Lucky Day
Joined: 10 Oct 2006 Posts: 215 City/Region: Churchton
State or Province: MD
Vessel Name: Lucky Day
Photos: Lucky Day
Posted: Thu Mar 21, 2013 2:37 pm Post subject: Jabsco Electric Flush Marine Toilet |
I have a line on a what might be a good deal on one of these Jabsco units: http://www.amazon.com/Jabsco-37010-0090-Electric-12-Volt-Compact/dp/B000O8F3D2
A local boater has a new one he wants to sell. Anyone know if it will fit properly and work in my 2004 CD-25? And would it be easy to install/replace the existing Jabsco head that was factory installed?
Thanks - David |
Discovery
Joined: 08 Dec 2003 Posts: 1245 City/Region: LOA, UTAH
Vessel Name: Discovery
Photos: Discovery
Posted: Thu Mar 21, 2013 3:26 pm Post subject: |
David,
Does your 25' have a sewage holding tank that is separate from the toilet? Not part of the toilet base. The unit you indicate has no built in holding capacity, but would discharge into a tank or overboard if you incorporated a "Y" selector valve. _________________
Brent and Dixie,
1984 22' Classic sold 2003
2003 24' TomCat sold 2005
2006 CD 22' Angler Sold 2014
"Free men do not ask permission to bear arms." ~ Thomas Jefferson |
Lucky Day
Photos: Lucky Day
Posted: Thu Mar 21, 2013 5:15 pm Post subject: |
Yes. The holding tank is located under the deck at the transom. |
Joined: 02 Nov 2003 Posts: 21604 City/Region: Pensacola
Posted: Sat Mar 23, 2013 3:16 am Post subject: |
The electric is almost identical-there was a conversion kit from manual to electric. You might move the base slightly, and do some replumbing. I had one conversion and one new electric. (but not in a C dory) You should be able to rotate the base90 deg. If there is not enough room for the motor straight back.
You will probably use a bit more water (fill up the tank faster). The discharge is 1"--adaptor supplied. The used to called the "growler". For the noise they made. Like any head the don't like anything not pre eaten... They do use16 amps..short time. I had some electrolysis issues on the bronze thru hull, until I put in a dual pole switch (breaker) to disruptive the negative when I was not actually using the head. _________________ Bob Austin
Lucky Day
Photos: Lucky Day
Posted: Sat Mar 23, 2013 6:41 pm Post subject: |
Thanks for responding. If I can get it for the price I want to pay I will forge ahead. |
