correct height for outboards while traveling
gokorn1
City/Region: Palmer
PostPosted: Mon Apr 25, 2011 11:32 pm    Post subject: correct height for outboards while traveling Reply with quote
Just wondering how I should have my outboards when traveling down the road. I've owned bass boats with supports in the past,
Simplicity
City/Region: Chipley
Vessel Name: Simplicity
Photos: Simplicity
PostPosted: Tue Apr 26, 2011 7:54 am    Post subject: Reply with quote
I've towed our boat with a Honda 135 many thousands of miles with the trim set at the spot where the lower gearing starts with no noticeable ill effects so far. Recently a couple of people recommended tilting it all the way up with the support bracket in place so I'm not so sure what the best way is either.
sweet pea
City/Region: Gulfport
State or Province: MS
C-Dory Year: 1998
Vessel Name: Sweet Pea (SOLD 10/2012)
Photos: Sweet Pea
PostPosted: Tue Apr 26, 2011 8:32 am    Post subject: Reply with quote
If you do trailer with the motor trimmed up, you really need a support. There is a lot of stress on the transom due to flexing with the motor trimmed up and trailering.
A support device will eliminate most of the flexing as long as the transom is strapped down as well. In my opinion the lock down lever on the motor (not on all motors) from the manufacturer isn't adequate alone.
Capt. Charles
Will-C
City/Region: Temple
Vessel Name: Will-C
Photos: Will-C
PostPosted: Tue Apr 26, 2011 9:36 am    Post subject: correct height for outboards while traveling Reply with quote
I would say we are about half way. It kind of depends on your trailer somewhat. Coming in out out of a parking lot with a large difference in elevation between the parking lot and the street is the thing you want to watch out for. In my limited thinking you just don't want the motor bouncing around trying to work up dynamic loads to better put cracks in your transom. I just have a piece of carpet covered 2 x 4 x 18" with a lag bolt in one end going thru a couple links of chain tied to a piece of cord with a snap clip. We place the 2 x 4 in between the transom part of the motors mount and the tilting motor itself and use the power tilt to clamp down on the 2 x 4. The chain cord and clip arrangement keep the 2 x 4 attached should it ever fall out as who wants that thru your windshield. Check my album under trailer modifcations I think. We could be wrong!
D.D.
potter water
City/Region: Logan
C-Dory Year: 1997
C-Dory Model: R-21 Tug
Vessel Name: Poopsy
Photos: Still C-razy
PostPosted: Tue Apr 26, 2011 10:21 am    Post subject: Pretty well balanced Motors when tilted Reply with quote
My CD 22 has twin Suzuki's. My boat mechanic says that the power head on the motor when fully tilted places the center of gravity of the motor on or slightly ahead of the motor mounting bracket such that the "bouncing" moment is vertical over the bracket. Not cantilevered over the back end, and therefore will not induce twisting motions on the motor bracket. On the other hand, with the motors down, the CG is clearly aft of the stern, and will induce a twisting or bending load on the stern when you hit bumps.
That is what he says, and he's got 40 year of experience.
I had a small trailerable houseboat that had a heavy merc 90 on an extended motor mount. The mount was a good two feet aft of the stern of the boat and the motor hung off of that. There was a huge moment arm hanging off that stern and it always bothered me, but the boat was towed thousands of miles that way. I still stowed the motor in the up position so's not to strain the mounting bits that were part of the motor itself.
Also, to finish off this tome, my mechanic says that if a stern and motor can't handle highway bouncing around, then it is going to be a weak design under motoring in heavy seas as well.
So, you pays yer money and you takes yer chances.
Testosterone Tales-Amazon.com
KG7RC
sweet pea
C-Dory Year: 1998
Photos: Sweet Pea
PostPosted: Tue Apr 26, 2011 10:38 am    Post subject: Reply with quote
I don't think you can compare transom stress of trailering to the stresses of being on the water under way. Unless you are jumping logs in the river. My mechanic would disagree with yours. You just have to read, research, and make your own mind up.
Watch the engine on the next trailered boat you pass. There is a huge amount of difference in the movement you see when trailering as opposed to underway on water.
BrentB
City/Region: Greenwood
State or Province: IN
Photos: BrentB
PostPosted: Tue Apr 26, 2011 11:23 am    Post subject: Reply with quote
Yamaha has an engine support
http://www.simyamaha.com/Yamaha_Engine_Support_p/mar-mtspt-ym-10.htm
This company has a wedge support
http://www.m-ywedge.com/
Brent Barrett
Nunya
Photos: Nunya
PostPosted: Tue Apr 26, 2011 11:40 am    Post subject: Reply with quote
I've been using the mywedge for years on boats. Turned all my fishing buddies onto it. They all use it. Good product.
Montana Kev
City/Region: Bozeman/Yellowstone
State or Province: MT
Vessel Name: Grace
Photos: Grace
PostPosted: Tue Apr 26, 2011 12:02 pm    Post subject: Reply with quote
Here is a thread with some good information on motor position when trailering.
http://www.c-brats.com/viewtopic.php?t=12379
El and Bill
City/Region: Lakewood, CO
Vessel Name: Halcyon
Photos: Halcyon
PostPosted: Tue Apr 26, 2011 12:04 pm    Post subject: Reply with quote
We have trailered our twin Honda 40's tens of thousands of miles by dropping them gently down onto a nice fat dowel placed horizontally across the mount. Don't know if this is best for all but an experienced boater suggested this to us more than ten years ago and so far so good - like El's grandad used to say, "proof's in the pudding."
Doryman
Vessel Name: Lori Ann
Photos: Lori Ann
PostPosted: Tue Apr 26, 2011 12:50 pm    Post subject: Reply with quote
Me 2. Also use a product they make that keeps the engine(s) on centerline of boat while trailering (i.e., keeps them upright laterally.)
Doryman
M/V Lori Ann
Anacortes, WA
jennykatz
City/Region: naples
Vessel Name: Little Treasurer
Photos: Jennykatz
PostPosted: Tue Apr 26, 2011 1:40 pm    Post subject: outboard ht Reply with quote
When we trailer our cc-23 or the cd-22 (when we had it) We would tilt the motor down and have a 2by6 hold it out a little like Will-c and Halcyon does .I would not trailer a boat using the little eng hold this will break first big bump in the road . We also tie the engine from moving around . Yamaha makes a rubberized product that you can insert into tilt ram that acts as a shock absorber . Check out some of the photo albums you will see how a lot of us trailer .
Doryman
Photos: Lori Ann
PostPosted: Tue Apr 26, 2011 1:46 pm    Post subject: Re: outboard ht Reply with quote
That is the mywedge.
Hunkydory
State or Province: WY
Vessel Name: Hunkydory
PostPosted: Tue Apr 26, 2011 2:00 pm    Post subject: Reply with quote
And we followed your advise several years ago putting more tens of thousands of miles on many rough roads with zero problems, so yes indeed the "proofs in the pudding" , though for at least 20,000 miles before that just used the built in supports and those miles included some very rough roads in the Yukon, BC and Alaska, so at least with the small Honda' s it will take quite abit more than the first big bump to do damage.
PostPosted: Tue Apr 26, 2011 2:06 pm    Post subject: Reply with quote
I tow with a triangle type wedge in under the mounting system. It is enough to raise the skegs about 14" of the ground on the level. That has been enough to clear the parking lot and curb cuts we have been across. The engines are tilted about 30 degrees forward, and lowered onto the blocks to hold them in tight. (Comes from my Yamaha mechanics recommendation.)
Page generation time: 0.0874s (PHP: 57% - SQL: 43%) - SQL queries: 32 - GZIP disabled - Debug on
