ETEC 50 Oil leak
Noreaster
City/Region: Wallace
Vessel Name: Nor'easter
Photos: Nor'easter
PostPosted: Fri Aug 27, 2010 1:05 pm    Post subject: ETEC 50 Oil leak Reply with quote
Was going over the boat last night before a trip this weekend and noticed my oil level was down so I topped it off. Imagine my dismay when I returned from the garage and saw oil running down the skeg! Ran back to the garage and grabbed a ratchet kit to remove the engine cowls. I found the oil tank was cracked on the backside about halfway down. Has anyone else seen this? I ran Yamahas for 24 years prior to 2004. Never had a single issue. I'm hoping this is an isolated incident. Mad
Lenny
bncwaite
City/Region: Crockett
Vessel Name: Roe Boat
Photos: Time To Fish
PostPosted: Fri Aug 27, 2010 1:29 pm    Post subject: Reply with quote
Yup...I've heard of it before here:
http://www.etecownersgroup.com/?forum=136482
They(BRP) have been replacing them under warranty. The "weld" seems to come apart.The fix seems to be an updated oil tank.
Matt Gurnsey
Dealer
City/Region: Port Orchard
Photos: Kitsap Marina
PostPosted: Fri Aug 27, 2010 5:00 pm    Post subject: Reply with quote
We've done quite a few E-Tecs and haven't seen this issue, so my guess is it is not very common.
Matt Gurnsey
Kitsap Marina
www.kitsapmarina.com
360-895-2193
(888) 293-7991
Noreaster
Photos: Nor'easter
PostPosted: Mon Aug 30, 2010 1:14 pm    Post subject: Reply with quote
This motor is so easy on oil I was able to get out this weekend just the same (there were a couple of cups in the tank below the crack, I just kept a close eye on consumption). I found a new tank for almost $40.00 but with the new isolators, mounts, clamp and gasket sleeve plus shipping it comes out to around $80.00. Sure beats the $340.00 or so for a new assembly. Still, it makes me wonder if I shouldn't have stuck with Yamahas. I ran Yamaha 2 strokes for 20 years and had zero issues, between this motor and the 90 I had on the boat before this one, I've racked up some pretty good repair bills Mad
Page generation time: 0.0686s (PHP: 49% - SQL: 51%) - SQL queries: 18 - GZIP disabled - Debug on
