30' C-Dory Catamaran/Black Feather
Gratitude
City/Region: Costa Mesa
C-Dory Year: 1992
Vessel Name: C Pelican
Photos: C Pelican
PostPosted: Wed Oct 03, 2007 10:44 am    Post subject: 30' C-Dory Catamaran/Black Feather Reply with quote
It appears that the original molds for the 30' C-Dory catamarans are being used again in production.
http://www.blackfeatherboats.com/
I have been in contact with the president Gregor Welpton.
and they have some impressive gallons per hour fuel burns. He wrote:
With Honda 225's we are seeing through several boats a fuel consumption
of 9 gallons per hour @ 4200 rpm - giving a cruise of 29 - 30 knots.
This seems to be the real sweet spot for the boat.
With Suzuki 250's we are seeing a burn of 10.5 at 4300 giving a cruise
of 32-34 knots depending on loading. This data comes from 3 separate
charter vessels this summer each with over 500 hours run time. When run above the cruise, fuel consumption does climb dramatically -
although I don't have any solid data for burn at full throttle. 30 knots
seems fast enough for most.
By the way - these burn rates are for engines combined - not per.
Gregor
I would be curious to know how these fuel burn rates compare with both the TomCat.
Gratitude is one of the shortest lived emotions on the face of the earth. Make the time to thank others for their help and kindness.
Doryman
Vessel Name: Lori Ann
Photos: Lori Ann
PostPosted: Wed Oct 03, 2007 11:11 am    Post subject: Reply with quote
I have been keeping my eye on this boat for some time. One of our members worked as a fishing guide out of the Juneau area last summer and one of the boats in their fleet was a ChillKat. THIS THREAD has a little information (unfortunately, not good) on the company and the boat.
Please keep us posted on what you find out!
Doryman
M/V Lori Ann
Anacortes, WA
B~C
City/Region: Bend
Vessel Name: Blue~C
Photos: Blue~C
PostPosted: Wed Oct 03, 2007 2:43 pm    Post subject: Reply with quote
hey there, I ran around some in hull #1. I liked it, thought it rode and handled well and made a helluva great fishing platform. I don't know what to make of those fuel figures as the fuel monitor would generally read about the same as the speed, ie, 19knt- 19gpm, 23 kts-23gpm and the gallons squirted in the tank every three days kind of backed those numbers up. this boat had a pair of 250-225? yamaha's. maybe I should have ran it 30knts and saved some fuel, or maybe I should have raised the kicker or brought in the sea anchor Smile
I think most of the grumbling about the CK was due to two things, it was hull #1 and there where some birthing issues and also in the fleet where a pair of very heavy 34' Baja Cruiser cats...naturally the lighter weight CK isn't going to ride as nice as the bigger cat which it was compared to
here is a link to the original C-Dory 30' performance specs
http://web.archive.org/web/19981206135614/www.c-dory.com/30phperf.htm
Ken
1999 22' boaterhome
bjidzik
City/Region: Juneau
Vessel Name: Betty Joe
Photos: Betty Joe
PostPosted: Wed Oct 03, 2007 3:02 pm    Post subject: Reply with quote
I got a chance to look at the ChilKat 30 at the Juneau Boat Show this year. The boat on display was rigged as a charter or sport fishing vessel, but they are listing options for a cruiser version.
Unfortunately, I didn't get a chance to take one out (yet). They cost significantly more than a Tomcat, but they're being built locally in SE Alaska. I'm not sure how many they produce each year.
Larry H
City/Region: Tulalip,
C-Dory Year: 1991
Photos: Nancy H
PostPosted: Wed Oct 03, 2007 4:37 pm    Post subject: Reply with quote
Hi all,
I saw a 30 Black Feather cat at Craig this summer. I have lots of photos, which I will post latter this winter when I have some time.
The boat was in used by a fishing lodge to take out charter fishermen. It had twin 225 Hondas, one of which was getting a new lower unit at about 200 hours. The mechanics changed the lower unit right in the water at the dock. The boat was a walk around charter fishing model, and seemed well made.
Larry H
A C-Brat since Nov 1, 2003
PostPosted: Fri Oct 05, 2007 7:06 pm    Post subject: Reply with quote
I would tend to believe the origional C Dory Tom Cat preformance numbers, rather than current claims. The Tom Cat 255 gets from 2 to 2.3 miles a gallon at max effeciency planing speeds. The boats have simlar hulls--the Chilkat has higher tunnel clearance, wider spacing of the hulls and wider beam, plus it weighs more.
I also considered it--but it is not easily trailerable--that is it requires a permit. I think they are great boats, and hope to see a cruising model next summer....
Page generation time: 0.0437s (PHP: 66% - SQL: 34%) - SQL queries: 19 - GZIP disabled - Debug on
