Chines and tracking
bmacpiper
Vessel Name: Big Blue
PostPosted: Fri Sep 07, 2007 2:34 am    Post subject: Chines and tracking Reply with quote
Hi all,
Posted a while back about following seas, and have been experimenting with them since then. I've learned a lot and have gotten much more familiar with the dory. One thing I notice is that the boat is very willing to slip sideways and/or roll when I'm quartering off the following seas, which makes for a lot of work on the wheel and throttle.
I searched this site for past discussions on adding chines or keel strips, and found a little info, but mainly it was relating to much older C-Dorys. I am still wondering whether anyone with a more recent hull has added chines, what the results were, etc. Are there pre-fab kits, or would I need to glass these on myself?
Any strong arguments for or against?
Other than this handling issue, I have been having high times with the new boat--finally got the new garage door installed so she fits at the house now.
tx,
bmc
bmc
"Do it today, you may not pass this way again!"
2005 16 Cruiser, "Natural Blue", sold 2009
2004 19 Angler, "Crush", sold 2012
2007 22 Cruiser, "Big Blue", purchased 2012
PostPosted: Fri Sep 07, 2007 10:00 pm    Post subject: Reply with quote
bmacpiper, you rally have me confused. The C Dory by defination is a hard chine boat. What do you want to modify? Chine
:Nautical. The line of intersection between the side and bottom of a flatbottom or V-bottom boat.
One of the reasons that the semi dory hull forum is very seaworthy is that is will slide sideways and not trip on a keel or a deep V.
I think that you would negate some of the seaworthy properties of the hull form by adding a keel.
Alasgun
Guest
PostPosted: Fri Sep 07, 2007 10:06 pm    Post subject: Chines and Tracking Reply with quote
I can relate. Until I discovered a simple tool that made those necessary snap moves a snap, I endured following seas and all that came with them.
It seemed I was neither agile or fast enough to out steer them and the fun meter was way low.
When I discovered the "Steering Ball", suicide ball, whatever, my woes ended. I built mine, have used it all year and would not own a boat without one. Yep, it helped that much.
Might think about giving er a try.
Mike
bmacpiper
PostPosted: Fri Sep 07, 2007 10:50 pm    Post subject: Chines Reply with quote
Thataway: From Chapman's, "Some modern boats are designed with multiple chines (longitudinal steps) for a softer ride at high speeds in rough water; this is often referred to as deep-vee design. Larger round-bottom vessels may be built with bilge keels--secondary extenal keels at the turn of the bilge that reduce the vessel's tendency to roll in beam seas."
So here's what I'm after. In a following or quartering sea, the dory slips sideways and rolls a lot. It is very discomforting and takes constant attention to the wheel and throttle. What I'm thinking about is two chines that run from the transom forward, roughly halfway between the mini-keel and the turn of the bilge on each side. They would be triangular in cross-section, with a vertical side towards the keel, and a tapered side towards the gunwale. Thought being that it would resist sideways motion (slip/yaw and roll), but not affect forward motion/drag. I would expect it would take a vertical face of 1.5 to 2 inches at a minimum to affect much change, but that's the question: what have others done to address this, what results, etc.???
Alasgun: do you have a link for this? I'll google as well, but if you know of a good location for one...
Thanks to all,
bmc
tsturm
City/Region: Soldotna
Vessel Name: JMR TOO
Photos: JMR-TOO
PostPosted: Fri Sep 07, 2007 11:47 pm    Post subject: Re: Chines Reply with quote
[quote="bmacpiper"]
Buy a different boat? What I do in following seas is trim motor way up & gass it, if you are being overtaken by the wave behind you you are not in the throttle enough! It is amazing how much BIG WATER these little boats take!!!
Good luck! Mr. Green Beer
PostPosted: Sat Sep 08, 2007 12:01 am    Post subject: Reply with quote
You have a semi dory--this is a type of hull. With it come some good features. This is also what I mean by people buying a C Dory and not understanding the boat.--I am not picking on you--but you want a different type of boat, or so you think. You cannot make a semidory into a deep V by adding strakes. If you drive a deep V in a following sea, you may very rapidly change your mind. The deep V is more in its "element" going into seas.
By attempting to put some strakes,--and that is what you are describing--not chines--(chines are a part of the hull, and you cannot change that), you will seriously modify the handling of the C Dory. 1.5 to 2" bilge keel will do nothing, but perhaps slow the boat down a little. I can tell you what you are suggesting will not work--and it may cause other handling problems.
As tsturm says, you have to drive the boat so it stays on the back of the wave--and work thru the seas--this is the nature of this little sea worthy boat! Some dealers have recently started carrying a different brand of a hull which is a down east type of hull; it has a keel, and there have been some folks who didn't understand that type of boat and were terrified by it in the same type of conditions you describe.
Doryman
Vessel Name: Lori Ann
Photos: Lori Ann
PostPosted: Sat Sep 08, 2007 2:09 am    Post subject: Re: Chines Reply with quote
Please clarify for me what trimming the motor way up does for you under these conditions.
Doryman
M/V Lori Ann
Anacortes, WA
bmacpiper
PostPosted: Sat Sep 08, 2007 2:24 am    Post subject: Chines Reply with quote
thataway--
OK, we can argue about what they're called--strakes or chines--but you get the idea. I don't want a different type of boat, I want to improve the one I have (if it is indeed possible).
So you mention slowing the boat down, it won't work, and possibly inducing other handling problems. Please elaborate, if you care to. Generic statements like that are not helpful unless you can help me understand the why of the matter. Are you saying that the sideslip and roll make the dory more seaworthy? If so, why?
tx,
bmc
Alasgun
Guest
PostPosted: Sat Sep 08, 2007 3:41 am    Post subject: Chines and tracking Reply with quote
Very seldom do I make throttle adjustments, generally finding a workable setting and concentrate on the steering. With a ball, split second changes are easily accomplished. I find myself making corrections just before they are needed and can actually maintain a good course thru a most uncomfortable sea. We have several locations in Prince William Sound where a confused chop / sea condition exist and when combined with any wind a real challenge exist. I have literally been thrown out of my seat on a couple occasions when trying to negotiate these areas BEFORE I got onto the steering ball.
Someone on this site got me thinking about these balls a while back and I believe their post related to docking. Believe me, it will help more than your docking. A side benefit is my 4 yr old grandson can steer quite well by getting on his knees and using the ball.
The better marine sites list an Edison brand which runs upwards of $50, ebay has some automotive types for under $20.
One more tidbit that will reap a long term benefit, be patient , there are some real sailors on the site who are quite willing to help out.
Mike
iggy
City/Region: Hillsboro, OR
Vessel Name: Edward Gallaher
PostPosted: Sat Sep 08, 2007 3:59 am    Post subject: Reply with quote
bmc -
With all due respect, you are asking some very difficult questions. Experienced marine architects debate these issues endlessly, leading to dozens and dozens of of hull designs, optimized for various conditions.
When I took a Power Squadron course, they spent several hours describing the pros and cons of various hull types, barely scratching the surface! Round bottom displacement hulls sit down in water; they don't plane, they go slow, but they carry a lot of cargo, and are very economical to move through the water. OTOH, they roll terribly without some sort of stabilizers. Deep-V hulls cut through the chop more smoothly and reduce pounding, but require higher speeds, and therefore much more power (and fuel) to get up on a plane than a flatter dory hull. The C-Dory planes very easily, but tends to pound at higher speeds. A C-D might have to slow down for a more comfortable ride, but it will still stay up on a plane at these intermediate speeds. If a deep-V slows down much, it drops off the plane and must go much slower -- there's no 'intermediate'.
All designs are compromises, and many are hybrids (semi-displacement hulls; fast trawlers), but each feature provides its own advantages and disadvantages under different conditions.
These comments do not directly address your handling questions, However, it is very unlikely you are going to 'improve' the handling of your current boat any more than you'd be able to re-design (and build) a new suspension for your car. (Sprung weight; un-sprung weight; tire size, width, pressure; spring coefficients; shock absorbers; wheelbase; turning radius; not for the faint of heart!) It is MUCH more likely you will make the hull worse -- maybe dangerously worse.
You mention 'slipping' and 'rolling'. The 'rolling' may not be comfortable, but if I understand what you are saying, the 'slipping' is actually preventing even more rolling. Your proposed design could cause the hull to 'catch' as it attempts to slip sideways -- if you think you're rolling now, you ain't seen nothin' yet!
I'm sure Bob will comment further, but the practical goal should be to learn how to handle your current hull under a variety of circumstances, and/or know when and how to avoid those circumstances if necessary. If those circumstances are common, and you want to be out there under those conditions, and the boat simply does not handle to your satisfaction, you may indeed be better off with a different hull design altogether.
Good luck!
iggy
ffheap
City/Region: Hingham
C-Dory Year: 1983
Vessel Name: Inn-The-Water
Photos: Inn-The-Water
PostPosted: Sat Sep 08, 2007 7:27 am    Post subject: Reply with quote
Hi Folks,
When I took my 1983 C-Dory across Nantucket Sound in 25 to 35 Knot winds, I had the wind on my port bow, and had to "play" with the wheel as the waves came by. When a big one came, the boat just rose with the wave,and the wave went under the boat. (In breaking seas it might had been a different story.) The boat responded beautifully, but it was a lot of work.
Would I ever do it again? No. Am I glad I did it? Yes. I got to see how the C-dory handled rough seas and high wind. Just beautifully.
Fred
Fred
1TUBERIDER
City/Region: Crescent City
PostPosted: Sat Sep 08, 2007 10:21 am    Post subject: Reply with quote
Hi Bmacpiper
IMHO you should not change your boat.
One thing to consider is your load. How much excess weight is forward?
The main tools are your helm and throttle. I like to stay on top of the swells in a following sea. I back off throttle when it feels like I am dropping into the swell. If the swell passes you can throttle up and stay on the back of the swell, this is a safe place. When a swell lifts you, if your not into surfing it, then back off throttles till you are on top, then throttle up and stay there.
I am not talking about doing this in breaking waves. Then you want to be on the back of the swell or better yet in port. Practice, practice and practice.
1tuberider
Sea ya
tsturm
Photos: JMR-TOO
PostPosted: Sat Sep 08, 2007 12:15 pm    Post subject: Re: Chines Reply with quote
It keeps your bow from digging into the wave in front of you. Kind of allows you to ride the back of the wave in front of you! Mr. Green Beer
bmacpiper
PostPosted: Sat Sep 08, 2007 12:27 pm    Post subject: Chines Reply with quote
Thanks again to all--I do appreciate the varied input. Of course my first choice is avoidance of the seas mentioned, but I also want to be ready if and when I get caught, which we all do. For now I'll keep practicing and getting comfortable--I had made a decision when I bought the boat not to make any significant changes until I have at least a year behind me, and this is no exception.
Looking forward to meeting some of you down the road!
bmc
Doryman
Photos: Lori Ann
PostPosted: Sat Sep 08, 2007 12:36 pm    Post subject: Re: Chines Reply with quote
Doesn't that increase the chance that the props will be out of the water more as you rock forward and aft with wave motion?
This is not something I have experienced yet, so I am not trying to be contentious, just trying to understand what I should do when confronted with those conditions!
Thanks again,
Page generation time: 0.0719s (PHP: 73% - SQL: 27%) - SQL queries: 26 - GZIP disabled - Debug on
