Setting up,a trailer for CD 22
snal
City/Region: Asheville
C-Dory Year: 1994
Vessel Name: Thelma Lou
Photos: Thelma Lou
PostPosted: Sun Aug 12, 2007 5:25 pm    Post subject: Setting up,a trailer for CD 22 Reply with quote
Our new (1994) CD 22 Angler has a bunk style trailer, and I'd like to make sure that the bunks are positioned correctly. Right now the bunks are positioned roughly 8" inside of the chines. Does anyone know if this is correct, or is there a "stronger" area where the bunks should be located?
Also, there are no rollers anywhere at the keel, just one "v" roller at the bow winch, and the bunks are roughly 8' long.
Snal~
(Larry and Jo)
1994 C Dory 22 Angler (sold 2012)
Currently looking for a steal of a deal on a 25' "Thelma Lou II"
PostPosted: Sun Aug 12, 2007 6:06 pm    Post subject: Reply with quote
We also had a roller at the very aft center of the trailer frame, to avoid the bow from hitting the frame. The 8" in sounds fine. There is no specific strengthening area--the best braced area is the outside chines, because of the hull acting as an "I" beam.
snal
C-Dory Year: 1994
Photos: Thelma Lou
PostPosted: Sun Aug 12, 2007 6:51 pm    Post subject: Reply with quote
Thanks Bob...this trailer has V shaped crossmembers with plastic guards to prevent the keel from striking them. I just wasn't sure if the bunk placement was correct, and offered enough support.
Thanks!
416rigby
Vessel Name: Foggy Dew
Photos: Foggy Dew
PostPosted: Sun Aug 12, 2007 7:22 pm    Post subject: Reply with quote
We have a tandem axle Pacific with no rollers. Works great. We've found that it's easiest to launch and recover at ramps that have a more shallow angle as opposed to steep ramps.
Also, if your trailer doesn't have long side guides, you'd be wise to check into a set. They add lateral support while trailering and make getting her on the trailer a lot easier, especially when the wind is blowing.
snal
C-Dory Year: 1994
Photos: Thelma Lou
PostPosted: Sun Aug 12, 2007 8:39 pm    Post subject: Reply with quote
Yep!...I plan to fab up a set of side boards, that, and getting the controls slicked up will make loading a breeze.
Page generation time: 0.0298s (PHP: 58% - SQL: 42%) - SQL queries: 18 - GZIP disabled - Debug on
