Frozen bilge water, bad noise when spinning
chucko
City/Region: Davidson
C-Dory Year: 1997
Vessel Name: Sea Angel
Photos: Sea Angel
PostPosted: Sat Feb 21, 2015 11:53 am    Post subject: Frozen bilge water, bad noise when spinning Reply with quote
My rule 500 auto sensing bilge pump was trying to sense frozen water and making a terrible grinding sound,so I pulled the fuse for now. I am hoping no damage done after it thaws. Any knowledge about this appreciated. 5 degrees yesterday Tux
What doesn't kill us makes us stronger.
I say that every time I wax the boat.
1997 22 cruiser, sold may 2023
1998 17 Aquasport Osprey cc sold sold 2012
1977 16 Mako cc sold 1999
tsturm
City/Region: Soldotna
Vessel Name: JMR TOO
Photos: JMR-TOO
PostPosted: Sat Feb 21, 2015 1:08 pm    Post subject: Re: Frozen bilge water, bad noise when spinning Reply with quote
You will probably be ok it was still running. I have burnt up more than my share of pumps by not pulling the fuse in the winter. Wink
Thanks for taking our weather down below, I needed the break!! Mr. Green
Jake
PostPosted: Sat Feb 21, 2015 1:26 pm    Post subject: Reply with quote
So that's why my bilge pump doesn't work in the Spring. Hmmm
potter water
City/Region: Logan
C-Dory Year: 1997
C-Dory Model: R-21 Tug
Vessel Name: Poopsy
Photos: Still C-razy
PostPosted: Sat Feb 21, 2015 4:59 pm    Post subject: Reply with quote
If you are keeping the boat out of the water during the freezing months as I do, I pull the batteries all together and keep them warm in my garage and can top them off several times in the winter. Precludes any electronic gremlins happening while the boat is under covered storage on the trailer. If you are keeping your boat in the water, then, of course, you would want full time bilge function. I use to resist pulling the batteries, but over the years, my batteries last longer and it is also a chance to clean up the battery compartments year to year.
Testosterone Tales-Amazon.com
KG7RC
chucko
C-Dory Year: 1997
Photos: Sea Angel
PostPosted: Mon Feb 23, 2015 2:22 pm    Post subject: Reply with quote
After calling tech support,the response was pull the fuse if u can befor freeze.the proper size fuse should blow before damaging unit. I put it back after thaw and seems fine, caught it in time I guess. Thumbs Up
PostPosted: Mon Feb 23, 2015 6:09 pm    Post subject: Reply with quote
In the water or on the trailer? If it is on the trailer, you can pull the plug, make sure the nose of the trailer is raised a bit, and the water will drain out. If it is in the water, and water in the cockpit is freezing, what is happening with the water the boat is in??? Shocked
chucko
C-Dory Year: 1997
Photos: Sea Angel
PostPosted: Wed Feb 25, 2015 6:03 pm    Post subject: Reply with quote
I have the boat on a lift above the water, I just prefer to keep pump on if occasional rain gets in
Page generation time: 0.0662s (PHP: 30% - SQL: 70%) - SQL queries: 21 - GZIP disabled - Debug on
