Honda's new Generator
T.R. Bauer
City/Region: Wasilla
Vessel Name: C-Whisperer
PostPosted: Tue Feb 15, 2022 8:26 am    Post subject: Reply with quote
I sure would think so - that's a lot of power and I have heard from the RV folks the 2200 runs an AC unit reliably depending on the factors. Some AC units, like the one on top of my RV, have a big capacitor to help with start up energy requirements. Mine has a second one for the fan as well. Anyway, it hardly even pulls a 4k genset down on startup while running a litany of other loads.
Salmon Fisher
City/Region: Arlington
Vessel Name: Kim Christine
Photos: Kim Christine
PostPosted: Tue Feb 15, 2022 12:40 pm    Post subject: Reply with quote
Here is a link to what you need for your AC:
https://www.microair.net/products/easystart-364-3-ton-single-phase-soft-starter-for-air-conditioners
Patrick and Kim Walker
2004 25 Cruiser-Present
1985 22 Classic -2019 (Sold)
PostPosted: Tue Feb 15, 2022 5:52 pm    Post subject: Reply with quote
cdory25 wrote:
But will it run my roof top air conditioner?
There is a pretty good chance that the 2200 Honda will run you roof top RV air conditioner, if you put an EasyStart kit on the Air Conditioner. (Cost about $300.). This avoids full locked rotor amps at initial start up. No question with the EasyStart, the new 3200 Honda would run it.
Foggy
C-Dory Year: 2014
Photos: W B Nod
PostPosted: Wed Feb 16, 2022 6:41 pm    Post subject: Reply with quote
What about the new Li ion battery inverters (Yeti Goal Zero, Bluetti, etc);
lighter in weight, shore power (120V) rechargeable, solar rechargeable,
car chargeable (auto is DC, OB engine is DC) and seem to be ideal for
marine use avoiding hazards of gas/propane?
It's said "Lithium is the new gasoline". Consider environment, pollution...
If you're insecure, you can even carry along one of those little outdated
Honda dual (gas/LPG) fuel chargers for a quick recharge, or, just to make
you feel better.
Aye.
PostPosted: Wed Feb 16, 2022 7:29 pm    Post subject: Reply with quote
Foggy wrote:
...It's said "Lithium is the new gasoline". Consider environment, pollution...
Gasoline still has about 100 times the energy density of lithium batteries.
If you add in the energy requirements and carbon cost of actually mining the lithium and manufacturing the battery, are you actually ahead if you use a Li battery?
Only immediate advantage is that you move the source of the pollution (electric generating plant) somewhere away from the end user if you are using a battery vs. a generator (if you have access to shore power to charge the battery). It is possible that some or all of the energy used to charge you Li battery comes from renewable sources.
PostPosted: Wed Feb 16, 2022 9:50 pm    Post subject: Reply with quote
You would have to have a mighty big "inverter generator" to power an air conditioner. Every once in a while we have a C brat show up at a gathering, with his new "solar charger"--it is not even enough to run a refrigerator for 24 hours. In the real world of powering items, these are basically toys for people who have very low loads.
To run a RV roof air conditioner for 9200 to 13,000 BTU would for 8 hours at night would require a bank of about 500 amp hours usable. I did this with golf cart batteries in about 2002 for an express cruiser with a 5000 BTU Water cooled 120 V AC air conditioner. The 400 amp hour battery bank (Golf carts) would run bout 4 hours before it was "out of juice".
We are not there yet. Even though I had a 5,000 BTU air conditioner in the C Dory 25, with usable 200 amp hours of usable Li battery power, and a 2000 watt PSW inverter, I would not consider running the air conditioner on it.
robhwa
City/Region: Anderson Island
Vessel Name: Marcia C
Photos: Problemadela
PostPosted: Thu Feb 17, 2022 8:16 am    Post subject: Reply with quote
The only "modest-sized" unit I've seen that is capable of sufficient overnight air conditioning is the one used in the Storyteller compact RV, based on the small Sprinter van.
https://1rm4pw3qup7umqlqkbggk81c-wpengine.netdna-ssl.com/wp-content/uploads/2020/08/Battery-Pack-Data-Sheet_8.28.20.pdf
Various units are available, but the Storyteller is usually outfitted with about 12 KW hours. About 350 lbs. All proprietary.
You could create the equivalent with LiFePO4 batteries and a large inverter, but after you depleted the cells with 8 hours or so of use overnight, how would you recharge them with outboard motors? At 35 watts for the new Honda 90 that would be 400 hours or so of running the motor for one night of air-conditioning. Even 1000 watts of solar won't completely do it under perfect conditions, and where would those panels fit on a C-Dory? The Storyteller Van has a second alternator that charges at 8000 watts, full output only >2500 RPM. Yes, we certainly aren't there with battery-powered air-conditioning for a C-Dory. Gasoline still holds an awful lot of energy in a compact form. Damn how that math constantly limits my hopes and dreams.
We looked at a Storyteller (and a Winnebago Revel) earlier, but towing wasn't great in case we wanted a 25 or Tomcat later, seating was limited, it'd be hard to get canoes and kayaks on top, and it cost about $200,000. Gas mileage wasn't that great either, similar to a 3/4 or 1 ton diesel truck. We opted for a truck and a pop-up camper.
robhwa
PostPosted: Thu Feb 17, 2022 11:58 am    Post subject: Reply with quote
…Honda 90 is about 35 AMPS, not watts, so figure more like 1/12 400 hours. Still a lot of motoring.
Foggy
C-Dory Year: 2014
Photos: W B Nod
PostPosted: Thu Feb 17, 2022 12:23 pm    Post subject: Reply with quote
Seems a Yeti Goal Zero 3000X would work for some. Then there's the 6000X, at
36 lbs heavier but with about 2X the below stats on run/charge time.
Want more juice, add Li ion batteries; lighter than lead-acid and pricier.
www.goalzero.com
Capacity: 3032 Wh (10.8V, 280.8 Ah)
Wt: 69.78 lbs
400W solar charge time: 9 - 18 hrs
Hours of Runtime
Light-a-Life 350 (4.5 W): 674
Light Bulb (11 W): 276
CPAP (65 W): 47
TV (42" LED) (100 W): 31
Pellet Grill (60 W): 51
Microwave (1000 W): 3
Portable Fridge (25 W): 122
WiFi Router (25 W): 122
Mini Fridge (35 W): 87
Full Size Refrigerator (66 W): 46
Circular Saw (13 Amp) (1500 W): 2
Aye.
I have zero vested interest in this company.
jkidd
City/Region: Northern, Utah
Vessel Name: Voyager
Photos: Voyager (JK)
PostPosted: Thu Feb 17, 2022 3:17 pm    Post subject: Reply with quote
www.goalzero.com
Wt: 69.78 lbs
Hours of Runtime
CPAP (65 W): 47
Aye.
I use a Yeti 1000 in my boat and yes it can run a lot of things and the bigger ones can run even more. The problem is if you use up the capacity in a day you can not reliably put that capacity back with solar in 1 day. Most of the time I can put back what I use the next day cruising around for a few hours. This generator will meet the new emission standards that are being set. It's weight is even with the Yeti 3000. It doesn't need to be charged just add gas. My outboard runs on gas so I already have it on board.
Jody Kidd
KE7WNG
Northern, Utah
Looking at the list that foggy provided--the closest to the RV roof air conditioner is the circular saw--and that gets 2 hours of run time. So you would need 4X that capacity for overnight.
Although LiFePO4 batteries are apparently more expensive--that does not hold up iv you want to keep the the battery unit for 10 years. Although 1/2 the weight of FLA batteries, the weight adds up quickly in either an RV or boat.
Our current RV is on a sprinter 3500 chassis-(One ton), we have towed a 4300# car a number of thousands of miles. I would say that is about the size limit as what I would want to tow. We are going to tow our Caracal cat to Hontoon, so we will see how that works behind the Sprinter. We had a Road Trek one ton with "towing capacity" of 6800 lbs listed. We towing the first 25 fir short distances. That was marginal. There is no way I would even consider a C dory 25 behind a sprinter chassis.
In our rv, we have a 3500 watt Onan diesel generator--that is fine for the most of our challenges with power--such as the 15000 BTU roof air. Some owners have gone to 2 100 amp hours batteries. The sprinters have 200 amp output LN alternators--but there is danger of these overheating, so they are limited in run time to less than 50 when charging the Li battery bank.
No free lunch here.
Bob
jkidd
PostPosted: Mon Sep 19, 2022 6:56 pm    Post subject: Reply with quote
There here, on the box it says not for sale in California.
PostPosted: Mon Sep 19, 2022 7:15 pm    Post subject: Reply with quote
It certainly is a game changer! It does not seem to have a fuel shut off, like the 2200 has--that was great to run the fuel out of the carb--but with injectors it may not be necessary.
At $2600, it is more expensive than 2 of the 2200 units. ($1200 each). It will be interesting to see if any of the cheaper competitors come out with a similar model
The 2200 are: AC Output 120V 2200W max. (18.3A), 1800W rated (15A).
Looking a little further it has a 1.2 gallon tank, and has A C Output 120V 3200W max. (26.7A), 2600W rated (21.7A).
Looking at the specs, two of the 2200s give you a true 30 amp steady running power. The single 3200 only gives 21.7 amps or just a little over 20 amps, steady running draw. I would go with two of the 2200's.
My RV has a 3.200 Onan Diesel generator--These are only made for OEM installation, and have 26.7 amps output.. The 3200 is a great size--can run AC, plus microwave.
jkidd
PostPosted: Mon Sep 19, 2022 8:03 pm    Post subject: Reply with quote
No fuel shutoff, no choke just switch it on and pull the rope. one pull starts. You can slow pull the rope to start it.
You would need a 2200 and a 2200 companion to parallel them to get then 30 amp socket. You would still be limited by the 30 amp socket.
The fuel injection solves a lot of the fuel related problems. My CRF250L has fuel injection, no choke and no fuel shut off just start it and go nice!!!
-Waypoint-
C-Dory Year: 1998
Vessel Name: Waypoint
Photos: Waypoint
PostPosted: Mon Sep 19, 2022 8:39 pm    Post subject: Reply with quote
Love it. But the only way I would see the need to get a genset that size for our boat would be to have the ability to keep our roof A/C running and run a small hair dryer at the same time.
I have the Honda 2200 companion model and we use it to keep the A/C running non-stop underway. Runs our Colman Mac Air 13,500 BTUs for 5 hours on 0.9 gallons of gas. The phone app shows 1540 watts with just the a/c running. So I just turn the A/C off for a min so my wife can dry her hair.
Mark n' Yuka Elwell
Page 3 of 4
Page generation time: 0.0473s (PHP: 67% - SQL: 33%) - SQL queries: 28 - GZIP disabled - Debug on
