CD 22 Transom
SENSEI
City/Region: Stanwood
Vessel Name: SENSEI
Photos: SENSEI and SERENITY
PostPosted: Fri Apr 05, 2013 11:21 am    Post subject: Reply with quote
I had to replace the core in Sensei's transom. it was balsa and no ply. it was redone with balsa .
Roger on the "SENSEI"
1993 22 Cruiser (sold 2014)
1983 22 Classic (sold 2017)
ferret30
Vessel Name: Lily Pad
Photos: Lily Pad
PostPosted: Fri Apr 05, 2013 11:44 am    Post subject: Reply with quote
My 2006 definitely has green foam in the transom.
C-Val
City/Region: White Rock
C-Dory Year: 1988
Vessel Name: Seaduced
Photos: C-Val
PostPosted: Fri Apr 05, 2013 1:44 pm    Post subject: Reply with quote
Sensei
Your album is very helpful to me as I will probably into redoing mine soon
Question: if you were doing yours again would you remove the inside as you did or would you cut off the outside skin as some others have suggested?
(I was going to replace mine with marine plywood since I am used to working with ply --unless that is a bad idea)
Writing a sea story with my C-Dory !
1982 22' Classic Popeye
1981 22' Classic Bad Boy Brutus
1988 22' Angler
PostPosted: Fri Apr 05, 2013 2:18 pm    Post subject: Reply with quote
...C-25 has a high density foam transom...
Ditto on our 2007 model year CD25. It's a "pinkish" color.
http://www.c-brats.com/modules.php?set_albumName=album1535&id=San_Juans_2011_001&op=modload&name=gallery&file=index&include=view_photo.php
cedarecho
City/Region: Juneau
C-Dory Year: 1982
C-Dory Model: 22 Classic
Vessel Name: Veryln
Photos: VERLYN
PostPosted: Sun May 12, 2013 2:36 am    Post subject: Reply with quote
I replaced my transom with 2 layers of marine grade plywood.
PostPosted: Sun May 12, 2013 7:35 am    Post subject: Reply with quote
Got pictures? Hope you mean transom core, pretty sure you do! Others will be very interested in the process! Thanks!
cedarecho
City/Region: Juneau
C-Dory Year: 1982
Vessel Name: Veryln
Photos: VERLYN
PostPosted: Sun May 12, 2013 1:37 pm    Post subject: Reply with quote
I did mean the transom core. I do have pictures posted in Verlyn's album.
PostPosted: Sun May 12, 2013 2:15 pm    Post subject: Reply with quote
Good choice. It should last more than another 30 years, especially if you sealed the top with epoxy and line any holes with epoxy.
digger
City/Region: Spokane
Vessel Name: C-Sik
Photos: Snoopy-C
PostPosted: Sun May 12, 2013 2:40 pm    Post subject: Reply with quote
I can hardly wait to see more of The Prairieboy progress on his album. I keep checking, and am glad that there will be some new artwork in the form of boat rebirth coming out of Kentucky. Ron
Page generation time: 0.048s (PHP: 50% - SQL: 50%) - SQL queries: 22 - GZIP disabled - Debug on
