Flushing Techniques
Dora~Jean
City/Region: Simi Valley
Vessel Name: Dora~Jean
Photos: Dora~Jean
PostPosted: Tue Oct 30, 2007 10:35 am    Post subject: Reply with quote
My guess is you can't run it with the hose only connection, ear muffs OK. That's per my Yamaha manual, I believe Honda's are same. Must not get enough water into the impeller area for running.
Steve & Carmen
MacGregor 26X 1988-1996
Glaspar Seafair Sedan 18 (2)
StarCraft 19 & 22
Catalina 17 & 22
Crestliner 19
Ashley Lynn
City/Region: Panhandle
Vessel Name: Ashley Lynn
Photos: Ashley Lynn
PostPosted: Tue Oct 30, 2007 12:56 pm    Post subject: Reply with quote
I have a 2007 Suzuki 115 and was told not to run the motor while flushing using the hose port.
After our sea-trial, one of the maintenance techs flushed the motor using the ear-muffs and running the motor. I questioned as to which method was better....ear-muffs while running motor or hose port with motor off?
I basically led to believe that it was just a preference.
Maybe a dealer rigging with Suzuki motors will chime in.
Bob & Nancy (Ashley Lynn)
Boating, where its ok to play with your dinghy!
PostPosted: Tue Oct 30, 2007 3:14 pm    Post subject: Reply with quote
If I leave the engines in the water (salt water) to flush using the flushing port on the side, what good is it? Maybe it gets the salty stuff out of the powerhead? The water pump is still sucking in the salt water!
If I had it in fresh water, I wouldn't need to flush it at all. Maybe without the engine running and with enough fresh water pressure, the water will get all through the engine and it wouldn't be necessary to run it at all?? Question Exclamation
Doryman
Vessel Name: Lori Ann
Photos: Lori Ann
PostPosted: Tue Oct 30, 2007 3:33 pm    Post subject: Reply with quote
Not if you tilt the motors up & out of the salt.
Doryman
M/V Lori Ann
Anacortes, WA
Alok
City/Region: League City
State or Province: TX
Photos: Top Cat
PostPosted: Tue Oct 30, 2007 3:44 pm    Post subject: Reply with quote
Charlie:
Am I missing something? I have 150 Suzukis that are used in salt water. I flush them in the water with the engine off and the motors vertical (prop in the water). With the engine off, the water pump is not sucking anything.
I run fresh water using a garden hose attached to the flushing port for about 5 minutes each, with the water draining through the pee-hole . This is an approved way of doing it as per the manual.
Alok
C-Dory Tomcat (Topcat) sold January 2012
PostPosted: Tue Oct 30, 2007 4:08 pm    Post subject: Reply with quote
The problem using the flushing port, is that the water pump housing and lowest part of the housing/intake is not flushed with fresh water. You can probably get away with flushing using the port, as long as you peroidically run some "salt away" thru the lower unit, and replace the impeller regularly.
On the CD 25, the previous owner had not raised the lower units out of the water for the entire 3 seasons he had used the motor--and I suspect that he didn't flush the engines. Only 120 hours on the engine. There was some corrosion on the external part of the lower unit, but none on the internal part. There was some minor salt crystal build up in the pump discharge, but again not bad. I flushed the engine with "Salt away" (it kills the grass!, so the Admiral was not too happy!) The impeller and housing looked to be fine.
PostPosted: Tue Oct 30, 2007 4:23 pm    Post subject: Reply with quote
Alok wrote:
Charlie:
Thanks. I'm concerned about flushing salt out of the lower unit and the impeller areas. Do you see water coming out of the intake ports of the lower unit when you do it? If so, maybe that at least gets flushed and then fills up with salt water again...
westward
C-Dory Year: 1985
Vessel Name: TBD
Photos: Steady Eddy
PostPosted: Tue Oct 30, 2007 7:57 pm    Post subject: Reply with quote
maybe I've missed it from earlier, but does anyone who has installed Permatrims use the flushing bag? Mike.
PostPosted: Wed Oct 31, 2007 9:18 am    Post subject: Reply with quote
I've got permatrims ordered for my Suzi 115's and I have a flushing bag. I'll see if it will go in after they're delivered.
Jazzmanic
Photos: C-Dancer
PostPosted: Wed Oct 31, 2007 1:38 pm    Post subject: Reply with quote
Good point, Mike. The Permatrim on our Suzuki 90 (same engine as the 115) is really big. I'm not sure if the flushing bag will wrap around it. I can't wait to hear Charlie's findings.
Peter
CAVU
City/Region: Spokane
Vessel Name: CAVU
Photos: CAVU
PostPosted: Wed Oct 31, 2007 2:09 pm    Post subject: Reply with quote
Constant Craving,
Something you mentioned early on in this thread caught my eye. You said you were using ear muffs to flush your Honda 8. My Honda 8 came with a special rubber hose fitting for flushing the engine. Normal ear muffs do not work. I think the side holes on the lower unit are not intake ports and that could explain why your impeller fried?
Ken Trease
22 CD Cruiser, CAVU
Twin 40HP Hondas
PostPosted: Thu Jun 10, 2010 6:41 pm    Post subject: Reply with quote
Captains Cat wrote:
Steve, we use one of these for flushing. Works in/out of the water...
If any of you use these flushing bags, make sure you store them in a rodent proof bag. Got mine out about two weeks ago to demo the Honda 35 on the 16 Angler that Dragonfly bought and found it totally "moused". Holes all over the place. It's a heavily rubberized plasticlike fabric. Totally ruined.
petemos
State or Province: NS
Vessel Name: C-You-Later
Photos: C-You-Later
PostPosted: Fri Jun 11, 2010 1:33 pm    Post subject: Reply with quote
I've got permatrims on my Suzi 115's and I have a flushing bag, which I don't use anymore. It's kind of tight to get it in the bag, plus on my boat and trailer you have to put the bag on a platform to get it high enough. Then it is a pain to get it off and or wait for it to drain. I'm back to using ear muffs when out of the water and the flushing port on the side in the water. You can run the motor while you are using the port as it does not flush the water pump and would cook the impeller.
Mighty Bite
Vessel Name: Mighty Bite
Photos: Mighty Bite
PostPosted: Fri Jun 11, 2010 4:17 pm    Post subject: Reply with quote
The flushing bags are a great way to go, but with the Permatrim it's
going to be necessary to have Quality make up a special sizing, which
I think they will do w/o a problem, but probably for a additional cost.
They are pretty good folks and I don't think it would be a big deal.
(ref, Suzy 90 & 115).
I've been using their bags for years and would have a larger bag
made up if I wasn't at a point where I'll probably be putting 3rd Byte
up for sale.
Mark on Mighty Bite
Jack in Alaska
C-Dory Model: 26 Pro Angler
Vessel Name: HIGH TIDE II
Photos: HIGH TIDE II
PostPosted: Sun Jun 13, 2010 3:48 am    Post subject: Fresh water flush Reply with quote
How about using a 55 gal plastic drum cut down to fit your height etc. A 30 gal could be used on smaller engines.
I have a 55 gal and will cut it down for my 200 hp Honda.
Where do you obtain the salt-away???
No. CD026021I405; AK-5008-AK
MSSI No. 338143486(cancelled)
Stolen & stripped in Aug. 18
Page 2 of 3
Page generation time: 0.0514s (PHP: 66% - SQL: 34%) - SQL queries: 28 - GZIP disabled - Debug on
