Kicker on a CC 23 L or R
hank schneider
City/Region: blowing rock
Vessel Name: Ditch Witch
Photos: Ditch Witch
PostPosted: Thu Apr 02, 2009 3:55 pm    Post subject: Kicker on a CC 23 L or R Reply with quote
Hello
My kicker will be here tomorrow and I assume I will need to pull one of the swim platforms. I"m thinking about mounting to the right of the engine because of all the cables & lines there - leaving the left for back access and entrance. Any advice or warnings?
Hank
PostPosted: Thu Apr 02, 2009 7:17 pm    Post subject: Re: Kicker on a CC 23 L or R Reply with quote
Aye, Matey - give us port or starboard, because "left" and "right" depend on whether you are looking fore or aft!
hank schneider wrote:
Hello
Hank
hank schneider
Photos: Ditch Witch
PostPosted: Fri Apr 03, 2009 7:42 am    Post subject: Starbord Reply with quote
Got it - keep worring that I will reverse them
I was referring to starboard.
One more Q
Is there a reasonable way to connect the kicker to the fuel supply line as well as a tank
(not at the same time)
H
NewMoon
City/Region: Holladay
C-Dory Year: 1991
Vessel Name: Cindy Sea
Photos: Cindy Sea
PostPosted: Fri Apr 03, 2009 8:01 am    Post subject: Reply with quote
We rigged our CD22 with this valve:
http://www.discountmarinesupplies.com/Fuel_Valves-SEACHOICE_THREE_WAY_FUEL_VALVE.html
Richard Cook
"Cruising in a Big Way"
PostPosted: Fri Apr 03, 2009 9:18 am    Post subject: Reply with quote
This looks like the same valve used to select between the port and starboard tanks on my CD-22!
NewMoon
C-Dory Year: 1991
Photos: Cindy Sea
PostPosted: Fri Apr 03, 2009 9:50 am    Post subject: Reply with quote
Senior moment - memory fades over the 11 years since our CD moved on to another home. We had considered adding another switching valve, but did it with a brass T and two tubes instead.
jennykatz
City/Region: naples
Vessel Name: Little Treasurer
Photos: Jennykatz
PostPosted: Fri Apr 03, 2009 10:51 pm    Post subject: kicker monting Reply with quote
HI Hank are you going to use the swim step and just mount a L bracket on the swim step then through bolt it and then you still can use the swim platform . WM sells them look up trolling motor's and mounts in their catolog .I've been thinking about a kicker also what size did you end up with ? let me know how it performs thanks jim
hank schneider
Photos: Ditch Witch
PostPosted: Sat Apr 04, 2009 8:11 am    Post subject: valve Reply with quote
DUH
That is the valve I have with one position plugged. Easy
Hank
Page generation time: 0.0478s (PHP: 63% - SQL: 37%) - SQL queries: 25 - GZIP disabled - Debug on
