toyman
Joined: 11 Jan 2009 Posts: 556 City/Region: Lake Livingston
State or Province: TX
Vessel Name: Fan-C-Dory
Posted: Sat Dec 05, 2009 11:59 am Post subject: Honda 150 |
Can anyone tell me where the water pressure transmitter for the water pressure gage at the helm is located ? My gage doesn't work, yet there is plenty of flow from the pee hole.
TIA _________________ Dave W.
KE5GOH
Stuck in the 70's,
In East Texas |
Posted: Sat Dec 05, 2009 12:24 pm Post subject: |
There isn't a water pressure gauge on the dash of Journey On, which also has a 150. There is a pitot tube pick up at the bottom of the lower housing, but I'm not sure where it ends up on the dash, or what it does there. It would only indicate through-the-water speed, though.
There is an coolant overtemp sensor, which sounds an alarm and shuts the engine down, but no gauge there.
There's a fuel pressure gauge on the dash and someday I'd like to find out why it varies while the RPM's are steady.
I think the only water pressure gauge is the pee hole.
If you find out different, my apologies.
Boris |
Socrateur
Vessel Name: Sea Skipper
Photos: Sea Skipper
Posted: Sat Dec 05, 2009 5:42 pm Post subject: |
The water pressure gauge plug is located on the side of the thermostat housing which is at the top of the engine. The plug is directly below where the large water relief tube connects to the thermostat cover. Hope this helps.
 _________________ Capt Jay |
Posted: Sat Dec 05, 2009 5:54 pm Post subject: |
Well, I'll be darned. I don't have one and the 2005 shop manual doesn't show it.
Thanks for the info.
Boris |
Posted: Sat Dec 05, 2009 6:27 pm Post subject: |
I just looked at the dash of Journey On (again.) The gauge is labeled "Pressure" and I was told that it was a fuel pressure gauge, and it sort of acted like one. Can't find the sensor for that, either. Next step is to ask a Honda dealer.
Boris |
Alyssa Jean
Joined: 02 Nov 2003 Posts: 2376 City/Region: Guemes Is.(Anacortes)
Vessel Name: Alyssa Jean
Posted: Sat Dec 05, 2009 7:16 pm Post subject: |
At the top rear of the engine under the cover you will find a small 1/4" plastic tube that attaches to the engine via a brass fitting. I have had to take mine apart twice and clean out the accumulation of salt crystals. _________________ David and Kate
Alyssa Jean 16 Angler
K7KJR C-Brats #51 |
Socrateur
Photos: Sea Skipper
Have you looked in the manual on page 8-1? Chapter 8: Thermostats/Relief Valve/Flush Valve. Page one identifies the 1/8 BPT Water Pressure Gauge Plug in my manual. |
Dreamer
Joined: 01 Jan 2006 Posts: 1766 City/Region: Really Sunny SaddleBrooke
Photos: Dreamer
Posted: Sat Dec 05, 2009 7:22 pm Post subject: |
Toyman,
Here's the line and fitting. More photos in my maintenance album. It's the brass fitting next to the temp. sender.
 _________________ Roger
Dreamer- Sold 25 Feb. 2013 |
