CD 22 Wiper / Washer Mods
RichardW
City/Region: Huntsville
State or Province: AL
Vessel Name: C Eagle
Photos: C Eagle
PostPosted: Tue Sep 16, 2008 7:17 am    Post subject: CD 22 Wiper / Washer Mods Reply with quote
For those bugged by the CD wiper operation:
I finally got around to modifying the AFI 1000 wipers to eliminate the annoying run on problem of the factory setup.
I added a DPDT switch (ON-OFF-Momentary ON) for each wiper so that they can be controlled individually to run continuously or in a momentary mode to just give a swipe or two. The wipers park as soon as the switch is returned to the off (center) position.
The washer is designed to operate only when both switches are in the down (momentary position) so that the wipers run and the washer sprays.
The mounted switches and the electrical schematic are shown at the end of this album page:
http://www.c-brats.com/modules.php?set_albumName=album403&op=modload&name=gallery&file=index&include=view_album.php
Rolling Eyes
Richard and Cheryle Porter
breausaw
Vessel Name: Triple J
Photos: Triple J
PostPosted: Tue Sep 16, 2008 7:16 pm    Post subject: Reply with quote
Wow Richard, what a great mod! I was thinking of doing something similar with automotive accessories, but this approach is way nicer.
Is this an after-market marine product or did you just retrofit the system together from off-the-shelf components?
What I’ve thought of doing is adding intermittent wiper relays to each wiper switch that could be individually adjusted, and then adding a push-button windshield washer.
Boatless for now but looking
RichardW
Photos: C Eagle
PostPosted: Tue Sep 16, 2008 7:37 pm    Post subject: Reply with quote
Jay,
I designed this mod with off the shelf switches and an automotive washer system. I eliminated the need for a separate pushbutton switch for the washer by using the second pole of each DPDT switch wired in series. This means that both switches must be on in the momentary down position for the washer to operate. The wipers will operate in conjunction with the washer; which is what you need to happen.
I may add some photos when I get some time.
Richard
Doryman
Vessel Name: Lori Ann
Photos: Lori Ann
PostPosted: Tue Sep 16, 2008 11:31 pm    Post subject: Reply with quote
Hmmmm.....
RichardW is in Huntsville, AL and does cool mods like this.... Thumbs Up Thumbs Up
Wonder if he is an actual rocket scientist Question Question Question
Warren Laughing
Doryman
M/V Lori Ann
Anacortes, WA
Sea Angel
Photos: Sea Angel
PostPosted: Mon Oct 12, 2009 8:44 pm    Post subject: Reply with quote
RichardW;
Nice efficient use of space and logic. Well done Thumbs Up !
Have you had any issue with the wipers sweeping on a dry windshield till
the spray wets it?
Art
Art ka1rx
CBRAT #208
USCGAUX (RET), USN(RET)
Broadcast TV ENG(RET)
ka1rx@verizon.net
SKYPE: Art.Bartlett4
Jack in Alaska
C-Dory Model: 26 Pro Angler
Vessel Name: HIGH TIDE II
Photos: HIGH TIDE II
PostPosted: Tue Oct 13, 2009 1:54 am    Post subject: Reply with quote
Great set-up on your wipers. I had washers on my Classic but that is gone and now I need a better set-up on my new CD.
My wipers swing back and forth and only shut off when they are parallel. Otherwise they keep on swinging until they are parallel which sometimes takes 5-10 min.
Also how do you get the arms off of the knurled knob.?? It really needs the pantograph (sp???) type wipers.
No. CD026021I405; AK-5008-AK
MSSI No. 338143486(cancelled)
Stolen & stripped in Aug. 18
Page generation time: 0.0495s (PHP: 37% - SQL: 63%) - SQL queries: 20 - GZIP disabled - Debug on
