BF150 Honda fuel program error code-HELP
Jack in Alaska
C-Dory Model: 26 Pro Angler
Vessel Name: HIGH TIDE II
Photos: HIGH TIDE II
PostPosted: Sat Jul 02, 2011 9:51 pm    Post subject: BF150 Honda fuel program error code-HELP Reply with quote
My son just called me about the subject problem.
The motor runs fine as does the other one but one flashed the code.."error in programmable fuel system".
Can one continue to run the engine. He is 20 miles out and needs to recover his shrimp pots.
No. CD026021I405; AK-5008-AK
MSSI No. 338143486(cancelled)
Stolen & stripped in Aug. 18
Alyssa Jean
Vessel Name: Alyssa Jean
PostPosted: Sat Jul 02, 2011 10:29 pm    Post subject: Reply with quote
He has 2 150's on a 26??
David and Kate
Alyssa Jean 16 Angler
K7KJR C-Brats #51
Jack in Alaska
PostPosted: Sat Jul 02, 2011 10:40 pm    Post subject: Reply with quote
two 150's on a 28' by 9' Harbercraft
digger
City/Region: Spokane
Vessel Name: C-Sik
Photos: Snoopy-C
PostPosted: Sun Jul 03, 2011 1:34 am    Post subject: Reply with quote
I'd run it, if it will continue to run. Most of these codes will either warn you to fix something, or shut you down to some degree forcing the fix. It may be a fuel problem or a sensor problem (oxygen sensor). If moisture is the culprit, it may dry itself out...if the injectors are problem, then an cleaning them or replacement might be required. My 2 cents. Ron
Page generation time: 0.0262s (PHP: 63% - SQL: 37%) - SQL queries: 17 - GZIP disabled - Debug on
