Simplicity
Vessel Name: Simplicity
Photos: Simplicity
Posted: Fri Jan 18, 2008 9:32 am Post subject: condensation in V berth |
When it's cool we notice condensation on the top of the V berth in the morning. Anyone know how to prevent this? It looks like the
new Venture 23 has an interior covering over the glass.Maybe this will prevent it but I hope moisture doesn't occur under this covering.Thanks for any input. |
Sarge
Vessel Name: Sea Badger
Photos: Gigi
Posted: Fri Jan 18, 2008 9:43 am Post subject: |
Simplicity,
When you notice the condensation, is that after you have spent the night in the v-berth or when you visit the boat in the morning after no one has been in the boat for a while? Is the boat moored or on it's trailer?
Answering those questions will help determine the cause and a possible solution. _________________ -Sarge
2001 2150 Bayliner, sold
2007 CD25, sold
2007 Harbercraft Kingfisher 2850, sold
2011 Stabicraft 2250SC, sold
2011 Eastern 18cc
Blog: http://theseabadger.wordpress.com |
Wandering Sagebrush
Joined: 21 Jan 2005 Posts: 2785 City/Region: Northeast Oregon
Vessel Name: Constant Craving
Photos: Constant Craving
Posted: Fri Jan 18, 2008 9:44 am Post subject: Condensation |
The condensation is most likely from your breath. Most folks keep the hatches open (regardless of outside temperature) to help ventilate the cabin. If it is buggy out, you can cover the open hatch with weighted bug netting.
Yes, the carpeting (for lack of a better term) will help keep things from getting as wet, as will any form of insulation. Several owners have lined the berth and cabin areas with foam insulation, then covered that with a material. |
Simplicity
Photos: Simplicity
Posted: Fri Jan 18, 2008 9:53 am Post subject: |
We noticed the condensation while on the hook in Canada .It was quite cool and didn't have a hatch open because of the temp. |
Dora~Jean
Joined: 09 Mar 2004 Posts: 1518 City/Region: Simi Valley
Vessel Name: Dora~Jean
Photos: Dora~Jean
Posted: Fri Jan 18, 2008 10:32 am Post subject: |
Wandering Sagebrush wrote:
Quote: | Yes, the carpeting (for lack of a better term) will help keep things from getting as wet, as will any form of insulation. |
I've heard it called "monkey fur", I'm tempted to install it on our forward berth area ceiling, although down here in the SW it's generally not a problem to leave the hatch cracked open at night -- unless it rains during our 'winter rainy' season, say from Dec. 20 to Jan. 20.  _________________ Steve & Carmen
MacGregor 26X 1988-1996
Glaspar Seafair Sedan 18 (2)
StarCraft 19 & 22
Catalina 17 & 22
Crestliner 19
+4 Previous, 1/2 sail, 1/2 power |
Dene
Vessel Name: Fear Naut & Terra-Sea-Ta
Posted: Fri Jan 18, 2008 11:59 am Post subject: |
We put a worst marine humidifier in our V-berth when we're gone. Helps a lot. We use it overnight too while we sleep.
-Greg |
lloyds
Joined: 02 Aug 2005 Posts: 1724 City/Region: sublimity
Vessel Name: undecided
Posted: Fri Jan 18, 2008 1:10 pm Post subject: |
If you crack the hatch about 1/4 inch it cuts out about 90 % of the condensation. Always good to have a little fresh air anyway. |
Posted: Sat Jan 19, 2008 3:05 am Post subject: Over Night Ventilation |
Both the forward hatch and the Center window can be opened just a notch, so that the latch catches in the grove of the frame, preventing them from being opened more by just pressure, (as in from the outside), by just reaching under the edge of the widow or hatch cover. Generally, that is enough flow through ventilation to decrease much of the condensation buildup. If not, I will open the non-dockside window slightly. If there is still moisture inside, starting the Wallas, and running the widow fan takes care of it pronto. Hope this is some help.
SleepyC  _________________ Though in our sleep we are not conscious of our activity or surroundings, we should not, in our wakefulness, be unconscious of our sleep. |
Simplicity
Photos: Simplicity
Posted: Sat Jan 19, 2008 9:21 am Post subject: |
Thanks for the info. I guess that NW weather leads to more condensation problems.I'll try the simple solution first-crack the hatch. |
