Does your trailer 'clunk ... ?
redbaronace
City/Region: Puget Sound
Vessel Name: Tomcat
PostPosted: Mon Jan 13, 2014 12:32 am    Post subject: Reply with quote
Glad to know that I'm normal. I get the occasional clunking. It is quite loud from inside the truck. I will try some suggestions found here to reduce its occurrence.
PostPosted: Sun Jan 19, 2014 5:02 pm    Post subject: Reply with quote
On my Pacific Trailer, (tandem axle with Surge brakes) there is a bit of a clunk on startup after a stop. It is the actuator releasing and going into tow mode. There is a small fiber/rubber washer in there that helps to dampen that clunk. If it is missing, there will be much more clunk volume. I don't think greasing the ball will have much affect on the clunking one way or the other. I have kept mine greased, still have some clunk. If your hitch is set up right there should be very little play between the ball and the socket, (less than 1/16 inch.) If there is play there, things could get nasty and then you will get a chance to see how good your safety chains work. Shocked Twisted Evil
PostPosted: Sun Jan 19, 2014 5:49 pm    Post subject: Reply with quote
Plenty of "clanks" in our Caracal trailer, which does not have brakes. Just play in the coupling. So don't assume that any clunk has anything to do with the brakes.
Page generation time: 0.0258s (PHP: 61% - SQL: 39%) - SQL queries: 16 - GZIP disabled - Debug on
