Spring prep questions
matt_unique
City/Region: Boston
Vessel Name: Napoleon
Photos: Napoleon
PostPosted: Mon Mar 30, 2009 10:22 am    Post subject: Stream Reply with quote
All is well...I dunked both engines in the tub again today to test and I had immediate cooling spray upon start.
Thanks again.
Captain Matt
maryswensen
City/Region: Greenport, LI
State or Province: NY
Vessel Name: Mary C.
PostPosted: Mon Mar 30, 2009 4:09 pm    Post subject: Spring Prep Question Reply with quote
This might be of help. I was advised to spray WD40 down the outlet. Worked like a charm. I was advised that salt can block the channel and WD40 clears it out.
Good luck
Ed
Mary C.
PostPosted: Mon Mar 30, 2009 5:09 pm    Post subject: Reply with quote
There is a product called "Salt away" http://www.saltawayproducts.com/
I keep a 3 gallon spray bottle with a hose adaptor on the hose, and pump a little into the engines after running in salt water, when I cannot flush it every time. Generally this will help to prevent any salt deposits. You don't want to just superficially avoid salt deposition--because it can deposit in the entire water cooling system.
I am not a big fan of WD 40, although I do use it for a stage of cleaning rust etc. I suspect that there are better solvents to use on rubber hoses.
Page generation time: 0.0266s (PHP: 59% - SQL: 41%) - SQL queries: 16 - GZIP disabled - Debug on
