breausaw
Vessel Name: Triple J
Photos: Triple J
Posted: Fri Aug 10, 2012 2:29 pm Post subject: In-hull transducer for 25 |
Is there any place on a 25 with solid fiberglass to use an in-hull transducer? I would like to install a simple sounder for shallow depth alarm, and as a backup for the E80. My second option will be to mount the transducer on the starboard trim tab. _________________ Jay
tsturm
Joined: 01 Nov 2003 Posts: 1164 City/Region: Soldotna
Vessel Name: JMR TOO
Photos: JMR-TOO
Posted: Fri Aug 10, 2012 3:06 pm Post subject: Re: In-hull transducer for 25 |
breausaw wrote: | Is there any place on a 25 with solid fiberglass to use an in-hull transducer? I would like to install a simple sounder for shallow depth alarm, and as a backup for the E80. My second option will be to mount the transducer on the starboard trim tab. |
I don't think so. I put a Bronze through hull to the port side of the bilge pump. The trim tab sounds like a good option???
Have a good one.  |
ghone
C-Dory Year: 2011
Vessel Name: Kerri On
Photos: Kerri On
Posted: Fri Aug 10, 2012 3:52 pm Post subject: |
On the 22 the hull goes from cored to single skin ahead of the helm bulkhead. Not seen the 25 setup but check under the vee berth. You will see the core tapered down from double skin to single with a tapered transition area. On my 19 and 22 I used in hull pucks with good success. |
Posted: Fri Aug 10, 2012 5:10 pm Post subject: |
You could always do what Redfox did and VERY CAREFULLY remove the inner fiberglass skin and the core, leaving the outer skin intact. That way you can put one in a convenient location.
His pictures are HERE
charlie _________________ CHARLIE and PENNY CBRAT #100
K4KBA |
breausaw
Photos: Triple J
Posted: Fri Aug 10, 2012 5:54 pm Post subject: |
[quote="Captains Cat"]You could always do what Redfox did and VERY CAREFULLY remove the inner fiberglass skin and the core, leaving the outer skin intact. That way you can put one in a convenient location.
charlie[/uote
I thought of that also.
If it's not too deep could fill the hole with resin. |
