Thoughts on extra fuel storage
Da Nag
Vessel Name: Wilbur
Photos: Da Boats
PostPosted: Sun Feb 09, 2014 12:00 pm    Post subject: Reply with quote
BrentB wrote:
As of January of 2009, all new portable fuel containers in the US must meet new Mobile Source Air Toxic regulations based on the California Air Resources Board’s (CARB) regulations, and they must meet the requirements of the Children’t Gasoline Burn Prevention Act.
I've no idea what loophole is being exploited, but I'm glad one seems to exist.
I use these for all my portable fuel containers. They are more stable than jerry cans, easily secured given their shape, and pour better than anything out there without spilling a drop. Standard gear for motorcycle folks.
There are a few brands, they go on sale routinely.
Tux Will, C-Brat Nerd Tux
BrentB
City/Region: Greenwood
State or Province: IN
Photos: BrentB
PostPosted: Sun Feb 09, 2014 1:28 pm    Post subject: Reply with quote
I really like the RotoPax system but dont need them
http://rotopax.com/
On new generation gas cans, I removed the spring loaded tip and use a large Mr Funnel. I plan to buy a larger funnel from Tractor Supply and remove the entire spout, pour directly from the can
Brent Barrett
PostPosted: Sun Feb 09, 2014 1:34 pm    Post subject: Reply with quote
I wonder what they mean by this?
Note: Not to be sold as a portable fuel container in states that require spill-proof systems or have spill proof system regulations.
potter water
City/Region: Logan
C-Dory Year: 1997
C-Dory Model: R-21 Tug
Vessel Name: Poopsy
Photos: Still C-razy
PostPosted: Sun Feb 09, 2014 2:18 pm    Post subject: Reply with quote
Cheapo wall mart red containers and the wiggle type siphon tubes for xfer with the spout removed are the ticket. Yes, some care is needed for safety, and "children" are not allowed to fuel my boat in any case. Fire extinguishers should be on standby. I always place the fuel can on the gunnel on the side I'm fueling, held by the deck hand. In emergency it'll be pushed over the side and epa be damned. At least the deck hand and the captain won't be burned alive. Less chance of a spill with the siphon than using the California spouts. hate those things. Must have been their governor to come up with that solution. He's not an engineer I suspect.
Testosterone Tales-Amazon.com
KG7RC
hambone
PostPosted: Sun Feb 09, 2014 4:34 pm    Post subject: Reply with quote
Great info guys. Just placed my order.
http://www.amazon.com/Super-Siphon-1009-1-Hose/dp/B000ZOT39A/ref=pd_sim_sg_23
Hawg Hunter Productions.
halibut taco
City/Region: Whittier
Photos: Shiroz
PostPosted: Sun Feb 09, 2014 6:29 pm    Post subject: Reply with quote
You won't be disappointed with a shaker siphon. They work great and are cheap.
I use it with one of the blue 15 gal poly drums here Jay:
http://unitechofalaska.com/store/page37.html
For me the 15gal plastic drum is easier to deal with than several smaller cans. I strap it to the rail next to the cockpit step. It has a small footprint and doesn't affect the boat's ride noticeably. When it's empty I strap it up in the dinghy.
BrentB
Photos: BrentB
PostPosted: Sun Feb 09, 2014 8:53 pm    Post subject: Reply with quote
We have reagents in 15 gal containers
see
http://www.usplastic.com/catalog/item.aspx?itemid=23849
When filled, they weigh over 100 lbs and in the past used them for waste oil at home
How are you securing and venting them in the boat?
At work we use to hand trucks for transport and containers are just free standing
halibut taco
Photos: Shiroz
PostPosted: Sun Feb 09, 2014 10:17 pm    Post subject: Reply with quote
Gasoline is about 6 pounds per gallon making the 15 gal drum under 100 lbs. I can lift it myself onto a 5 gallon bucket. Then I siphon it from there into the main tank. To secure it I put the drum on a small towel to increase friction between drum and deck, then use a ratchet strap to the rail. It doesn't move, I've been in some rough weather with it.
The drum is not vented. We have cool weather here so I don't worry about expansion too much. I probably leave about 2 gal space for expansion. The drum is pretty rigid and handles pressure well. It doesn't take long to run through 13 gal with the distances we travel here so the drum is usually emptied by the next morning. It's pretty easy to crack the seal and let pressure out if needed. Your link appears to be the same drum. I notice it says not for fuel. My dealer said it was, I just needed to change the seals out with seals safe for fuel.
BrentB
Photos: BrentB
PostPosted: Sun Feb 09, 2014 10:29 pm    Post subject: Reply with quote
I wonder if a rotary hand pump could e added?
see
http://www.jmesales.com/product/fill-rite-sd62-rotary-hand-pump,5276,5404.htm?gclid=COy68uHOwLwCFeYWMgodJSEAyQ
BrentB
Photos: BrentB
PostPosted: Sun Feb 09, 2014 10:37 pm    Post subject: Reply with quote
Where can I find information on EPA approved gas cans or fuel containers?
Regulations changing the design of portable fuel containers were issued as part of EPA's rule to reduce air toxics from mobile sources (vehicles, engines and fuels). Mobile source air toxics are compounds emitted from highway vehicles and non-road equipment which are known or suspected to cause cancer or other serious health and environmental effects.
Information on the mobile source air toxic , which effects gas cans, as well as diesel and kerosene containers can be found here: http://www.epa.gov/otaq/toxics.htm.
You may also be interested in this document which examines design factors that may contribute to portable fuel can emissions: Estimating Emissions Associated with Portable Fuel Containers (PFCs) (PDF) http://www.regulations.gov/#!documentDetail;D=EPA-HQ-OAR-2005-0036-1133 (30 pp, 628K, EPA420-R-07-001, February 2007) (About PDF)
The regulatory announcement, Control of Hazardous Air Pollutants from Mobile Sources: Final Rule to Reduce Mobile Source Air Toxics is available here (PDF): http://www.epa.gov/OMS/regs/toxics/420f07017.pdf (5 pp, 143K, EPA420-F-07-017, February 2007) (About PDF)
The updated regulatory announcement, Control of Hazardous Air Pollutants from Mobile Sources: Early Credit Technology Requirement Revision is available here (PDF): http://www.epa.gov/otaq/regs/toxics/420f08030.pdf (3 pp, 124K, EPA 420-F-08-030, October 2008) (About PDF)
If you have further comments or questions, please contact EPA's Office of Transportation and Air Quality at: http://epa.gov/otaq/oms-cmt.htm
http://publicaccess.supportportal.com/ics/support/KBAnswer.asp?questionID=32525
Aurelia
City/Region: Gig Harbor
Photos: Aurelia
PostPosted: Sun Feb 09, 2014 11:35 pm    Post subject: Reply with quote
I have used the rotopax in some terrible conditions for motorcycling and would surely trust them not to fail. They are very thick walled and flat with many attachment options. They also make them for water and gear storage. They are relativly low capacity but have mounts that are very secure and can be stacked up to three deep with spacers on the mounts. Or just banked together and strapped like this,
http://www.gowesty.com/images/ec/products/large/large_039b9a9876f3a29c47567502db2b3cd1.jpg
Their photo page
http://www.flickr.com/photos/rotopax
I have ordered from this site which has quite a range of tanks.
http://www.justgastanks.com/
Examples:
plastic jerry can type minus the corrosion
http://justgastanks.com/product_info.php?products_id=1833
they do have some bladders but they are pricey (53 gallon for $600)
http://justgastanks.com/index.php?cPath=413_420
Motorcycle type
http://justgastanks.com/product_info.php?products_id=1322
Greg, Cindie & Aven
Gig Harbor
Ari - 19 Cruiser sold 2023
Roy & Dixie
City/Region: Silver Springs
Vessel Name: C Way
Photos: C-Way
PostPosted: Mon Feb 10, 2014 9:06 am    Post subject: Reply with quote
My 1999 22' CD has 2 18 gal tanks. I leveled them side to side with shims to allow more useable fuel to be delivered to the outboard pick-up tubes. This then allowed me room to install a third tank between the 2 original tanks; a 12 gal tank. I ran fuel line, teed into the main fuel line after the 2-tank selector valve, which also has an off position. The new fuel line has it's own on/off valve. This allows me to select one of any of the 3 tanks, now totaling 48 gal. The new tank is strapped down and can be moved out if I need to access the bilge pump, now blocked by the new tank.
When you come to a fork in the road, take it.
It's not the destination that is important, it's the trip.
"C-Way" Silver Springs, FL
breausaw
Vessel Name: Triple J
Photos: Triple J
PostPosted: Mon Feb 10, 2014 10:54 am    Post subject: Reply with quote
I have a fishing buddy who has been using these 6 gallon water jugs for gas the last couple years, most every trip he takes a few along. Thinking of switching over, I'll write gas on the side so no one takes a drink. Very Happy. He puts in 5.5 gallons of gas so there is a .5 gallon air space for expansion. Hay, the color matches my boat trim way better then the ugly red jugs. Thumbs Up
Boatless for now but looking
petemos
State or Province: NS
Vessel Name: C-You-Later
Photos: C-You-Later
PostPosted: Mon Feb 10, 2014 10:58 am    Post subject: Moveing gas around Reply with quote
I built an electric pump to get the gas out of the Gerry cans. It prevents spilling and also I broke one of the gas cap chains putting the nozzle into the filling hole and then had a pain of a time replacing the chain. This is not the cheapest option, but you buy an external electric car fuel pump with filter, and then connect whatever length of gas house your need to the siphon and output end. You then add extra wiring to get the length you want and terminate the wiring with a 12 volt cigarette type jack. The speed of transfer depends on the fuel pump you buy. Mine is about 1 gallon a minute. I also attach a quick snap connector at the siphon or output end. I have two extra connectors in my Fuel separator and connect to them. One, if I want to pump the tanks dry at the end of the season, the other if I want to pump directly into a tank. I also use this pump to get fuel out of my other outboard fuel containers and to pump fuel into my ATV. I’m just too lazy these day and old to be holding these 5/6 gallon cans up while the fuel is flowing out.
anchorout
City/Region: Lake Charles
State or Province: LA
Vessel Name: EZ DUZIT
Photos: EZ DUZIT
PostPosted: Mon Feb 10, 2014 6:12 pm    Post subject: new spouts Reply with quote
I recently purchased one of the gas jugs with the new style spouts. Of course it didn't work as it should. Using the KISS principle, one can pop these mechanical marvels apart, pull the guts out of them, and once popped back together, they work just as good as the old style jugs did.
Page 2 of 3
Page generation time: 0.0565s (PHP: 52% - SQL: 48%) - SQL queries: 28 - GZIP disabled - Debug on
