Anchor tests
Goto page 1, 2, 3, 4  Next
PostPosted: Sat Feb 16, 2008 4:47 pm    Post subject: Anchor tests Reply with quote
As promised I did tests on multiple anchors on Feb 16. on upper Perdido Bay. The bottom was about 2" of soft non cohesive mud, then 3" of cohesive mud, and finally several feet of combination co-hesive mud, sand and seashells. The air temp was 75 degrees, water temp 64 degrees, clear conditions with a 15 to 18 knots from the East, and minimal waves, since I was about 300 yards from the Eastern shore.
Each pass was in a slightly different place, so that no "disturbed bottom" was used.
The boat is an 18 foot 2003 Century center console, 8' beam, 15 degree dead rise and weight 1800 lbs. The engine is a 2003 115 HP fuel injected Yahama 115 lbs. The prop is 14" diameter x 15" pitch. The WOT RPM is 5500 and speed of 37 knots.
The anchor rode was 9/16" Dacron tow line (designed for drogues, low stretch but suppple). I did not want spring in the test line. No chain was depoyed (mostly to make it easier to get the anchor up) Chain might have helped set the anchor, but would have made no difference in the ultimate holding power.
Method. The boat was brought to a stand still in reverse. The anchor was lowered to the bottom in about 4 feet of water. A PVC pipe was put in the water right were the anchor was dropped. When the anchor was retrieved, the distance from this pipe (amount drug before fully setting) was measured, by the distance of the dug in anchor to the pipe.
After the anchor was on the bottom the anchor rode was paid out until a scope of 7:1 was reached. There was a slight tension on the rode (about 5 lbs) to feel if the anchor was dragging. If it was dragging, the rode was allowed to go slack and then light pressure again applied. When the rode was at 7:1, (including the distance of the cleate off the water), it was cleated off. A second piece of PVC pipe was put in the water and felt to see if the anchor was dragging. If it was dragging, the anchor was attempted to be re-set, or pulled on in slighly jerks to attempt to be set. The wind alone against the boat hull was putting 35 lbs of force on the anchor rode. Once set, the engine was put in gear at 600 RPM idle. The force measured on a spring scale was 100 lbs. If the anchor held at this load, then the throttle was gradually applied to 3600 RPM--this was the max RPM reached with the boat stationary, and the engine all of the way down. Normally the 3600 RPM would put the boat quickly on a plane, and sustain a cruising speed of about 22 knots. I estimated the bollard pull load at over 1000 lbs. Far more than the average boat would achive in winds less than 60 knots. The boat would crab sideways--to 90 degrees. I would take the boat back and re try again at 3600 RPM x 2 more times.
Weight on spring scales, which seem accurate. Fluke area measured, and is some what approximated because of the rounding of fluke edges.
Anchors:
Danforth standard 8 lbs Wt 8 lbs, 46 sq inches of fluke area. This anchor never properly set under these conditions. Just skipped across the bottom
Guardian G7 (cheap fortress)--4 lbs, fluke area 50 sq inches of fluke area,
It dug in and then pulled out at 3:1 scope, but seemed to be holding at 7:1 scope. It slowly drug about 20 feet and pulled out at about 1000 PRM--I estimated about 100 lbs. It would not reset as the boat was drifting.
Fortress FX 16 Wt 10 lbs, fluke area 266 sq inches, in standard position.
Set rapidly did not drag more than 3 feet at 3 runs up to max RPM
Northill Folding Sea Plane SS anchor: Weight 12 lbs, fluke each fluke 154 sq inches. Anchor set promptly did not drag initially. Held up to 1800 RPM and estimated 800 lbs.
Manson Supreme: 25 lb, Fluke area 192 sq inches, set promptly did not seem to drag, held to max RPM with minimal drag--not more than 2 feet.
Delta Fast set 22lb Fluke area 220 sq inches, drug a foot or so, set well, stayed set at full PRM, with about 5 foot total drag.
Danforth 35 lbs(WWII, Cast or forged and riveted crown)--simlar to the High Test or Performance anchor Fluke area 192 sq inches. This anchor set rapidly and did not appear to drag. Held at max RPM. This same anchor held my Cal 46 in 87 knots of wind.
Summary: The Danforth 8 lb did't have sharp enough edges, or was not able to penetrate the surface and did not set. This is a fairly commonly used anchor of the CD 22, and in this test failed.
The Guardian, is too light to pentrate to any depth. Notice that the much larger fluke area, and only 6# more weight FX 16 set well and did not drag.
The Danforth 35lbs is too heavy to be practical--and probably will not fit well on the standard bow puplits, plus no advantage over the other anchors.
The Delta and Manson Supreme were equal in these tests. The Danforth fits the bow roller/pulpit very well, and I put a fast pin thru the crown hole to secure the anchor on the roller. The Manson Supreme does not have a hole which can be used to secure it. It does fit on the Tom Cat Roller. Although they seemed equal, I suspect that in some conditions the Manson would do better. There was more mud on its fluke than any of the other anchors.
Although the Northill is a nice and light anchor, it did fail, and is probably not worth carrying--except on some grass types. I'll probably put mine in the "anchor" musuem-in my garage.
I'll post photos of the anchors tomarrow.
ppriest
Guest
PostPosted: Sat Feb 16, 2008 5:33 pm    Post subject: Reply with quote
Assuming the Fortress FX-16 is the adjustable model, which angle setting was used for this test?
Paul Priest
Sequim
colobear
City/Region: Denver
Photos: C-Cakes
PostPosted: Sat Feb 16, 2008 6:00 pm    Post subject: Reply with quote
Bob,
Thanks very much for doing this test and giving us all the results.
Patti and Barry
formerly C-Cakes, now
rving around N. America
RJD Wannabe
City/Region: Elk Grove
PostPosted: Sat Feb 16, 2008 6:03 pm    Post subject: Reply with quote
Many thanks, always been a fan of the Deltas.
Soon to join C-Dory owners
ccflyer
City/Region: Bradenton, FL
Vessel Name: Retriever
Photos: ccflyer
PostPosted: Sat Feb 16, 2008 6:30 pm    Post subject: Reply with quote
Delta Fast 22lb
Best price per google serach
$122.99
http://www.boatersworld.com/product/156780306msk.htm
There is a very fine line between "hobby" and "mental illness".
PostPosted: Sat Feb 16, 2008 8:47 pm    Post subject: Reply with quote
Paul,
The Fortress FX 16 is adjustable and was set in the "normal" 32 degree setting. The 45 degree or Mud setting is used for "soft" or minimally cohesive mud. I find that in most muds, the 32 degree setting works fine, and the anchor works down into sand or more cohesive layers.
Lacking a strain guage, I had considered using a 100 lb scale and a lever arm to attempt to measure the load on the rode. But after seeing the amount of force which the majority of the anchors held, I reaslized that it was beyond what would be safe with a spring scale and lever arm.
I may pullling with the Tom Cat--and a 1/2" U bolt attatched to the Armstrong bracket. I was watching the cleat very carefully as I was powering up and there was considerable load. I have always backed down in reverse when power setting anchors. The outboards with smaller props are much less effecient than the larger proped, reduction gear diesel boats--so it is hard for me to estimate the exact amount of static pull (Bollard pull). This is why West Marine and US Sailing use large tug boats and heavy duty strain guages when doing their much more detailed anchor tests.
I was surprised that the Delta, Manson Supreme and Fortress did not drag. I had expected at least one of them to, considering the power applied. The Fortress is too bulky (when put together) to be practical as an anchor. The Delta has the advantage of being a bit easier to secure than the Manson Supreme. I suspect that in some instances, that the Manson will set faster than the Delta...
PostPosted: Sat Feb 16, 2008 8:55 pm    Post subject: Great holding here Reply with quote
Thanks for doing this testing. That's way over the top C-Brat help you're doing, and it is appreciated. I am still looking, and the Manson Supreme or Rocna are way up on the list. Delta is more practically priced, and is looking better all the time. Thanks again, Dr. Bob. Thumbs Up Thumbs Up to you.
Dora~Jean
City/Region: Simi Valley
Vessel Name: Dora~Jean
Photos: Dora~Jean
PostPosted: Sun Feb 17, 2008 12:35 pm    Post subject: Reply with quote
Great info Dr. Bob, thanks. I happened to have a 22-lb Delta, same one for the past 2 boats, haven't had a problem with any of the conditions and bottoms I've used it on, including over 60 mph winds. It has reset consistently in strong or weak winds shifting 90-180 degs, also in Morro Bay where the current switches 180 degs every 6 hours at 4-6 knots. I bought it originally based on test research articles. We have some bottoms around our islands that are mainly pebbles, 1/4-1/2", the danforth I used to use (16 lb) on a smaller boat just skipped, wouldn't set. The Delta always sets in that same area.
The other popular anchor many folks use is the Bruce. I almost bought that one instead (for my 31ft trimaran), but a boater friend relayed an experience he had which changed my mind 12 yrs ago. He anchored by one of our islands, close to shore, near kelp. When the wind piped up, he began dragging his anchor. Brought it up, had an entire kelp root-ball in its grips! The plow type anchor would be less likely to do that I believe, but haven't experienced that.
Last year at the islands I observed a similar situation, a boat having trouble getting a solid set, he had a bruce, brought up a 'grass ball', roots and all -- clogged the flukes.
Please don't get me wrong, not trying to start a delta/bruce or any other kind of war. Some other owners might have other observations on Deltas, would love to hear them or any other anchoring situation that would be useful to share.
Steve & Carmen
MacGregor 26X 1988-1996
Glaspar Seafair Sedan 18 (2)
StarCraft 19 & 22
Catalina 17 & 22
Crestliner 19
PostPosted: Sun Feb 17, 2008 1:01 pm    Post subject: Reply with quote
Thanks for the kind words.
Here are a couple of photos of the Delta vs the Manson Supreme on the anchor roller of the Tom Cat 255. I was not able to upload any other photos of the tests for some reason. Notice how the Delta fits the pin and is secured on the roller. The Manson's slot does not line up with any of the holes in the roller pulpit, so it will have to be lashed in place. I know that the Delta clears the hull of the CD 25. The Manson is a bit longer on the "point"--and I won't know how it sits on the CD 25 roller until I take it out there in a couple of months.
Anchor tests are only valid for those types of conditions which the tests are done in--and should not be translated as being satisfactory in other bottoms. I feel that all of the anchors which held would hold a CD or Tom Cat in up to and including hurricane force winds--in these bottom conditions. I have not had good "luck" with Bruce anchors, so I do not use them. There are some "scoop" characteristics, rather than "plow" effects in the Manson--and it may be a good anchor where the bruce is, as well as places where the bruce does not work as well--but this is only speculation.
Alok
City/Region: League City
State or Province: TX
Photos: Top Cat
PostPosted: Sun Feb 17, 2008 4:29 pm    Post subject: Reply with quote
The Fortress is too bulky (when put together) to be practical as an anchor...
Bob:
Thanks for the info.
I agree with your comment about the Fortress being too bulky as the primary anchor. However, it makes a great back-up anchor. It is flat and very light. I carry a Fortress fully assembled in the locker under the aft dinette seat, cushioned between lifejackets. It seems to live quite comfortably in that location, so I have been lazy about mounting it permanently somewhere.
The rode and chain is in a waterproof container in the port fish box.
Alok
C-Dory Tomcat (Topcat) sold January 2012
PostPosted: Sun Feb 17, 2008 9:13 pm    Post subject: Reply with quote
Bob, that was quite a test. We've had very good luck with the Bruce, both here in So Cal and up in Canada. I'm sure the Manson will work very well.
Regarding the small Danforth not setting, I'm reminded of the first time I want to Santa Cruz Island in the Catalina 22, without much knowledge of boats. As you well know, in most of the harbours there, you have to anchor fore and aft, using 2 anchors. I bought a small Danforth, got some rope and happily set off. Got to Pelicans, set the front anchor, went back threw out the aft anchor, and nothing I did set that anchor. Finally a couple of scuba divers set it for me, by hand. Another learning lesson. I bought 10' of chain for that puppy and, it worked fine from then on.
Also, I looked at the West Marine tests on anchors (2008 catalog on the internet,) and they couldn't get a CQR to set in sand. That's a new one on me.
centerisland
City/Region: Mercer Island
Vessel Name: Lulu
PostPosted: Sun Feb 17, 2008 9:26 pm    Post subject: Reply with quote
I recall past tests (Practical Sailor? Powerboat Reports?) that concluded that the mud setting was almost always a poor choice. However, I think the mud palms can help with setting in many conditions. Plus they're free:
http://www.fortressanchors.com/mud_palms.html
helm
City/Region: Medford
Vessel Name: Chack Chack
Photos: Chack Chack
PostPosted: Sun Feb 17, 2008 9:46 pm    Post subject: Reply with quote
Bob, we have a Manson supreme on our CD-25 and it sits just fine on the bow roller. I had to modify the top roller because of the width of the anchor shank, very easy to do and all in all it is a nice rig.
Best
Eric
dogon dory
Vessel Name: DogOnDory
PostPosted: Sun Feb 17, 2008 9:58 pm    Post subject: Reply with quote
PostPosted: Sun Feb 17, 2008 10:22 pm    Post subject: Reply with quote
Bob:
How about this:
Just leave your Fortress FX-16 assembled and on the bow pulpit as the primary anchor.
This solves the storage and assembly/disassembly problem.
The 31 inch shank is so long it goes back to within a few inches of my windlass, which gives great leverage over the bottom part of the anchor and keeps the pivoting anchor roller locked in the up position.
I have such confidence in this set up that I never lock the anchor up with a pin or lash it down. In fact, I can hang on it with all my 230 lbs. I even considered putting removable stirrups on the anchor and using a remote control for the windlass so as to form a crane or elevator to get on and off the boat when beached, but gave up the idea as being too dangerous. Laughing Laughing Laughing
Bob- Nice work! Thanks!
Page 1 of 4
Page generation time: 0.0875s (PHP: 70% - SQL: 30%) - SQL queries: 27 - GZIP disabled - Debug on
