interior lights and bilge pumps won'twork
knot flying
City/Region: Charlestown
State or Province: RI
C-Dory Model: R-27 Tug
Vessel Name: ILLUSIONS
Photos: Knot Flying
PostPosted: Fri May 07, 2010 10:33 am    Post subject: interior lights and bilge pumps won'twork Reply with quote
I can't figure out why I can't get my interior lights or bilge pumps to work. I checked all of the fuses and they all look good. it seems like there is no power going to them. I put the switches on and the lights on the switches aren't going on either. Does anyone have an idea as where to look for something disconnected?
BrentB
City/Region: Greenwood
State or Province: IN
Photos: BrentB
PostPosted: Fri May 07, 2010 10:45 am    Post subject: Reply with quote
I would check the battery voltage and connectors for corrosion and loose connections. Then check the switch with the power off, fuses and light bulbs for conductivity using a digital volt meter
Brent Barrett
matt_unique
City/Region: Boston
Vessel Name: Napoleon
Photos: Napoleon
PostPosted: Fri May 07, 2010 10:52 am    Post subject: Gimme lights! Reply with quote
Forgive my stupid question - do you have a battery selector switch and if yes was it on 1, 2, or Both?
I doubt all your lights and pumps are burned out so I'm sure they are not getting juice at all. Start at your bats as suggested above. A voltage or multi-meter is your friend for this problem.
Are you getting power anywhere?
Captain Matt
PostPosted: Fri May 07, 2010 11:35 am    Post subject: Reply with quote
This is a classic case of "I'm not getting power to ___________"
We can all guess and give reasonable advice, as above, but the ONLY way to really find out what's going on is to buy a voltmeter and learn how to use it. They are cheap, Harbour Freight ~$4, and when set on the 20VDC scale can be used to trace how far the battery voltage is going.
Start with the battery, that's a good place to see how a voltmeter works, and keep going to the front of the boat to see where voltage disappears. Remember, the red lead goes to positive and the black lead to negative. The switches are all positive.
That's all it takes and you can find the fault immediately.
Matt Gurnsey
Dealer
City/Region: Port Orchard
Photos: Kitsap Marina
PostPosted: Fri May 07, 2010 12:00 pm    Post subject: Reply with quote
Is there a master breaker back near the battery? Try resetting that.
Matt Gurnsey
Kitsap Marina
www.kitsapmarina.com
360-895-2193
(888) 293-7991
BrentB
Photos: BrentB
PostPosted: Fri May 07, 2010 12:06 pm    Post subject: Reply with quote
My boat (not a C-Dory) came with an electrical diagram and I updated it with add-ons and updates.
designbug
City/Region: Annapolis
State or Province: MD
Vessel Name: Bella II
PostPosted: Fri May 07, 2010 12:18 pm    Post subject: Reply with quote
I had a similar problem last year and it turned out that the main circuit breaker was defective. I was able to determine that the main circuit breaker was the problem when I bypassed it and dc power was restored.
Since I replaced the breaker I have had no further problems.
Thanks, Dick
Page generation time: 0.089s (PHP: 24% - SQL: 76%) - SQL queries: 20 - GZIP disabled - Debug on
