Remounting radar display unit
Lucky Day
City/Region: Churchton
State or Province: MD
Vessel Name: Lucky Day
Photos: Lucky Day
PostPosted: Sat Jul 11, 2009 12:02 pm    Post subject: Remounting radar display unit Reply with quote
The P.O. on my boat mounted the display module for the radar suspended from the underside of the electronics shelf. That's too far above the helsman's line of sight for me. I want to move it so that it will be mounted upright on the dash area over the entryway to the v-berth, between the compass and the starboard side of that surface. I tested it there and didn't see any interference with the compass or the radar display.
So - Any tips on whether to mount the unit with bolts that go through the surface and secure it with nuts from the v-berth side? Or mount it using wood type screws that don't fully penetrate the surface. How thick is that surface and - Is that area of the dash cored?
Thanks in advance for any info.
Doryman
Vessel Name: Lori Ann
Photos: Lori Ann
PostPosted: Sat Jul 11, 2009 12:41 pm    Post subject: Reply with quote
I have my displays mounted with RAM brackets and they work well.
Doryman
M/V Lori Ann
Anacortes, WA
Lucky Day
Photos: Lucky Day
PostPosted: Sat Jul 11, 2009 1:14 pm    Post subject: Reply with quote
Do the RAM mounts need to be attached with screws too? Or does your setup use suction cups?
marvin4239
Vessel Name: C-FLE II
Photos: C-FLE II
PostPosted: Sat Jul 11, 2009 1:24 pm    Post subject: Reply with quote
Don't know if this will work for you but I started a while back mounting things with industrial sticky back velcro if I wasn't sure if I'd like the location. The stuff holds so good in some cases it became permenant mounting hardware. I even mounted my helm seat with it plus compass, rear view mirror, cup holders, paper towel rack etc and no holes in my glass. I bought the stuff at Lowes in a big roll.
marvin
Lucky Day
Photos: Lucky Day
PostPosted: Sat Jul 11, 2009 2:36 pm    Post subject: Reply with quote
I will look into the industrial velcro. Sounds very promising. Still interested in knowing about fixed mounting, though, before going ahead.
Doryman
Photos: Lori Ann
PostPosted: Sat Jul 11, 2009 2:52 pm    Post subject: Reply with quote
No suction cups. I suspect that the leveraged weight of the Raymarine display would be too much for even industrial strength velcro to withstand -- but I do not know. My RAMs are bolted to the dash.
toyman
City/Region: Lake Livingston
State or Province: TX
Vessel Name: Fan-C-Dory
PostPosted: Sun Jul 12, 2009 5:43 pm    Post subject: Reply with quote
You don't mention what size your unit is, but the PO of my boat mounted the Garmin 4210 on the "dash" directly in front of the helm using thru bolts. I feel it interferes to much with my forward vision ( probably only perceived ) and as soon as I get home it will go in the fwd corner stbd side above the windows.
Dave W.
KE5GOH
Stuck in the 70's,
In East Texas
Doryman
Photos: Lori Ann
PostPosted: Sun Jul 12, 2009 5:55 pm    Post subject: Reply with quote
Dunno how old you are or what your vision is like, but when I first bought my Tom Cat I mounted an E-120 where you are talking about mounting your Garmin. I found it to be a (literal) pain in the neck to have to tilt my head far enough back so I could look at the display through the bifocal (bottom) portion of my glasses. Plus, and this may only be me, but I was uncomfortable/overwhelmed with that big screen only inches away from my head and eyes. I now have 2 E-80s, mounted on both sides of the opening forward window, and that has worked well for me. Makes it easier for the Admiral to see the port display, too. Sometimes too easy! Twisted Evil
Levity
City/Region: Shippensburg
Vessel Name: Levity
Photos: Levity
PostPosted: Sun Jul 12, 2009 6:09 pm    Post subject: Reply with quote
Levity's Garmin 4210 was mounted using aluminum flat stock shaped and positioned to place the unit in an optimum viewing position. Read the discussion in the following forum: "Electronic Garmin 4210 Plotter & GMR 18 HD", see the photos in Levity's photo album.
Mike "Levity"
Doryman
Photos: Lori Ann
PostPosted: Sun Jul 12, 2009 6:34 pm    Post subject: Reply with quote
Here is the LINK to that discussion.
The 22 has a different dash configuration than the Tom Cat -- I may move the C-80 on my 22.
Doryman
Photos: Lori Ann
PostPosted: Tue Jul 14, 2009 10:00 am    Post subject: Reply with quote
Check out the SeaSucker as a possible way to mount your display, as well as many other items on a boat.
matt_unique
City/Region: Boston
Vessel Name: Napoleon
Photos: Napoleon
PostPosted: Tue Jul 14, 2009 11:09 am    Post subject: Display Reply with quote
I know suction cups and velcro are tempting, but I would never trust them for such an expensive unit. Also, bashing through seas/bad weather would be a bad time for the unit to fall on the floor, which is when it is most likely to happen with anything other than a solid mount Shocked
I too fix mounted my 10" Furuno display eye level with helm gauges, to the left of the helm. (You can see pics in my photo album).
There are a lot of creative installs done by C-Brat's though, scan through the albums to see what idea you like best.
Good luck.
Captain Matt
Doryman
Photos: Lori Ann
PostPosted: Tue Jul 14, 2009 11:46 am    Post subject: Reply with quote
Matt, according to SeaSucker, their product is much more than a suction cup and can hold 200#+ -- read their FAQ for more details. You have a visual display that lets you know vacuum needs to be pumped up, etc. It might be useful for testing different locations before settling on a permanent one. I would probably not use it for a permanent mount, though, if only because it makes no sense to tie up the cost of a SeaSucker in a permanent installation.
Lucky Day
Photos: Lucky Day
PostPosted: Tue Jul 14, 2009 1:58 pm    Post subject: Reply with quote
Great to have all these responses. If I go with a fixed mount, that brings me back to the original question regarding the dash/shelf area directly over the v-berth entrance on a CD-25:
"Any tips on whether to mount the unit with bolts that go through the surface and secure it with nuts from the v-berth side? Or mount it using wood type screws that don't fully penetrate the surface. How thick is that surface and - Is that area of the dash cored?"
Thanks.
Wandering Sagebrush
City/Region: Northeast Oregon
Vessel Name: Constant Craving
Photos: Constant Craving
PostPosted: Tue Jul 14, 2009 2:44 pm    Post subject: Mounting Reply with quote
I was skeptical of using a RAM mount for something as heavy as a C80, but I just got back from my favorite toy store (Fisherman's Marine) and saw a C80 mounted vertically on the large diameter RAM. It was very secure and steady. That was a bit of a surprise.
Kind Regards,
Steve
Page generation time: 0.0524s (PHP: 62% - SQL: 38%) - SQL queries: 28 - GZIP disabled - Debug on
