Seat Post repair on a 16ft Angler
shogimac
City/Region: Klawock
Vessel Name: SISU
Photos: Tonie O
PostPosted: Thu Apr 08, 2010 2:45 pm    Post subject: Seat Post repair on a 16ft Angler Reply with quote
Hello all,
Now that we can fish again in Monterey Bay for Salmon, I've dusted off the 16 footer for fishing (she does this great). I need to refasten the passenger seat post to the floor as it is loose.
Taking it off was easy but any advise on what is underneath the floor and a good way to refasten would be so helpful. Thanks in advance!
Shawn
JT
City/Region: JUNEAU
C-Dory Year: 1990
Vessel Name: Lil Toot
Photos: Palomino
PostPosted: Fri Apr 09, 2010 12:28 am    Post subject: Reply with quote
Shogimac,
I had a loose seat pedestal too. I overdrilled the bolt holes and jb welded them. There is a dead air space under the cabin floor. Shorter bolts go on the outside so you don't puncture the hull. That area drains the cuddy to the bronze outlet behind the seats. I considered rotating the pedestal to find solid floor to bolt into but found a cooler with cushion worked well and gave me the option of more cabin room when wanted.
I really enjoy reading and viewing your travels in Alaska!
JT Cool
Navanax
Vessel Name: Red Snapper
PostPosted: Fri Apr 09, 2010 12:35 am    Post subject: Reply with quote
Thanks for the question and response. Believe it or not I was headed to the boat shelter to replace the old post on my 16'angler and saw this. Perfect! I found what looks to be a good fit at fisheriessupply.com in Seattle. But simply using a cooler and foam may be an even better idea.
dotnmarty
City/Region: Sammamish
Vessel Name: LIZZIE II
Photos: Lizzie
PostPosted: Fri Apr 09, 2010 6:46 am    Post subject: Reply with quote
As long as you're considering alternatives, here's what Pat Anderson did on Crabby Lou
MartyP
Page generation time: 0.0626s (PHP: 24% - SQL: 76%) - SQL queries: 17 - GZIP disabled - Debug on
