Cooler rack mod
dogon dory
Vessel Name: DogOnDory
PostPosted: Tue May 30, 2006 11:19 am    Post subject: Reply with quote
PostPosted: Tue May 30, 2006 11:30 am    Post subject: Reply with quote
Dan-
Does it bother you in terms of not being able to see the motor's steering alignment when backing up?
(Maybe you aren't around tight docks and marinas enough to care!)
Joe.
Sneaks
Vessel Name: C-Brat
Photos: Jenny B and C-Brat
PostPosted: Tue May 30, 2006 11:39 am    Post subject: Reply with quote
dogon dory wrote:
One negative is that the cooler blocks line of sight to the cooling water telltale. I didn't realize how frequently I glance back at that rascal until now that I can't see it.
When boating near Camp Pendleton, I often wonder how (or if) the Marines modified the outboards on their inflatables so the telltale is directed almost vertical. It also exits with a lot of force - their telltales easily reach 5-6 ft. straight up. Something similar would easily be seen over your cooler on that nice rack.
Joe, a replacement wheel with a steering knob works wonders. It's so easy and quick to go lock to lock that way and you do get a bit of an indicator by the knob location .
Don
PostPosted: Tue May 30, 2006 12:57 pm    Post subject: Reply with quote
Don-
Been hot and cold on the spinner knob! Good with girls in high school, yes and no on the C-Dory!
I added a knob top my replacement wheel at one point, but didn't like the extra bump on the wheel where the knob collar wraps around the wheel or the knob itself, except in reverse, where it was a great tool! (In reverse, I stand bettween the fron seat in the aisle and steer with my left hand in order to see things more clearly.)
Been thinking of a way to add the knob slightly inside the outer wheel on one of the spokes and make it turn down inward out of the way when not in use (?)
Good idea about the tell-tale! Plenty of pressure there to add an extension tube up into visible range. Could even add a electrical pressure-sensitive switch and a red monitor light on the dash as a back-up or alternative.
Joe.
DaveS
City/Region: Arlington
Vessel Name: Sea Shift
Photos: Sea Shift
PostPosted: Tue May 30, 2006 2:35 pm    Post subject: Reply with quote
DOD,
With my Johnsons which are Suzukis under a Johnson cover you can turn the telltales 360 degrees. Are you able to do that with your telltale and shoot them upwards so you can see it?
Dave S.
"Sea Shift"
C-Brat #16
Mighty Bite
Vessel Name: Mighty Bite
Photos: Mighty Bite
PostPosted: Tue May 30, 2006 3:32 pm    Post subject: Reply with quote
I'm in the process of doing a cooler rack ala' Dogon Dan, only making it out of the Home Depot plastic wood. Pockets are made for the support bar, the pallet is done. I'll pick up the 1" square stainless support bar today from a local vendor and then it's just a matter of installling it.
I don't know how the plastic wood is going to compare long term with the
decking material, but thought I would use it because of the light weight.
I'll post some pictures shortly in my album.
Super idea Dan!
Mark on Mighty Bite
dogon dory
PostPosted: Tue May 30, 2006 5:03 pm    Post subject: Reply with quote
oldgrowth
City/Region: Rochester
Vessel Name: C-Voyager
Photos: C-Voyager
PostPosted: Tue May 30, 2006 7:39 pm    Post subject: Reply with quote
dogon dory wrote:
I appreciate all the responses but I really just wanted a reason to post the pic of the glassy calm water and the sun on top of the mountains. That's kind of why only the top of the cooler is in the pic. It was really a beautiful weekend on the Sound (finally) Rainbow .
I almost posted a reply to your post and photo, questioning your ability to take a photo of the cooler, then remembered you are a professional photographer so I figured your subject was really the view.
Mighty Bite
Photos: Mighty Bite
PostPosted: Tue May 30, 2006 10:41 pm    Post subject: Reply with quote
Dan, Dave is right on the tell tail. You can articulate it in about any direction.
As to the pissing contest. This old duffer knows his limitations and will concede.
Oh! The motors? err, OK!
DaveS
Photos: Sea Shift
PostPosted: Tue May 30, 2006 11:56 pm    Post subject: Reply with quote
The Twin Johnsons on "Sea Shift" are aimed "crossfire" at each other.........kind of a pissin' contest... Rolling Eyes
Heck, if you wanna have a bit of fun with it, aim it so when you come along side a float it'll shoot those standing by as you come in for a landing.... Laughing
Salmon Slayer
City/Region: Juneau, Alaska
C-Dory Year: 1981
Vessel Name: Holly May
Photos: Holly May
PostPosted: Wed May 31, 2006 1:32 am    Post subject: Reply with quote
Nice mod and pictures DOD, I read an article recently that said there really isnt a reason for telltales anymore because of the sophistication of the engines and warning systems but that they keep them for long time boaters who dont feel comfortable without them.
I am the same way; have to hear it (at idle) or see it from time to time to feel right.
Salmon Slayer
Where did all those years go?
barefoot
City/Region: St. Johns River
Vessel Name: Altered Attitudes
PostPosted: Wed Jul 26, 2006 4:32 am    Post subject: Reply with quote
[quote]Sea Wolf wrote: I added a knob top my replacement wheel at one point, but didn't like the extra bump on the wheel where the knob collar wraps around the wheel or the knob itself...Been thinking of a way to add the knob slightly inside the outer wheel on one of the spokes and make it turn down inward out of the way when not in use (?)
Would you believe J. C. Whitney shows two "steering wheel spinners", one of which folds away inward? Could be the ticket. If you don't have the catalog, I've seen them in the supermarket magazine rack for $3.99.
PostPosted: Wed Jul 26, 2006 5:48 am    Post subject: Reply with quote
Thanks, barefoot! I'll look it up! Joe.
Page generation time: 0.0418s (PHP: 71% - SQL: 29%) - SQL queries: 26 - GZIP disabled - Debug on
