Access Hatches rear cockpit bulkhead TC255
PostPosted: Fri Oct 08, 2010 6:24 pm    Post subject: Access Hatches rear cockpit bulkhead TC255 Reply with quote
My 2006 TC255 has the smaller access hatches on the rear of the cockpit. As such, it is very difficult to get to stuff down in the bilge like the macerator pumps for the fishboxes and especially the bilge pumps. Can someone measure their hatches on a newer TC? I know they are about as big as they can get and still fit, mine are a lot smaller. The outside measurement flange to flange will do.
Alternatively, if the factory (Scott?) can tell me what brand/model they are currently putting in the new TCs, that would be great too.
Thanks
Mike...
Photos: Accelerando
PostPosted: Fri Oct 08, 2010 6:38 pm    Post subject: Reply with quote
Charlie, can you post a picture?
My boat is not here, but I'll be with it next Friday and will get you pictures and measurements.
My lazarettes have stupid metal "floors" in them, each with a round access hatch. I am pulling those out.
mike
PostPosted: Fri Oct 08, 2010 8:49 pm    Post subject: Reply with quote
Dark out now, boat is in the driveway. Here's a "big hatch" on Roger's DREAMER, just under the red BBQ grill. Comes up to the deck level. Mine are a lot smaller. I'll just go measure the space I have and buy the biggest one that will fit.
Mike...
Photos: Accelerando
PostPosted: Sat Oct 09, 2010 12:59 am    Post subject: Reply with quote
Ah, I see. Mine are the same a Roger's.
When I get to the beat next weekend, I'll look and see if I can find a model number on them.
mike
Doryman
Vessel Name: Lori Ann
Photos: Lori Ann
PostPosted: Sat Oct 09, 2010 3:17 am    Post subject: Re: Access Hatches rear cockpit bulkhead TC255 Reply with quote
You could also do what Roger did, and install access covers in the fishboxes themselves. Roger writes about it here but something happened to his photos of the project -- they are not in his album any more.
Doryman
M/V Lori Ann
Anacortes, WA
PostPosted: Sat Oct 09, 2010 7:45 am    Post subject: Reply with quote
Thanks Warren. They're still there, may have been moved though so the old link doesn't work anymore. I'd like to do that too, wrestling with how to keep all the cutting debris out of the bilges since it'll be hard to clean out after the job(s).
drjohn71a
City/Region: Wichita
State or Province: KS
Vessel Name: Tom-a-Hawk
Photos: Tom-a-Hawk
PostPosted: Sat Oct 09, 2010 10:12 am    Post subject: Reply with quote
Charlie,
I, too, like that idea of the hatch IN the box. I am wondering if a guy used one of those new vibrating saws, avoiding through cutting until the last, and having someone hold a vacuum up to the saw blade, could avoid most of the problem of debris in the bilge?
PostPosted: Sat Oct 09, 2010 11:10 am    Post subject: Reply with quote
If you look at the post in his album, it says he used a sawzall which is a very messy process. Of course, once you open this up, and put a larger hatch in the vertical cockpit bulkhead, it'll be easier to get to the bilge to clean it out... Wink
I've got a rotozip, which is probably what I'd use.
matt_unique
City/Region: Boston
Vessel Name: Napoleon
Photos: Napoleon
PostPosted: Sat Oct 09, 2010 11:13 am    Post subject: Dremel Reply with quote
I would use a drill and a Dremel...the rotation of the Dremel and the drill is such that most all the debris would be ejected into the fishbox. Be sure to measure awfully careful Shocked
Captain Matt
Dreamer
Photos: Dreamer
PostPosted: Sat Oct 09, 2010 3:48 pm    Post subject: Reply with quote
Guys, Photos are back. Sorry Embarassed
Dreamer- Sold 25 Feb. 2013
PostPosted: Mon Oct 11, 2010 11:53 am    Post subject: Reply with quote
Still looking for someone to tell me the dimensions (outside dimensions of frame) of their TC rear cockpit bulkhead hatches. Mine are 12 1/2 X 15 1/2 which correspond to one of the Bomar models. Other Bomar models, larger, measure 18 1/8 X 20 3/16 ( a very tight if not impossible fit width wise) and 13/3/4 X 23 1/2 (close to the max height available).
Anyone near their boat with the larger hatches that can confirm one of these two alternatives?
Thanks..
drjohn71a
Photos: Tom-a-Hawk
PostPosted: Mon Oct 11, 2010 1:06 pm    Post subject: Reply with quote
Charlie,
If you are listing the outermost flange dimensions, your current size would match my aft hatches. Just mentally picturing it, I don't see how one could get a 24 inch dimension out of the transom wall area, so you may have the largest available.
I will be on the boat this weekend and will try to remember to measure that for you.
PostPosted: Mon Oct 11, 2010 1:47 pm    Post subject: Reply with quote
Yours may be the same as mine John but mine are way smaller than Roger's on Dreamer, see a post about 6 up on this thread, right below the red grill cover. Mine are at least 6 inches below the top edge of the cockpit. His are nearly flush (on the outer edge of the flange.).
Dreamer
Photos: Dreamer
PostPosted: Mon Oct 11, 2010 5:33 pm    Post subject: Reply with quote
Hi Charlie,
Just got back from the boat. Rear hatches are 23.5" tall, 13.75" wide. No part number apparent.
Now I have to go back to the boat and lock it up and get my keys that are hanging in the door... Embarassed
drjohn71a
Photos: Tom-a-Hawk
PostPosted: Tue Oct 12, 2010 9:39 am    Post subject: Reply with quote
Charlie,
My hatches are the same as Roger's - big. BUT please note that even those big transom hatches do not allow adequate room to mess with the bilge and macerator pumps on my my boat. There are several batteries and a floor to hold them behind the larger hatches.
I am thinking about putting those access hatches in the aft wall of each fish well.
Page generation time: 0.0544s (PHP: 65% - SQL: 35%) - SQL queries: 28 - GZIP disabled - Debug on
