Will Batteries Freeze
POSSUMGAS
City/Region: virginia beach
Vessel Name: HUNKEY DORY
Photos: HUNKEY DORY
PostPosted: Tue Jan 26, 2010 6:50 pm    Post subject: Will Batteries Freeze Reply with quote
I keep my 22 Cruiser in dry storage. I would like to know if my batteries will freeze. We have had several days of below 32 temps. The boat is in a boatel. Question
Alok
City/Region: League City
State or Province: TX
Photos: Top Cat
PostPosted: Tue Jan 26, 2010 7:03 pm    Post subject: Reply with quote
Some useful information at these sites...
http://www.trojanbattery.com/Tech-Support/FAQ/Maintenance.aspx
http://www.cdtechno.com/custserv/pdf/7953.pdf
http://www.powerstream.com/Storage.htm
Alok
PostPosted: Tue Jan 26, 2010 7:13 pm    Post subject: Reply with quote
To quote from Trojan:
"Can a battery freeze?
The only way that a battery can freeze is if it is left in a state of partial or complete discharged. As the state of charge in a battery decreases, the electrolyte becomes more like water and the freezing temperature increases. The freezing temperature of the electrolyte in a fully charged battery is -92.0oF. At a 40% state of charge, electrolyte will freeze if the temperature reaches approximately 16.0oF."
T.R. Bauer
City/Region: Wasilla
Vessel Name: C-Whisperer
PostPosted: Tue Jan 26, 2010 9:18 pm    Post subject: Reply with quote
Not if they are fully charged....We'd know up here......
Levitation
City/Region: Hemlock
C-Dory Model: R-25 Tug
Vessel Name: CHARLOTTE ANN
PostPosted: Wed Jan 27, 2010 7:18 am    Post subject: Reply with quote
Visit the boatel every 4-6 weeks and throw a half hour charge on the battery set... You should lay eyes on the boat periodically, anyway
denny-o
denny-o
PostPosted: Wed Jan 27, 2010 8:07 am    Post subject: Reply with quote
I can vouch for the visits. Visited the Captain's Cat on the lift yesterday and found the port bilge pump running (dry). I had antifreeze in the bilge. Had to pull the fuse to get it to quit, will investigate in warmer weather. My batteries stay on the built in charger when on the lift, no problems so far.
matt_unique
City/Region: Boston
Vessel Name: Napoleon
Photos: Napoleon
PostPosted: Wed Jan 27, 2010 9:09 am    Post subject: Bilge Reply with quote
Well Charlie, you need to dig out your monkey arms and remove the pump from the housing to test the float switch. It's really easy to test once you snap it out of the housing. Maybe you got something stuck in there or it just needs to be replaced.
Good luck with that.
In terms of batteries, I find I get longer life out of them if I keep them somewhat warm during the winter. I refill with distilled water, charge them up, then store them in our heated basement.
Captain Matt
Page generation time: 0.0459s (PHP: 46% - SQL: 54%) - SQL queries: 20 - GZIP disabled - Debug on
