hank schneider
Joined: 23 Mar 2008 Posts: 123 City/Region: blowing rock
Vessel Name: Ditch Witch
Photos: Ditch Witch
Posted: Thu Apr 02, 2009 3:55 pm Post subject: Kicker on a CC 23 L or R |
Hello
My kicker will be here tomorrow and I assume I will need to pull one of the swim platforms. I"m thinking about mounting to the right of the engine because of all the cables & lines there - leaving the left for back access and entrance. Any advice or warnings?
Thanks
Hank |
Joined: 02 Nov 2003 Posts: 8556 City/Region: Birch Bay, WA
Posted: Thu Apr 02, 2009 7:17 pm Post subject: Re: Kicker on a CC 23 L or R |
Aye, Matey - give us port or starboard, because "left" and "right" depend on whether you are looking fore or aft! hank schneider wrote: | Hello
Thanks
Hank |
hank schneider
Photos: Ditch Witch
Posted: Fri Apr 03, 2009 7:42 am Post subject: Starbord |
Got it - keep worring that I will reverse them
I was referring to starboard.
One more Q
Is there a reasonable way to connect the kicker to the fuel supply line as well as a tank
(not at the same time)
Thanks
H |
NewMoon
C-Dory Year: 1991
Vessel Name: Cindy Sea
Photos: Cindy Sea
Posted: Fri Apr 03, 2009 9:18 am Post subject: |
This looks like the same valve used to select between the port and starboard tanks on my CD-22!
NewMoon
C-Dory Year: 1991
Photos: Cindy Sea
Posted: Fri Apr 03, 2009 9:50 am Post subject: |
Senior moment - memory fades over the 11 years since our CD moved on to another home. We had considered adding another switching valve, but did it with a brass T and two tubes instead. |
jennykatz
Vessel Name: Little Treasurer
Photos: Jennykatz
Posted: Fri Apr 03, 2009 10:51 pm Post subject: kicker monting |
HI Hank are you going to use the swim step and just mount a L bracket on the swim step then through bolt it and then you still can use the swim platform . WM sells them look up trolling motor's and mounts in their catolog .I've been thinking about a kicker also what size did you end up with ? let me know how it performs thanks jim _________________ retired 8/08 from UAL, still working pt tm
hank schneider
Photos: Ditch Witch
Posted: Sat Apr 04, 2009 8:11 am Post subject: valve |
DUH
That is the valve I have with one position plugged. Easy
Hank |
