thu Sep 01, 2005 10:16 pm    Post subject: Reply with quote
Yes, well, ahem...I don't know if I am typical, probably not, but ever since third grade or so right up to the LSAT they have made me take aptitude tests...and I score in the 99th percentile on most categories - verbal, logic, writing, even math, not bragging, just a fact - but in one category, I swear to God, I have always scored in about the 10th percentile - or lower - spatial relationships, which of course is the key to understanding anything mechanical.
TyBoo wrote:
Pat -
gljjr
City/Region: Fall City
C-Dory Year: 1982
Vessel Name: Migratory Dory
Photos: gljjr
PostPosted: Fri Sep 02, 2005 2:49 am    Post subject: Reply with quote
Sheesh Pat, you should have just given me a call! Wink After being a mekanik for many a year I decided to clean up and do my problem solving with computers. But I still know a thing or two.
Since you got it working all is well. As stated above I would guess you just had air in the system and needed to burp it out.
Now then, does anyone know where I can rent a gantry crane to pull the motor on my boat? So far it looks like I'm going to have to make one. Sad
Gary Johnson
KB7NFG
k3nlind
City/Region: Layton
Vessel Name: Topkick
Photos: Topkick
PostPosted: Fri Sep 02, 2005 10:34 am    Post subject: Reply with quote
Gee Pat, look at the bright side... My son says, "Nobody is totally useless, they can always serve as a bad example!"
Right here you have opened a door I was looking at how to get through... I have grease AND glue questions and didn't know where to ask them... so here goes:
What grease do you expert mekaniks recommend for the trailer wheel bearings and what for the Honda engine control zerks?
What are you all talking about (other than I comprehend that it is some form of glue) when you mention 5500 and 2200 and 2600 (I don't really remember the numbers and I'm too lazy to glean back through the archives). Can someone tell me the Brand names of these glues and basically what each might be used for?
For now just sign me off as mekanically dumber than Pat... Embarassed
E.C.H.O.
bcnu,
ken
PostPosted: Fri Sep 02, 2005 10:55 am    Post subject: Reply with quote
k3nlind wrote:
<stuff clipped>
The sealants/adhesives are 3M marine products 4000, 4200 and 5200. They are essentially high performance caulks so they can be used as both adhesives and sealants.
4000 is a fast cure sealant with improved UV resistance, 4200 is a fairly fast cure sealant and 5200 is the strongest but is very slow curing. Info on all of them can be found at the link provided above. I almost always have a tube of 4200 and 5200 on board.
Roger on the SeaDNA
gljjr
C-Dory Year: 1982
Photos: gljjr
PostPosted: Fri Sep 02, 2005 11:27 am    Post subject: Reply with quote
As far as what grease to use. I personally prefer to use a synthetic grease formulated for marine use. I have used Mobile 1, Lucas, and Amsoil grease all with good results. I would use the marine grease on both the bearings and the controls. You want to use marine grade grease as it is formulated to combat water better than a non marine grease.
I want the synthetic as it is usually good to a higher temperature than a non synthetic. That is important when dealing with trailer bearings!
k3nlind
City/Region: Layton
Photos: Topkick
PostPosted: Fri Sep 02, 2005 12:12 pm    Post subject: Reply with quote
thanx Roger and Gary... I appreciate the information. Laughing
jimandlaurie
City/Region: Puyallup
Photos: Laurna Jo
PostPosted: Sat Sep 03, 2005 7:27 pm    Post subject: Reply with quote
Happy Birthday again Pat... A Grease Gun and a Wench... (sorry coudn't resist)
Commodore Jim & Adm. Laurie
Former C-Dory Christener.
2004 C-Dory Skiff- Little Poit Dhubh
2005 C-Dory 25 Cruiser -sold 2103
2002- C-Dory 22 Cruiser- Sold 2005
Page generation time: 0.1122s (PHP: 33% - SQL: 67%) - SQL queries: 27 - GZIP disabled - Debug on
