redbaronace
Joined: 29 Aug 2012 Posts: 581 City/Region: Puget Sound
Vessel Name: Tomcat
Photos: redbaronace (Name TBD)
Posted: Mon Jan 13, 2014 12:32 am Post subject: |
Glad to know that I'm normal. I get the occasional clunking. It is quite loud from inside the truck. I will try some suggestions found here to reduce its occurrence. |
Posted: Sun Jan 19, 2014 5:02 pm Post subject: |
On my Pacific Trailer, (tandem axle with Surge brakes) there is a bit of a clunk on startup after a stop. It is the actuator releasing and going into tow mode. There is a small fiber/rubber washer in there that helps to dampen that clunk. If it is missing, there will be much more clunk volume. I don't think greasing the ball will have much affect on the clunking one way or the other. I have kept mine greased, still have some clunk. If your hitch is set up right there should be very little play between the ball and the socket, (less than 1/16 inch.) If there is play there, things could get nasty and then you will get a chance to see how good your safety chains work.
SleepyC  _________________ Though in our sleep we are not conscious of our activity or surroundings, we should not, in our wakefulness, be unconscious of our sleep. |
Posted: Sun Jan 19, 2014 5:49 pm Post subject: |
Plenty of "clanks" in our Caracal trailer, which does not have brakes. Just play in the coupling. So don't assume that any clunk has anything to do with the brakes. _________________ Bob Austin
