Towing a 25 ft. cruiser
Dene
City/Region: Kalama
Vessel Name: Fear Naut & Terra-Sea-Ta
PostPosted: Mon Jan 14, 2008 2:02 am    Post subject: Re: Lots of good advice! Reply with quote
Kena B wrote:
Well nothing speaks like to voice of experience! So looks like I need to get some experience towing the CD25 with my truck! I pick the boat up in April in Anchorage and the drive to Fairbanks is about 350 miles and pretty good roads with no real scary grades. No guts, no glory (defined as stupidity). I am going to look into the Leveling hitch sugested from journey on, Boris. My hot rod days are pretty much over so I can take it slow and easy. It's about time I got some revenge for following all those $%^& tourists in motorhomes all summer that drive at 35 mph!
Thanks to all for the welcome and words of wisdom. Hopefully I can reply with a good note in April!
Still have the head cook thinking about a new truck just in case!!!
Don
You raise a good point about going slow and enjoying it. Referring to my trek, I stayed in the "slow" lane on I-5 and Hwy 99, going 60-65 and let everyone pass me. Aside from the hills, I actually relaxed and enjoyed parts of the 2 day, 1200 mile drive.
I do the same now when traveling in my RV. Why hurry.....I'm on vacation.
-Greg
dave
City/Region: Riverview
Vessel Name: Cocoon
PostPosted: Wed Jan 16, 2008 4:04 am    Post subject: Reply with quote
Pay attention to what CW has to say. Also, make sure you never have an accident if your trailer weight is over your 8700# limit. Then guess who is liable. Personally I would not even think about hauling a boat that heavy with a 1/2 ton truck. I like a larger safety factor.
helm
City/Region: Medford
Vessel Name: Chack Chack
Photos: Chack Chack
PostPosted: Wed Jan 16, 2008 6:34 pm    Post subject: Reply with quote
We towed our new CD-25 from Seattle to Medford last week with our Ford F 350 diesel - no problems with that truck. I would suggest using a weight distributing hitch , the equalizer brand can be used with hydraulic surge brakes as it makes the ride much better over long distances and the load just feels more stable.
Dora~Jean
City/Region: Simi Valley
Vessel Name: Dora~Jean
Photos: Dora~Jean
PostPosted: Wed Jan 16, 2008 10:53 pm    Post subject: Reply with quote
Equalizing hitch, you mean like this:
There are more photos of various systems and ideas in the Library section under Trailers and Towing.
Works great, but best to keep the tongue weight within 6-10% of the trailer weight for smooth operation. Some have converted to electric over hydraulic to avoid the surge brakes from engaging the brakes down long hills, expensive but it solves the problem for those that need it.
Steve & Carmen
MacGregor 26X 1988-1996
Glaspar Seafair Sedan 18 (2)
StarCraft 19 & 22
Catalina 17 & 22
Crestliner 19
helm
Photos: Chack Chack
PostPosted: Wed Jan 16, 2008 11:17 pm    Post subject: equalizer hitch Reply with quote
Hi Steve, I believe the easy-loader weight distributing hitch you have in your post won't work with a hydraulic surge brake.
We use a weight distributing hitch from equalizer www.equalizerhitch.com that allows the surge actuater to work. For a pole tongue trailer you need a pole tongue adapter, if you have an A-frame trailer you don't need the adapter.
We have towed our sailboat 26 feet and 4500 pounds with a 2500 pound trailer all over the Northwest with no problems. Our C-Dory 25 was rock solid on the 500 mile trip down from Seattle. They are expensive up front put don't wear out and worth the expense.
Dora~Jean
Photos: Dora~Jean
PostPosted: Thu Jan 17, 2008 12:49 am    Post subject: Reply with quote
Helm, I have no idea why you'd say that! I have 4 wheel Disc brakes, I've towed my boat over 10,000 miles up and down moderately steep hills, the brakes work smooth as silk and is the absolute best setup on any boat I've owned. That entire a-frame looking thing is attached (welded) to an Atwood actuator, the whole assembly moves together, the only way a surge brake system would work properly.
Come take a ride someday, I'd be glad to show you how well it works!
helm
Photos: Chack Chack
PostPosted: Thu Jan 17, 2008 1:12 am    Post subject: Reply with quote
My mistake, I just saw the chains ala easy-lift which is a system that won't work with surge brakes, your system looks great. I think I still like equalizer, less complicated, provideds sway control, and easy to move from trailer to trailer
Dreamer
Photos: Dreamer
PostPosted: Thu Jan 17, 2008 1:30 am    Post subject: Reply with quote
Helm,
Here's the Equal-I-Zer hitch installed. Spendy, but works well.
Dreamer- Sold 25 Feb. 2013
Doryman
Vessel Name: Lori Ann
Photos: Lori Ann
PostPosted: Thu Jan 17, 2008 2:26 am    Post subject: Reply with quote
I have a setup like Roger's too. Had my trailer modified after purchase with electric over hydraulic brakes and equalizer hitch.
I like it because now my boat trailer and my travel trailer hook up the same way.
Doryman
M/V Lori Ann
Anacortes, WA
Dora~Jean
Photos: Dora~Jean
PostPosted: Thu Jan 17, 2008 2:49 am    Post subject: Reply with quote
Helm, yes, I forgot the name and I did 'borrow' them from my travel trailer, they are EZ-Lift. But this system (by Pacific) does let them work good. But like I said, if your tongue weight gets too high and you crank up the tension, the Atwood actuator begins to bind with all that torque placed on it.
Kena B
City/Region: Fairbanks
Vessel Name: C-yalater
Photos: C-yalater
PostPosted: Mon May 05, 2008 10:17 pm    Post subject: I told ya so...... Reply with quote
For all who contributed advice on my question to tow a 25 ft C-Dory with a 1/2 ton truck..... I FINALLY got my boat and drug her to Valdez last weekend and with my 2006 Chevy 1/2 ton 4x4 (350 Alaska road miles). She towed GREAT! I did about 55 average other than the areas that have been know to swallow tourist's motorhomes. Had the back of the truck FULL of stuff to! Made it in 8 hours. On fairly flat roads it pulled great, will admit that going up some of the long steep hills she slowed down to 45 but I sure expected worse!! I did add an equalizer hitch and am covinced that helped consderably. Going down Thompson pass ( a VERY long grade, about 5 miles) the surge brakes worked great! Never felt as though I needed anything else. If I wanted to slow or stop, no problem. For those interested, I have a few pics in my photo album!
So.... for those who said "no way!" to my original question, sorry but you were wrong! For those who said go for it, "You have chosen wisely"
Thanks for the help!!
Don
C-Yalater
[/img]
Every hour you fish, adds an hour to you life!!!
jennykatz
City/Region: naples
Vessel Name: Little Treasurer
Photos: Jennykatz
PostPosted: Mon May 05, 2008 10:37 pm    Post subject: towing with a Honda Reply with quote
I just picked up my cape cruiser 23 from melbourne fl to Naples fl about 230miles We used my 4100lb single axcel trl with brakes . The Honda Pilot did great about 11-12mpg almost the same mileage as towing the c-22 cruiser.You definatly know it s back there but going about 55-60 it worked great . I might end up with a tandem alum trl we will see depending if the duck sells with or without the trailer I love my Honda and my c-dorys
gljjr
City/Region: Fall City
C-Dory Year: 1982
Vessel Name: Migratory Dory
Photos: gljjr
PostPosted: Tue May 06, 2008 12:53 am    Post subject: Re: Towing C-25 Reply with quote
Edward Thieme wrote:
Just to be contrary, I have a C-25 which I tow with a 2005 Nissan Frontier 4X4 with the 4 liter V6 265hp engine and a 6 speed manual transmission. I towed the new boat back to CO, where there are real mountains, from Fife, WA. Last fall went to Lk. Powell which means going over Vail Pass and Eisenhower Tunnel going and coming. No I wasn't the fastest thing on the road but just shifted down going up hill. On halfway level ground maintaining 55mph, the fastest I want to go towing anything, was no problem.
Ed
Ed,
I hope you never get in an accident while towing your boat with that vehicle. More than likely the insurance company will not cover the repairs as you are seriously overweight towing that boat with the Nissan. And the likelihood of getting into an accident seriously increases when you are overweight. It isn't so much being able to PULL the boat as it is being able to control the boat while doing evasive maneuvers or trying to stop.
Remember that max towing capacities are often rated with load leveling hitches. Without that they are often reduced by a thousand pounds or more.
Don (Kena B), Congrats on the new boat.
Gary Johnson
KB7NFG
john schuler
City/Region: Missoula, Montana
Vessel Name: Clara (sold)
PostPosted: Tue May 06, 2008 10:40 am    Post subject: Tail wagging the dog. Reply with quote
I aggree with most posters here. I think you need 3/4 ton or better. I have a
1 1/2 ton dulley. I don't think dulleys are the best for pulling bumper pull
trailers either. When trucks have worn grooves in the highway they tend to wander. With the high prices of fuel you should be able to find a good price.
Good luck.
CoolSmile john schuler CoolSmile
jimandlaurie
City/Region: Puyallup
Photos: Laurna Jo
PostPosted: Tue May 06, 2008 2:33 pm    Post subject: Reply with quote
This towing thing has been visited before ,but is is always good to have someone bring it up, as it is timely with the newer CD owners out here.
That being said....as mentioned in the past we primarily tow our CD-25 with our 2004 V-8 powered VW Touareg. It tows it fine as the Touareg is a really heavy ,almost 6.000 lb vehicle itself, it has plenty of power and the short wheel base helps in tight backing situations. We also have a F-250 4X4 Ford with a 460 in it that we use sometimes. but it uses a lot more fuel than the Touareg. We do get a lot of looks when we go down the road with the Touareg, and of course some glassy-eyed looks when asked what we tow our CD with, but it works for us. Money not being a problem I would use my 2008 T-850 Kenworth that I drive at work if I could, I could then tow the CD and our Travel Trailer at the same time.
Page 2 of 3
Page generation time: 0.0708s (PHP: 68% - SQL: 32%) - SQL queries: 28 - GZIP disabled - Debug on
