cabin engine noise in 16 & 19 c-dory's
oldgrowth
City/Region: Rochester
Vessel Name: C-Voyager
Photos: C-Voyager
PostPosted: Sun Oct 07, 2007 6:44 pm    Post subject: cabin engine noise in 16 & 19 c-dory's Reply with quote
There have been many threads on the noise generated in the cabin on the C-Dory’s without a cabin bulkhead. I have been trying different things to lessen the engine noise inside the cabin. The foam rubber you see on the engine has made a big difference.
I now have to figure out a way of building something that will not interfere with either engine when they are turned or raised. It has to be mounted to the engine and easy to remove. I would like something that can be layered and shaped around the engine but not against it, like lead flashing but much lighter.
Building something really is not the problem, it is, I would like something besides thick foam for the insulation and would prefer something that could be layered in the enclosure.
Anybody know of a good sound insulation material that is light and thin?
________
Doryman
Vessel Name: Lori Ann
Photos: Lori Ann
PostPosted: Sun Oct 07, 2007 6:50 pm    Post subject: Reply with quote
How about this stuff, which is used to reduce sound in diesel trucks?
Doryman
M/V Lori Ann
Anacortes, WA
CAVU
City/Region: Spokane
Vessel Name: CAVU
Photos: CAVU
PostPosted: Sun Oct 07, 2007 7:55 pm    Post subject: Reply with quote
Dave there was a post recently about using a plastic called Kydex which is thermo-moldable. Maybe you con fabricate a close fitting cover using Kydex and the insulation mentioned by Warren?
Ken Trease
22 CD Cruiser, CAVU
Twin 40HP Hondas
PostPosted: Sun Oct 07, 2007 9:37 pm    Post subject: Reply with quote
Dave-
Why not cut your boat in half (again) and add four feet and an inboard engine and a heavily insulated cowl?
PostPosted: Sun Oct 07, 2007 10:03 pm    Post subject: Reply with quote
Joe - if he keeps adding feet, eventually the engine will get far enough away that he can't hear it from the helm. Problem solved if ya' ask me.
PostPosted: Sun Oct 07, 2007 10:18 pm    Post subject: Reply with quote
Roger-
Yeah, pretty soon he's gonna have a Panga-Dory, and then one of those super-long river canoes you see on the travel films from Africa! Then he can arrange passengers from front to rear in First Class, Business, Economy, and Engine Compartment/Deaf Only.
Joe. Rolling Eyes
PostPosted: Sun Oct 07, 2007 10:23 pm    Post subject: Reply with quote
The stuff you want is called Aerogel.
Jimbo
City/Region: Maple Ridge
C-Dory Year: 1981
C-Dory Model: 22 Classic
Vessel Name: Cheyenne
Photos: Cheyenne
PostPosted: Sun Oct 07, 2007 10:48 pm    Post subject: Reply with quote
Ever thought about building a bulkhead Shocked
Jimbo
oldgrowth
Photos: C-Voyager
PostPosted: Sun Oct 07, 2007 11:00 pm    Post subject: Reply with quote
Ken - I remember Kydex being discussed a few weeks ago but until I went on their site, I never realized all the things that can be made with it. It certainly appears it should work and Warren’s idea for the insulation looks like it would work.
Using the single sided insulation inside the engine cover could also help. I would like to know how thick the stuff is.
Anybody have any ideas on how thick of a sheet of Kydex I would need? I was thinking of a ¼ inch.
________
tsturm
City/Region: Soldotna
Vessel Name: JMR TOO
Photos: JMR-TOO
PostPosted: Sun Oct 07, 2007 11:02 pm    Post subject: Reply with quote
Jimbo
Ditto
oldgrowth
Photos: C-Voyager
PostPosted: Sun Oct 07, 2007 11:09 pm    Post subject: Reply with quote
Mike – Aerogel looks like it would work, but is un-available in anything except small granular pieces. I wonder if it would work if several layers of grains were glued to the inside of the engine cover or to a cover of Kydex over the engine.
It seems to me if Aerogel was used it would have to have a protective coating over it to keep it from chipping off. Would it then still have the sound insulating qualities?
Jimbo – adding a bulkhead to the 16 Cruiser is all but impossible and it would make the cabin way too cramped.
________
dotnmarty
City/Region: Sammamish
Vessel Name: LIZZIE II
Photos: Lizzie
PostPosted: Mon Oct 08, 2007 10:32 am    Post subject: Reply with quote
Here's an alternative
http://www.bose.com/controller?event=VIEW_PRODUCT_PAGE_EVENT&product=headphones_anc_subcategory&ck=0
MartyP
oldgrowth
Photos: C-Voyager
PostPosted: Sat Oct 13, 2007 1:45 pm    Post subject: Reply with quote
Marty - I read all I could find about the Bose noise cancelling headphones and still am not sure what they do. Head phones that block all sound, the radio and people’s conversation will not help.
If they are not plugged into a radio can you still hear it?
They are kind of expensive but if they block engine and water noise but not radio and conversation they may be worth it. It would be $600 for the two of us.
Anybody have any experience with them?
________
PostPosted: Sat Oct 13, 2007 3:27 pm    Post subject: sound canceling headphones Reply with quote
Dave,
I occasionally fly with my boss, and we use headphones with intercom mic's in the plane. Maybe, the VHF's could be set up like the plane set. On the question about Kydex thickness. I'm pretty sure it comes in 1/8, 3/16, and 1/4. It is realativly easy to heat mold and can be worked (cut, drilled, sanded) cold. I don't know about welding, I think not. but it is quite durable. As with a lot of plastics, it may have issues with vibration. Wish you the best with this new project.
DaveS
City/Region: Arlington
Vessel Name: Sea Shift
Photos: Sea Shift
PostPosted: Sat Oct 13, 2007 7:08 pm    Post subject: Reply with quote
oldgrowth wrote:
Anybody have any experience with them? [/b][/size][/color]_______
Dave, we utilize earphones now on all of our emergency apparatus in the fire service to "deaden" the noise of the siren and airhorn. They also come equipped with a "push to talk" button on the earphones so you can transmit over your radio. All personnel in the unit are able to converse with them in normal conversation.
Additionally, we have the same set-up on our Fire/Rescue boat. One of the headsets has an extended cord so that the firefighter operating the water cannon located on the vessel's bow can communicate with the helmsman. (The Hale water pump on the bow makes A LOT OF NOISE!, making it impossible to carry on a conversation without the headsets).
After my 30 years under sirens, I can't hear much anyhow......particularly my wife when she talks to me... Rolling Eyes
Dave S.
"Sea Shift"
C-Brat #16
Page generation time: 0.0535s (PHP: 68% - SQL: 32%) - SQL queries: 28 - GZIP disabled - Debug on
