Honda 150
toyman
City/Region: Lake Livingston
State or Province: TX
Vessel Name: Fan-C-Dory
PostPosted: Sat Dec 05, 2009 11:59 am    Post subject: Honda 150 Reply with quote
Can anyone tell me where the water pressure transmitter for the water pressure gage at the helm is located ? My gage doesn't work, yet there is plenty of flow from the pee hole.
TIA
Dave W.
KE5GOH
Stuck in the 70's,
In East Texas
PostPosted: Sat Dec 05, 2009 12:24 pm    Post subject: Reply with quote
There isn't a water pressure gauge on the dash of Journey On, which also has a 150. There is a pitot tube pick up at the bottom of the lower housing, but I'm not sure where it ends up on the dash, or what it does there. It would only indicate through-the-water speed, though.
There is an coolant overtemp sensor, which sounds an alarm and shuts the engine down, but no gauge there.
There's a fuel pressure gauge on the dash and someday I'd like to find out why it varies while the RPM's are steady.
I think the only water pressure gauge is the pee hole.
If you find out different, my apologies.
Socrateur
City/Region: Danville
Vessel Name: Sea Skipper
Photos: Sea Skipper
PostPosted: Sat Dec 05, 2009 5:42 pm    Post subject: Reply with quote
The water pressure gauge plug is located on the side of the thermostat housing which is at the top of the engine. The plug is directly below where the large water relief tube connects to the thermostat cover. Hope this helps.
Capt Jay
PostPosted: Sat Dec 05, 2009 5:54 pm    Post subject: Reply with quote
Well, I'll be darned. I don't have one and the 2005 shop manual doesn't show it.
Thanks for the info.
PostPosted: Sat Dec 05, 2009 6:27 pm    Post subject: Reply with quote
I just looked at the dash of Journey On (again.) The gauge is labeled "Pressure" and I was told that it was a fuel pressure gauge, and it sort of acted like one. Can't find the sensor for that, either. Next step is to ask a Honda dealer.
Alyssa Jean
Vessel Name: Alyssa Jean
PostPosted: Sat Dec 05, 2009 7:16 pm    Post subject: Reply with quote
At the top rear of the engine under the cover you will find a small 1/4" plastic tube that attaches to the engine via a brass fitting. I have had to take mine apart twice and clean out the accumulation of salt crystals.
David and Kate
Alyssa Jean 16 Angler
K7KJR C-Brats #51
Socrateur
Photos: Sea Skipper
Have you looked in the manual on page 8-1? Chapter 8: Thermostats/Relief Valve/Flush Valve. Page one identifies the 1/8 BPT Water Pressure Gauge Plug in my manual.
Dreamer
Photos: Dreamer
PostPosted: Sat Dec 05, 2009 7:22 pm    Post subject: Reply with quote
Toyman,
Here's the line and fitting. More photos in my maintenance album. It's the brass fitting next to the temp. sender.
Dreamer- Sold 25 Feb. 2013
Page generation time: 0.0366s (PHP: 69% - SQL: 31%) - SQL queries: 21 - GZIP disabled - Debug on
