22 cruiser powered with a Honda 50
PostPosted: Wed Aug 25, 2010 1:22 am    Post subject: with twin 40's Reply with quote
That Honda50 with 600 hours should be just past a good break in.If it won't go for several thousand hours,get rid of it and get Yamaha Twisted Evil
Seriously, the least expensive and perfectly sound upgrade would be to add another single 50, and convert to twins. Plenty adequate power, and superb handling.
The single 50 will do the hull speed cruising, but will be, (as noted several times above), seriously overworked, at more than 6-7 knots.
SleepyC Moon with twin 40's
Fishhawk
City/Region: Bon Secour
State or Province: AL
Vessel Name: Osprey
Photos: Osprey
PostPosted: Wed Aug 25, 2010 6:22 am    Post subject: Reply with quote
What Harvey says is what I would do.
"We intend to alleviate global warming's effects of raising ocean water levels by removing enough fish to counteract it all! "
jennykatz
City/Region: naples
Vessel Name: Little Treasurer
Photos: Jennykatz
PostPosted: Wed Aug 25, 2010 2:11 pm    Post subject: cd-22 honda 50 Reply with quote
I bought a 99 cd-22 cruiser witha 50 hp honda on it . This is how cuttler marine did their boats in Maryland .On the sea trial we had 3, 220lb men on board she would do16mph (gps) and would plane off at 10mph .
I replaced the 50 with a 90 Suzuki (06) and sold the 50 for $1500 to a friend . Looking at your options I would look over the whole package elec ,trailer canvas etc Then decide adding a 90 will probably add $8000-10,000 to overall package but then deduct what you get for the 50honda and there is your price . If you plan to keep the boat more then a few yrs you will be happy with your decision and resale will be a lot better .Or you can look for another boat with the right Hp. and mayber price will be better ?
20dauntless
Photos: Retriever
PostPosted: Wed Aug 25, 2010 2:39 pm    Post subject: Reply with quote
I'm not so sure that another 50 would be the cheapest option. Remember for twins you'd have fiberglass repair costs to fill the original holes and the cost of rigging two engines. For the single 90, the engine would cost ~$2000 more than the new 50 but (if you stayed with Honda) would require no additional controls, etc. The bolt holes would stay the same (I think) and you could sell the original 50 for ~$2,000 I would think, saving the cost of fiberglass repair and controls/instruments for the second engine.
But I'd ask a dealer to be sure...
seabeagle
City/Region: Farmington Hills
Vessel Name: Sea Beagle II - Sold 4-19-12
Photos: Sea Beagle II
PostPosted: Wed Aug 25, 2010 6:33 pm    Post subject: Reply with quote
Who says 50's are for16's. I'd like to see a 75+ on my 16.
I am the 125% I work so the 99% don't have to.
http://www.youtube.com/SeaBeagleII
Wefings
Dealer
City/Region: Panhandle
Photos: Cruise Ship #4
PostPosted: Wed Aug 25, 2010 7:14 pm    Post subject: Reply with quote
The new 70 Yamaha would be sweet !
Marc
Wefings Marine Website
Since 1909
Matt Gurnsey
Dealer
City/Region: Port Orchard
Photos: Kitsap Marina
PostPosted: Wed Aug 25, 2010 8:05 pm    Post subject: Reply with quote
Yeah, I'm hoping to sell a 70 soon so we can sea trial it and see if it's everything Yamaha says it is. If it is, it could be one very sweet engine.
Matt Gurnsey
Kitsap Marina
www.kitsapmarina.com
360-895-2193
(888) 293-7991
seabeagle
PostPosted: Wed Aug 25, 2010 8:10 pm    Post subject: Reply with quote
How does the weight of the 70 compare to the 50?
PostPosted: Thu Aug 26, 2010 8:23 am    Post subject: Reply with quote
According to the Yami website, the 70 is 257# and the 50 is 237#.
One # per extra HP!
jennykatz
City/Region: naples
Photos: Jennykatz
PostPosted: Thu Aug 26, 2010 9:01 am    Post subject: Yamaha 70 Reply with quote
the new Yami 70 is the same block engine as the 50-60 (60 cu in)engines but I believe it has the VVT and 4valves per cylinder giving it more hp
It looks like a nice engine probably very fuel efficient nice for a 16or 19 but if price was close I would opt for yami 90
Matt Gurnsey
Dealer
PostPosted: Thu Aug 26, 2010 7:03 pm    Post subject: Reply with quote
We have been told that the new 70 is not the same block as anything currently in the Yamaha line up, although looking at the bore / stroke and displacement it matches the 50/60. It weighs about 260 pounds. It also looks much smaller than other 70's on the market, and weighs slightly more than the Yamaha 50/60. I wish I had a 50 or 60 in stock to compare it too.
Doryman
Vessel Name: Lori Ann
Photos: Lori Ann
PostPosted: Thu Aug 26, 2010 8:36 pm    Post subject: Reply with quote
Matt -- A question about gearing for Honda, Yamaha and Suzuki. I have noticed that Suzuki gearing is more aggressive than that of Yamaha and Suzuki. For the 150s:
Honda -- 2.14:1
Yamaha -- 2.00:1
Suzuki -- 2.50:1
Several people here prefer Suzuki for performance. I am wondering why the other manufacturers don't match those gear ratios -- I don't believe the lower gear ratios on the Hondas and Yamahas result in significantly more economy, if reports from the field are to be believed. So what are the tradeoffs here?
Doryman
M/V Lori Ann
Anacortes, WA
PostPosted: Fri Aug 27, 2010 1:17 am    Post subject: Reply with quote
Honda -- 2.14:1
Yamaha -- 2.00:1
Suzuki -- 2.50:1
Warren-
The Suzuki is actually lower geared than the Honda and Yamaha, which turn the motor 2.14 times and 2 times, respectively, for each revolution of the prop, because the Suzuki must turn it's motor 2.5 times to get it's prop to turn once.
(I guess ratios have to be understood from which side of the numbers your on!)
As I understand it, the advantages of the lower gear ratio on the Suzuki is that the resulting slower turning prop with a higher pitch is
1. less likely to cavitate than a lesser pitched (and probably smaller diameter) prop that is turning faster, and
2. should have less frictional loss, since the speed of the water accros the slower turning blades should be slightly less.
There are probably more advantages and/or trade-offs, too, but these are the two I can think of right now.
I made an analogy once using a row boat. You could row the boat with three foot oars or 8 foot oars.
Either would propel the boat, but the three foot oars would waste a lot of energy splashing around a lot, whereas the longer 8 footers would transfer the
energy more efficiently.
Of course, the analogy is exaggerated to more than the gear ratio differences, but the idea is the same.
Hope this makes sense (and holds water too!)
Doryman
Photos: Lori Ann
PostPosted: Fri Aug 27, 2010 6:37 am    Post subject: Reply with quote
Thanks, Joe! Razz I would have benefitted from taking high school science from you, I think!
colobear
City/Region: Denver
Photos: C-Cakes
PostPosted: Fri Aug 27, 2010 10:53 am    Post subject: Reply with quote
One thing to consider that has not been mentioned here, I think, is the charging capacity of the engine alternators. We run 2006 Honda 40's and are happy with them as engines but each has just a 10 amp charging capacity, 20 amps together. That means the charging the batteries, even underway, will take a very long time. Newer Honda engines, I understand, have higher capacity alternators as do Suzuki and Tohatsu.
Were we to re-power today I would look seriously at charging capacity and weight as critical factors and would strongly consider Suzukis.
Patti and Barry
formerly C-Cakes, now
rving around N. America
Page 2 of 3
Page generation time: 0.0461s (PHP: 68% - SQL: 32%) - SQL queries: 28 - GZIP disabled - Debug on
