Fuse block with 20 fuses
Jack in Alaska
C-Dory Model: 26 Pro Angler
Vessel Name: HIGH TIDE II
Photos: HIGH TIDE II
PostPosted: Mon May 30, 2011 3:03 am    Post subject: Fuse block with 20 fuses Reply with quote
My CD has two fuse blocks with 10 fuses each for various things on the boat. 1/3 of the spots do not work and basically are a POS.
I am looking for a fuse block with spade fuses that will accommodate 20 fuses. It does not need any grounding capability as my present grounding block is adequate and works well.
Any ideas please????
Jack
No. CD026021I405; AK-5008-AK
MSSI No. 338143486(cancelled)
Stolen & stripped in Aug. 18
PostPosted: Mon May 30, 2011 10:30 am    Post subject: Reply with quote
I couldn't find a fuse block for 20 circuits. You'll probably have to replace the two fuse blocks with two new fuse blocks. I'd recommend the Blue Sea Systems blocks. They're well made and if you get the ones with the covers, you can easily label each circuit - imagine that, labeled circuits! (I wish the people who wired boats were required to label all fuses). Here's a link to the Blue Seas product.
PostPosted: Mon May 30, 2011 11:45 am    Post subject: Reply with quote
Jack,
Just out of curiosity, can you find a maker/importer name on the fuse blocks? I have a 2005 C-25 and it came with reasonable wiring and switch panel plus fuse blocks. Or is your boat one made before C-Dory took over the molds?
Jack in Alaska
PostPosted: Mon May 30, 2011 1:32 pm    Post subject: Reply with quote
Roger.......
Thanks for the info. That company has just what I need. Now to find one here in the hinterlands.
Jack
PostPosted: Mon May 30, 2011 2:39 pm    Post subject: Reply with quote
Jack in Alaska wrote:
Roger.......
Jack
Jack - I believe that West Marine carries Blue Sea stuff. I know Fisheries Supply in Seattle carries it. They would probably ship to Alaska.
mikeporterinmd
State or Province: MD
Vessel Name: Shelly IV
Photos: Shelly-IV
PostPosted: Mon May 30, 2011 9:29 pm    Post subject: Reply with quote
Check around on prices for Blue Seas stuff. West is probably the most expensive. While I don't mind paying the premium when I buy in store, I don't see much sense in doing so via mail-order.
I redid my entire boat with Ancor and Blue Seas. Check out my photo album if interested. I did the work a while ago, and it is holding up very well.
Mike
Jack in Alaska
PostPosted: Mon May 30, 2011 10:38 pm    Post subject: wiring Reply with quote
Mike........
Any chance you are coming to Alaska this summer. I have a wiring job for you.....ha
Yours looks like mine wants to be. I have parts coming and will tear into it when they get here.
Jack
mikeporterinmd
Photos: Shelly-IV
PostPosted: Tue May 31, 2011 11:38 pm    Post subject: Re: wiring Reply with quote
Mike........
Jack
Thanks a bunch! I am not the neatest wirer, here, either. Some guys make it
look like art. But, what I did is functional, proper, and should last a long time.
Some of the coils of wire are spare runs. I ran an extra 10 gauge positive and
neutral forward in case I want to power radar or something similar that is
power hungry.
Mike
AKDAVE
C-Dory Model: R-25 Tug
Vessel Name: Rebecca Ann
PostPosted: Wed Jun 01, 2011 10:44 pm    Post subject: Reply with quote
Jack,
Polar Wire in Anchorage also stock some Blue Seas items.
Jack in Alaska
PostPosted: Fri Aug 26, 2011 11:32 pm    Post subject: rewiring Reply with quote
I totally rewired behind the dash using two Blue Seas fuse blocks. It came out excellent and even looks like I knew what I was doing. All labeled.
The only thing in-op is the anchor light and it did not work before and I don't anchor at night.
Doryman
Vessel Name: Lori Ann
Photos: Lori Ann
PostPosted: Sat Aug 27, 2011 1:17 pm    Post subject: Reply with quote
West will match online competition in-store -- all you have to do is ask and show them the price you want them to match.
Doryman
M/V Lori Ann
Anacortes, WA
Page generation time: 0.0577s (PHP: 52% - SQL: 48%) - SQL queries: 24 - GZIP disabled - Debug on
