Help! I found a 1" dia. spot under the brass keel guard
mcolp
City/Region: Colorado Springs
Vessel Name: Allyson Marie
Photos: Allyson Marie
PostPosted: Thu Apr 01, 2010 6:08 pm    Post subject: Help! I found a 1" dia. spot under the brass keel guard Reply with quote
Hello All, I need your help on this one!
I found a spot under the brass keel guard today while I went to check out the boat at the storage lot today. (See last 2 photos in my album today)
When I probed the area with an ice pick it was hard as a rock but the discolored area was definitely below the surrounding gelcoat approx. .025-.030"
The Brass keel guard was not damaged and appeared to be bedded in 5200 or
something similar. No gaps were present between the keel guard and the
area in question. Any Ideas out there?
Thanks!
Mike
Question
PostPosted: Thu Apr 01, 2010 6:23 pm    Post subject: Reply with quote
Someone with more knowledge about boat building can explain better, but I believe that spot is part of the process used to pop the hull out of the mold. Not a problem although they sure did a poor job of cosmetic work. The spot is there on all hulls but usually they cover it with well blended gelcoat. No worries as long as you don't look at it.
mcolp
PostPosted: Thu Apr 01, 2010 8:34 pm    Post subject: Reply with quote
Tyboo Mike,
Thanks for your info!. Now that I think about it, the fact that the area in question appears to be perfectly circular and symmetrical with the keel guard makes sense
as the most probable reason. If I had not looked under the boat, I would not have
seen it. (Out of sight, Out of Mind)
Mike
DAVEY
City/Region: Nanoose Bay
Vessel Name: na
PostPosted: Fri Apr 02, 2010 10:19 am    Post subject: Reply with quote
I bought a 16' cruiser last summer and I have the same circle on my hull,I would think that it is part of the moulding process.
Davey Cool
Casey
City/Region: The Villages(FL)
Vessel Name: "Dessert 1st"
Photos: Dessert 1st
PostPosted: Fri Apr 02, 2010 4:53 pm    Post subject: Reply with quote
Shhh ... that's the C-Dory's navel.
DaveS
City/Region: Arlington
Vessel Name: Sea Shift
Photos: Sea Shift
PostPosted: Fri Apr 02, 2010 5:09 pm    Post subject: Reply with quote
I can't wait to tell my wife that we own a Naval Vessel! Rolling Eyes
(That in itself should permit us to moor up to the USS Abraham Lincoln in Everett.... Thumbs Up )
Dave S.
"Sea Shift"
C-Brat #16
PostPosted: Fri Apr 02, 2010 5:12 pm    Post subject: Reply with quote
There is no reason that such a defect should appear (agree that it is primarily cosmetic. It is possible that C Dory has used water pressure to pop the hulls out of the mold (a common practice) , and this is where the water fitting is in the mold.
Larry H
City/Region: Tulalip,
C-Dory Year: 1991
Photos: Nancy H
PostPosted: Fri Apr 02, 2010 5:29 pm    Post subject: Reply with quote
If I recall correctly, that circle is where there was a steel plunger in the mold.
That plunger was used to 'pop' the hull out of the mold. They may also have used water pressure to assist the removal.
Seems to me that there was a thread here about this.
Larry H
A C-Brat since Nov 1, 2003
PostPosted: Fri Apr 02, 2010 7:16 pm    Post subject: Reply with quote
Dave - when are you going to tie up to the USS Abraham Lincoln? I'd like to be there to photograph the attempt. Laughing
(from a distance of course).
PostPosted: Sat Apr 03, 2010 1:03 am    Post subject: Reply with quote
Here ya' go................Pick one!
FREE TIE UP & BERTH
See ya' in 50 years!
Joe. Laughing Thumbs Up
Page generation time: 0.06s (PHP: 51% - SQL: 49%) - SQL queries: 23 - GZIP disabled - Debug on
