EdenPURE GEN3 Quartz Infrared Portable Heaters
eNORMous
City/Region: Beaufort
Vessel Name: Antibody
Photos: Antibody
PostPosted: Wed Nov 26, 2008 12:21 pm    Post subject: EdenPURE GEN3 Quartz Infrared Portable Heaters Reply with quote
I've been researching heaters for my 25' Cruiser. I didn't see anyone on the C-Brats site who owned one of these EdenPURE Quartz Infrared Portable Heaters and thought I'd share what I found. They look very reasonable and very safe (infrared) - requiring only 7.5Amps/900Watts yielding a rating of 2300 BTU, heat up to 300 square feet, quite small (14.25"H x 11.5"W x 13.75"D), and are apparently very economical.
Anyways, thought I'd pass this along. They have two models. If anyone has one in their home, it would be nice to hear how they like.
http://www.biotechresearch.com/edenpure/edenpure-gen3-model-500-quartz-infrared-portable-heater.html
I am what I am & that's all that I am & there ain't no more.
E Pluribus Normus
PLB Beacon ID: 2DCE5DE29CFFBFF
Dene
City/Region: Kalama
Vessel Name: Fear Naut & Terra-Sea-Ta
PostPosted: Wed Nov 26, 2008 1:26 pm    Post subject: Reply with quote
I really like quartz heaters. I've bought three so far...two for boats and one for an RV. The Optima one has 400 and 800 watt settings. The 800 setting will quickly heat up a cabin and the 400w maintains it. We had it on that setting all night in our RV last weekend. 35 degrees outside. 65 inside. Regardless which brand you choose, you'll appreciate how efficient and silent they are.
-Greg
Doryman
Vessel Name: Lori Ann
Photos: Lori Ann
PostPosted: Wed Nov 26, 2008 2:03 pm    Post subject: Reply with quote
$297 for a heater is a bit steep for me. Greg, where did you get the Optima? I was not able to Google one...
Doryman
M/V Lori Ann
Anacortes, WA
PostPosted: Wed Nov 26, 2008 3:02 pm    Post subject: Reply with quote
eNORMous-
I don't have one of these, but will offer a few ideas:
1.) $300 for a small electric heater is at least $200 too much. A decent electric heater can be had for $100 or less, probably half as much, or $50.
2.) Watts is Watts, amperage is amperage, heat is heat. Whatever you put into a heater in amperage (amount of current flow) or watts (amount of power over time), comes out as heat, either as radiant energy and/or a rise in air temperature. All electrical energy is converted to one or the other of these forms of energy (or a combination of the two).
No heater can make more energy or heat out of a given amount of electricity than there is in what comes down the cord in amperage, voltage, and watts. Even the energy generated in the motor (if it has one) and heat lost in the cord of the appliance, turns of as some form of heat energy. These ideas are derivatives of fundamental laws of physics. Part of their advertising claims about this heater are simply not true. Read what I have written below, then re-read their ad!
3.) Heater history 101:
Early electric heaters simply had hot coils and radiated heat as infared heat wave energy.
Later, blower motors were added to help convert radiant and molecular energy of the hot coils to hot air, and blow this hot air around the room.
As time went on, two speed blowers with two heat level settings were developed, then thermostats were added for regulatory convenience. Some space heaters were also designed to oscillate back and forth to distribute the heated air better. Now we also have digital controls and timers.
Heaters can still be divided into radiant heaters and space (room) heaters, or a combination of the two.
Newer developments include:
Ceramic heating elements where the metal coils or elements are buried in a ceramic matrix (looks like a radiator heat exchanger) to lower the temperature of what were before exposed hot coils of wire. This lowers the fire danger by lowering the temperature of the heating element.
Quartz heating elements wrap the hot wire coils around a ceramic rod, then enclose that with a quartz glass tube. This makes a great radiant heater, and also provides protection from having a red-hot radiant heating coil in contact with the air. This lowers the fire potential., while still making a radiant type heater possible.
You can understand what a danger any hot heating element poses on a boat, particularly considering the possibility contact with gas, propane, or diesel fumes.
Space heaters are best suited to enclosed spaces, whereas...
Radiant heaters are better suited to open spaces where the entire space or room is too large to entirely heat up, thus the radiant heater can heat a workspace or sleeping space directly w/o wasting heat on the whole warehouse, etc.
Radiant heaters have the advantage of being able to heat up quickly and provide warmth without the lag of a space heater, which has to heat the entire space up gradually.
Again, remember that some heater types are actually combinations of these two types of heaters, providing both radiant heat directly and moving air to warm up space.
Now some more considerations.
Good heaters can be had for from $50-$100, and much less in the Springtime when stores close out their Winter seasonal merchandise.
The $100-$500 heater won't make any more heat than the $50 heater. The more expensive ones may circulate the air somewhat better, have more convenient controls, look prettier, etc., but you get the all the heat you pay for from the electric company, no more, no less.
I'd recommend you get a two speed / heat level heater with a low enough setting that you can run it on a generator conveniently. Also, a thermostatically controlled one makes a lot of sense when sleeping in a boat.
Heaters are designed with a maximum draw of about 1600-1700 watts total because they are usually plugged into a 15 amp circuit that can only provide 1800 watts without tripping the circuit breaker.
A Honda 2000i generator should be worked at no more than about 1600-1700 watts, which makes them able to handle most room heaters.
A Honda 1000i generator can be worked at 750 watts continuously, thus you need a heater that has a half-level setting within this range if you have this type of generator. If you have some other brand or level of generator, find out what level it can be worked at continuously and get an appropriate heater.
Another idea; I like a low lying heater, not a tall one. (Have dog or young child on board?) The flatter, more horizontal body is harder to accidently turn over in a boat than a tall one. All modern heaters have an automatic switch in them which will turn them off if they are turned some way other than upright. I'd find one that fits somewhere conveniently in a space once I have the boat set up for sleeping as well as when awake. Mine fits in the footwell under the helm, where it can be run during the day or at night. Also dries out wet feet, shoes, and socks!
Another thought: a 12 volt electric blanket can be a very viable alternative to staying warm when sleeping.
120 volt heaters must run off Shore Power or a generator. They can be run through a suitably large inverter, but the battery power needed is too great for most boat battery systems. Witness:
A 750 Watt heater will draw 6.25 amps at 120 volts. At 12 volts, the inverter must draw 62.5 amps to provide that 750 Watts, plus some more for its own inefficiency/heat loss. An 110 Amp-hour group 27 battery can provide that ~70 amp draw for less than 1/2 hour w/o damaging the battery, so battery power for these types of heaters is impractical.
So, in short, I think you may have a good heater there, but it's well over priced and a good part of the selling points are not scientifically valid.
Sorry for the lecture. Old Physics and Chemistry teachers have a hard time finding a suitable target audience sometimes!
P.S.: Too bad there isn't room for an electric simulated fireplace in a boat!
An alternative might be the Dickinson Propane Fireplace:, although it's even more expensive and some folks won't like the propane heat source because of the perceived danger, etc.
Happy Thanksgiving!
PostPosted: Wed Nov 26, 2008 3:51 pm    Post subject: Reply with quote
To make it short and simple:
1. That heater is only changing electrical energy into heat energy. It DOES NOT create energy.
2. 900 watts is the same as 3071 BTU. THE SAME, just different units.
3. You're spending $300 for an electric heater that is worth $45, since the power in = heat out for ANY electric heater.
4. Whoever is selling those heaters is doing one heck of a job.
eNORMous
Photos: Antibody
PostPosted: Wed Nov 26, 2008 3:59 pm    Post subject: Reply with quote
I'll research further (as I'm off to the airport for the holidays). A couple thoughts though:
1) No heater makes energy - none, period. Heat is always lost as a result of transfer (unless you want to discuss atomic fusion). Mr. Green
2) I've been researching the parts contained in each of the units as well - since (it only makes sense) plastic and galvanized far outlast non-galvanized, and the parts contained in our home air conditioner (Trane) is not made for the midwest United States - it's made for a salt-water environment with brass and stainless as opposed to other materials - including the fan bearings, blades, etc. So, there is some consideration of researching the actual materials employed for the parts of these units, as well.
I'll continure to research, but I'm not looking for a pretty unit and thanks for the suggestions.
Norm
lloyds
City/Region: sublimity
Vessel Name: undecided
PostPosted: Wed Nov 26, 2008 4:16 pm    Post subject: Reply with quote
I just bought a Holmes last night, a ceramic model, for $17, marked down from $21 at Walmart. My last one lasted about 10 years on a boat, and it was about $100 back then. Amazing how cheap you can get this stuff for. The box it came in would cost me $4 at postal connections.
PostPosted: Wed Nov 26, 2008 5:40 pm    Post subject: Reply with quote
As long as we're comparing costs, I've bought good heaters for $15-$30 at stores during the Spring sell-off.
The last three were Sunbeam units, with dual speeds, oscillating fan output, digital controls and read-outs, and remote wireless controls as well, for just over $30 each.
Other simpler ones, have cost as little as $15-$20.
I've also bought heaters at garage and moving sales, including ceramic ones for $5-$15 that do everthing necessary.
On my CD-22 Cruiser, I've never had to use it more than on the low setting. It usually cycles on and off, as necessary.
The same size heater will heat my Sea Ray 265 Sedan Bridge running continuously on low, even though it has about four times the interior volume of the C-Dory. The difference is insulation: headliner, upholstered and padded seats and walls (just like the sanitarium, including Sea Foam green walls), drapes, Venetian blinds, carpets, window covers, weather stripping, etc.
I think you could cut the heat requirements down by 1/3 to 1/2 by fully insulating a C-Dory, including B~C Ken's Pain Free Spray on Insulation Solution.
Or you could buy a new C-Dory Venture 23 or a Skagit Orca 24, with most of the insulation already in place. (Many other brands omitted*, of course!)
Or maybe "omsmitted", whatever you think!
CAVU
City/Region: Spokane
Vessel Name: CAVU
Photos: CAVU
PostPosted: Wed Nov 26, 2008 10:24 pm    Post subject: Reply with quote
Joe,
I have recently shopped for small portable heaters. Apparently the rules about tip-over switches have changed. They all now have a safety overheat switch (thermal breaker) but only a few of the very high end models have a tip over safety switch. Last time I bought a heater they all had a tip-over switch.
Ken Trease
22 CD Cruiser, CAVU
Twin 40HP Hondas
PostPosted: Thu Nov 27, 2008 12:22 am    Post subject: Reply with quote
CAVU wrote:
Joe,
Ken-
Thanks for the new information!
Didn't know about the changes.
A tip-over switch is something to really want in a boat heater, IMHO.
The much older models don't have them either!
Thanks!
Dene
City/Region: Kalama
PostPosted: Thu Nov 27, 2008 1:31 am    Post subject: Reply with quote
I got it through Amazon. It's an Optimus and it sells for $29. It does have a tip-over safety feature and it's low to the ground. The height is equal to that of a typical step.
Very dry heat. I love not having to dry the windows while underway.
-Greg
PostPosted: Thu Nov 27, 2008 1:45 am    Post subject: Reply with quote
-Greg
Is this the one?
Optimus H-5210 Infrared Quartz Radiant Heater
Looks nice. You may want to read the Reviews
I think I'd prefer a heater with a fan to help circulate heat into the v-berth and pick up cold air from the floor and warm it, making the cabin have a more uniform temperature.
Not For Hire
City/Region: Cadillac, MI
Vessel Name: Not For Hire
Photos: Not For Hire
PostPosted: Thu Nov 27, 2008 8:45 am    Post subject: Reply with quote
I use a small electric heater when on shore power. (I have a Wallas 1300 for when underway or on the hook). Tried a nifty $85 dollar model but it wasn't as good as the $15 walmart style model although it was more compact. Both of these models have a thermostat. But the thermostat shuts off the fan and the heater, thus stopping air circulation and, more importantly, stopping the white noise of the fan. I would like a small electric heater where, when on the heat setting, the fan stayed on and only the heating element turned on and off by thermostat. Anyone know of such a model?
Regards, Mark
Mark S
Cadillac, Michigan
Dene
City/Region: Kalama
PostPosted: Thu Nov 27, 2008 1:22 pm    Post subject: Reply with quote
That's the one Joe. I didn't notice any disparity of temperature when we used it in the boats or RV. We placed it on the 400w setting overnight and it did fine. I prefer a cooler V-berth. Also, I get annoyed with the cycling of the Aspar or ceramic heater.
I did read the reviews and they are correct about the temp knob being difficult to read. However, we just used a permanent market to help us see the indicator. Beyond that, no complaints, which is why we bought one, tried it, then bought two more.
Hope you find what you're looking for.
-Greg
Doryman
Photos: Lori Ann
PostPosted: Thu Nov 27, 2008 1:33 pm    Post subject: Reply with quote
Sea Wolf wrote:
Is this the one?
What attracted me to this heater was that it could run at 400 watts, which is much lower than the usual 750/1500 watt space heater. That could be important running off the inverter. Obviously, not for long, but to take the chill off the cabin before the Wallas gets going it might be perfect.
Page generation time: 0.0556s (PHP: 71% - SQL: 29%) - SQL queries: 28 - GZIP disabled - Debug on
