In-hull transducer for 25
breausaw
Vessel Name: Triple J
Photos: Triple J
PostPosted: Fri Aug 10, 2012 2:29 pm    Post subject: In-hull transducer for 25 Reply with quote
Is there any place on a 25 with solid fiberglass to use an in-hull transducer? I would like to install a simple sounder for shallow depth alarm, and as a backup for the E80. My second option will be to mount the transducer on the starboard trim tab.
Boatless for now but looking
tsturm
City/Region: Soldotna
Vessel Name: JMR TOO
Photos: JMR-TOO
PostPosted: Fri Aug 10, 2012 3:06 pm    Post subject: Re: In-hull transducer for 25 Reply with quote
I don't think so. I put a Bronze through hull to the port side of the bilge pump. The trim tab sounds like a good option???
Have a good one. Thumbs Up Thumbs Up
ghone
City/Region: Nanaimo
C-Dory Year: 2011
Vessel Name: Kerri On
Photos: Kerri On
PostPosted: Fri Aug 10, 2012 3:52 pm    Post subject: Reply with quote
On the 22 the hull goes from cored to single skin ahead of the helm bulkhead. Not seen the 25 setup but check under the vee berth. You will see the core tapered down from double skin to single with a tapered transition area. On my 19 and 22 I used in hull pucks with good success.
PostPosted: Fri Aug 10, 2012 5:10 pm    Post subject: Reply with quote
You could always do what Redfox did and VERY CAREFULLY remove the inner fiberglass skin and the core, leaving the outer skin intact. That way you can put one in a convenient location.
His pictures are HERE
charlie
breausaw
Photos: Triple J
PostPosted: Fri Aug 10, 2012 5:54 pm    Post subject: Reply with quote
[quote="Captains Cat"]You could always do what Redfox did and VERY CAREFULLY remove the inner fiberglass skin and the core, leaving the outer skin intact. That way you can put one in a convenient location.
charlie[/uote
I thought of that also.
If it's not too deep could fill the hole with resin.
Page generation time: 0.0319s (PHP: 62% - SQL: 38%) - SQL queries: 18 - GZIP disabled - Debug on
