Orbial Polisher
Tug
City/Region: Sault Ste. Marie
State or Province: ON
C-Dory Year: 1985
Vessel Name: Drifter
Photos: Drifter
PostPosted: Fri Oct 07, 2011 9:08 pm    Post subject: Orbial Polisher Reply with quote
Today i thought i would try to polish and shine the black trim on the side of my boat. I was a total failure. I used that 3M Restorer and wax product.First i applied some of the product to the 6 inch Orbital Polisher pad and gently spread it over the area.next i used another softer bonnet to do the polishing and shining, all that happened was streaking and the bonnet turned almost a black colour where as it was white before. No shine or nothing,its still dull with streaks in it. Tug
Montana Kev
City/Region: Bozeman/Yellowstone
State or Province: MT
Vessel Name: Grace
Photos: Grace
PostPosted: Fri Oct 07, 2011 9:31 pm    Post subject: Reply with quote
Tug,
The 3M restorer wax worked good for me on my green trim which was chalky white when I bought the boat. I found that I had to first clean the area really good with soap and water after I power washed it. I used a cheap boat cleaner/wax from Attwood first to cut thru some of the layers of chalk. After some time with the cleaner I had a pile of green rags. I cut round rags and lay them over the buffing pad, then toss them once they turn green. Eventually the green almost stopped coming off. Then I moved to the 3M restorer. I have better luck rubbing the restorer or cleaner on the boat with a soft sponge or polishing pad first then go right to it with the buffer. It took 2 passes with the restorer to get a good result. Do small areas at a time.
Good Luck,
Kevin
A Fishin C
Guest
PostPosted: Fri Oct 07, 2011 9:49 pm    Post subject: Reply with quote
I tried the orbital as well and crappy results. This time I am going with Mother's Pure Carnuba wax on the bottom and top sides, by hand, in small sections.
Dreamer
Photos: Dreamer
PostPosted: Fri Oct 07, 2011 10:30 pm    Post subject: Reply with quote
BTDT. The orbital buffer was very unsatisfactory. For the colored trim, Cabernet in our case, a real buffer and two levels of rubbing compound finally did the job. Sold the Orbital on "2good2toss" $20. Followed up with 3M Polish/Wax then 3M Wax.
Dreamer- Sold 25 Feb. 2013
ferret30
Vessel Name: Lily Pad
Photos: Lily Pad
PostPosted: Sat Oct 08, 2011 3:36 am    Post subject: Reply with quote
I had success with a Porter Cable random orbital and 3M color restorer then their lighter cleaner wax combo. But there were definitely whole areas and spot stains that I had to do by hand. My technique is now to start with light stuff, then in places where that didn't work, I go heavier by hand, then cover it all up with wax. I had green come off on the pads and rags even with the lightest abrasive. Kind of worrisome at first but then I realized the color goes all the way through.
Tug
C-Dory Year: 1985
Photos: Drifter
PostPosted: Sat Oct 08, 2011 8:49 am    Post subject: Reply with quote
I will give it another go today and try your suggestions. When i saw that black stuff coming off it had me worried also, thought it was black paint at first. Need to take a few pain pills for my back, that bottom painting is a killer.Want to stain the exterior bulkhead wall again today also.Tug
nordicstallion
City/Region: Crescent City
C-Dory Model: 19 Angler
Vessel Name: Rylee Rose
Photos: Rylee Rose
PostPosted: Sat Oct 08, 2011 10:16 am    Post subject: Reply with quote
I used a variable speed power buffer and automotive polishing compound. looks good. stay away from the c-dory sticker tho as it will be destroyed. That part needs to be done by hand. My boat wasnt too bad when I got it.You will need to start with rubbing compound to get rid of chalk first. Its going to take some time but its worth it. Vern/C-Dog
Tug
C-Dory Year: 1985
Photos: Drifter
PostPosted: Sat Oct 08, 2011 8:20 pm    Post subject: Reply with quote
I gave it another go at polishing the Black Trim on my boat.First i rubbed in by hand 3M Marine Rubbing Compound followed by hand buffing Collinites's No.925 Fiberglass Boat Wax. I ended up with a shine but the streaks can be still seen deep in the Gel-Coat. I guess its the best that can be done for the 1985 Gel-Coat. See pictures in album. Tug
dotnmarty
City/Region: Sammamish
Vessel Name: LIZZIE II
Photos: Lizzie
PostPosted: Sat Oct 08, 2011 8:53 pm    Post subject: Reply with quote
I think it looks great!
MartyP
hambone
PostPosted: Sat Oct 08, 2011 9:20 pm    Post subject: Reply with quote
LOOKS GREAT, WELL DONE.
H Wink Thumbs Up
Hawg Hunter Productions.
ferret30
Photos: Lily Pad
PostPosted: Sat Oct 08, 2011 11:04 pm    Post subject: Reply with quote
Ha! That's not too different from the result I got on our 2006! The dark green was hard to get shiny for some reason. I kind of wish our boat had the light gray stripes!
PostPosted: Sun Oct 09, 2011 12:15 pm    Post subject: Reply with quote
Black is the worst color to "restore". Ask me how I know. Wink
Page generation time: 0.0887s (PHP: 45% - SQL: 55%) - SQL queries: 24 - GZIP disabled - Debug on
