Motor Support for Trailering
Swee Pea
City/Region: Bath
Vessel Name: Swee Pea
Photos: Swee Pea
PostPosted: Sun Oct 04, 2009 11:15 am    Post subject: Motor Support for Trailering Reply with quote
I know this topic has be covered EXTENSIVELY, but when I was trying to find that wedge like rubber motor support for trailering that was linked in one of the posts on "Trailering Motors, Up or Down", I could not find the post. Embarassed (computerly challenged) A simple google search got me to the website of the M-y Wedge Motor Support (now I know what its called) .
So this post is not to rehash old stuff, but to help others who might not have found the old topic and are not familiar with the product. This is NOT a shameless plug for the manufacturer. Rolling Eyes http://www.m-ywedge.com/
Maybe this post and the title will make searching for this particular solution a little easier.
Maybe I am not making sense Shocked , but that's no surprise.
Safe boating to all
Swee Pea
matt_unique
City/Region: Boston
Vessel Name: Napoleon
Photos: Napoleon
PostPosted: Sun Oct 04, 2009 11:49 am    Post subject: Trailer Reply with quote
Does the trailer height for your vessel allow you to just keep it full down (once you're up the ramp)? If yes, I would suggest leaving it full down.
Captain Matt
Swee Pea
City/Region: Bath
Photos: Swee Pea
PostPosted: Sun Oct 04, 2009 1:37 pm    Post subject: Reply with quote
There is decent clearance, but I am a constant victim of Murphy's Law. I will know that there wasn't enough clearance when I pull into some area where I hit bottom - I saw a guy in a parking lot do this to his motor.
I think that this wedge product is kind of a meeting a happy medium - the engine is not full up nor totally down. It is "safely out of the way". Murphy will have to keep looking for another buddy. Wink
Swee Pea
PostPosted: Sun Oct 04, 2009 5:39 pm    Post subject: Reply with quote
I guess that the question is "Does the transom saver" (support which goes from the lower leg of the outboard to the tailer frame) or the wedge give better support and is easier on the transom? I don't know the answer to this question. I have never used a motor ram wedge, but have trailered with a piece of wood under the mount, to hold the motor up, and with the motor down, as well as several transom saver type of devices.
CAVU
City/Region: Spokane
Vessel Name: CAVU
Photos: CAVU
PostPosted: Sun Oct 04, 2009 9:52 pm    Post subject: Reply with quote
I am not advocating one way or the other but I will pass along my experience. I have always towed with the motors tilted up and locked down on the tilt lock support. I know that some of the motor manufacturers warn against trailering this way but I don't understand why it should be a problem. I have owned a 17 Montauk with 90hp Johnson which I have towed thousands of miles this way. Next I had a 19' Arima with 90 hp Honda which I towed for 10 years this way and my current 22' Cruiser with twin 40hp Hondas. Never had any problems. Having your engine firmly down on the metal tilt support seems better to me than bouncing around on a hard rubber support. The metal support arms which attach from the engine to the trailer frame seems to me would be even worse. Just my two cents worth.
Ken Trease
22 CD Cruiser, CAVU
Twin 40HP Hondas
Boont Boater
City/Region: Berkeley
C-Dory Year: 2010
Vessel Name: Aurora
PostPosted: Sun Oct 04, 2009 11:44 pm    Post subject: Outboard support? Reply with quote
I have a lot less trailering experience then Ken but I just used the supports that came with the outboards. We have a CD-25 with a 150 Verado and a 20 hp Honda kicker. I tried putting the engines down initially but it looked like an accident waiting to happen.
I know that the manufacturers want a different support but I don't understand why. I spoze if you were going over rough roads and there was a lot of bouncing around a different support might make sense.
Maybe it's just a liability kind of chicken-shit thing. Perhaps someone could explain why a different support system is necessary.
Ranger 29 tug
Casey
City/Region: The Villages(FL)
Vessel Name: "Dessert 1st"
Photos: Dessert 1st
PostPosted: Mon Oct 05, 2009 6:47 am    Post subject: Reply with quote
Maybe the Real Purpose of the little support legs (that we're not supposed to use...) is just one of those mystery's of Life! In that case, I wonder why every manufacturer puts them on their outboards?
Like most of us, I've used the support legs from time-to-time; with no ill effects.
Like Dr. Bob I usually have a special piece of wood that I put in place then lower the motor enough to jam the wood, thus taking some of the pressure off the hydraulic rams. I don't know the CORRECT answer, but the wood is delightfully low tech, and seems to work. There's something pretty neat about using an old piece of 2x4 to hold a multi-thousand dollar motor up!
...but that brings me back to Why the manufacturer's even bother with the little foot gizmo's. I suspect it's something silly like being able to temporarily hold the motor-up while we check the hydraulic fluid, or change a line.
Then again, maybe it IS one of those mystery's of Life; and now I have something to ponder Today.
Life is Good; but confusing.
Best,
Casey
PostPosted: Thu Oct 07, 2010 11:08 am    Post subject: Reply with quote
Well, it's time to 'fess up about my latest screwup! I bought some of those neat little hard rubber wedges for my twin Suzi 115's so I could use them on our latest trip to the CBGT in Oriental and a beach week on the outer banks. Launched the boat and recovered it several times, wedges seemed to work great. They keep the engines near but not quite fully up. You just insert the rubber block around the tilt/trim cylinder rod and lower the engine until it's locked in place.
As I said, all was fine until I got home. The boat was on the trailer and I went out to start "detripping" stuff (fishing gear, personal items, etc). I usually use a stepladder between the engines to climb onto the Armstrong Bracket instead of climbing up the ladder over the bow from the trailer.
I lit off the battery switches and tried to tilt engines full down, forgetting about the supports. Rolling Eyes Cry Cry Well, let me tell you all that those tilt/trim systems have plenty of down force.... I cracked both plastic reservoirs on the trim/tilt systems to the point where I can see the oil in them.
According to the manual, in order to remove the tilt/trim motors/hydraulics, you need to support the engine from the top, remove the stbd engine mount from the transom (or at least slide it to the right) to get it out. In looking at it, and with some hoped for consultation from Marc at Wefings, I think I can do it without moving that mount. If I can get to the allen screw holding the plastic reservoir onto the metal mount, just the port inner one (nearest the transom) is hard to reach, the other three are easy, I can remove that reservoir after I take the top piece off. The motor would rest on the engine locks instead of being supported from above. Hopefully strong enough.
I'll take pictures when I start work so that folks know how to do it if they ever screw up like I did. Probably will cost $350 or so in parts alone, Marc is checking on availability....
The message here is "be careful if you use those things...." Angry Thumbs Up
Wefings
Dealer
City/Region: Panhandle
Photos: Cruise Ship #4
PostPosted: Thu Oct 07, 2010 11:23 am    Post subject: Reply with quote
Working on it now, the guys in the shop think its doable that way , and John our parts guy is looking for availability .
Just left you a message Charlie .
Marc
Wefings Marine Website
Since 1909
Will-C
City/Region: Temple
Vessel Name: Will-C
Photos: Will-C
PostPosted: Thu Oct 07, 2010 1:21 pm    Post subject: Motor Support for Trailering Reply with quote
Hi,
I just use a two foot length of regular wood 2x4 carpeted with a short piece of chain lag bolted to the end and a carabineer clip to clip the chain and a short piece of cord/ rope to the boat so if it ever falls out it does not become intimate with a fellow motorists windshield. I just tilt the motor and insert said 2x4 and lower the motor with the tilt switch and clamp down on the 2 x 4 then clip on safety rope/chain combination on to the boat somewhere and wala No problemo. El Cheapo! It's large enough that you can't miss it when launching or detripping. Check my album for pictures under trailer mods I think. Sorry for your troubles Charlie. Sad
D.D.
PostPosted: Thu Oct 07, 2010 1:23 pm    Post subject: Reply with quote
I hear you, should have done it the easy way instead of the tech way! My Bad!!
Will-C
City/Region: Temple
Vessel Name: Will-C
Photos: Will-C
PostPosted: Thu Oct 07, 2010 2:15 pm    Post subject: Motor Support for Trailering Reply with quote
Charlie,
You went the hi tech route. There is no way I'm gonna call you a geek as where I'm from that's gnat (sic) right!
Respectfully submitted,
D.D.
Mike...
Photos: Accelerando
PostPosted: Thu Oct 07, 2010 3:52 pm    Post subject: Reply with quote
Ouch Charlie! I am sorry to hear that. Sad
I purchased the m-ywedges (two for each motor) and they have worked well. I'll have to remember to not do that.
mike
PostPosted: Thu Oct 07, 2010 4:17 pm    Post subject: Reply with quote
Yeah, Mike they do what they're supposed to do unless you forget to take them out and try to put your engines down like I did. Not sure what your T/T stuff is made out of but the force will bust things up pretty good.
BrentB
City/Region: Greenwood
State or Province: IN
Photos: BrentB
PostPosted: Thu Oct 07, 2010 5:18 pm    Post subject: Reply with quote
Sorry to read about this event
At least it happened after the trip
Brent Barrett
Page generation time: 0.0635s (PHP: 67% - SQL: 33%) - SQL queries: 28 - GZIP disabled - Debug on
