matt_unique
Vessel Name: Napoleon
Photos: Napoleon
Posted: Mon Mar 30, 2009 10:22 am Post subject: Stream |
All is well...I dunked both engines in the tub again today to test and I had immediate cooling spray upon start.
Thanks again. _________________ Captain Matt
maryswensen
Joined: 03 May 2007 Posts: 26 City/Region: Greenport, LI
State or Province: NY
Vessel Name: Mary C.
Posted: Mon Mar 30, 2009 4:09 pm Post subject: Spring Prep Question |
This might be of help. I was advised to spray WD40 down the outlet. Worked like a charm. I was advised that salt can block the channel and WD40 clears it out.
Good luck
Ed _________________ Mary C. |
Joined: 02 Nov 2003 Posts: 21384 City/Region: Pensacola
Posted: Mon Mar 30, 2009 5:09 pm Post subject: |
There is a product called "Salt away" http://www.saltawayproducts.com/
I keep a 3 gallon spray bottle with a hose adaptor on the hose, and pump a little into the engines after running in salt water, when I cannot flush it every time. Generally this will help to prevent any salt deposits. You don't want to just superficially avoid salt deposition--because it can deposit in the entire water cooling system.
I am not a big fan of WD 40, although I do use it for a stage of cleaning rust etc. I suspect that there are better solvents to use on rubber hoses. _________________ Bob Austin
