Rub Rail
pcator
City/Region: Fletcher
Vessel Name: Donna Marie
Photos: Donna Marie
PostPosted: Wed Jul 11, 2007 8:05 am    Post subject: Rub Rail Reply with quote
Any ideas on reinstalling rubber part of the rub rail?
PostPosted: Wed Jul 11, 2007 9:35 am    Post subject: Reply with quote
I did mine a couple of years ago, hard to find one that fit right. If it's too tight, you can't slide it in, if it's too loose, it doesn't fit right. Make sure it's a little longer than you think it needs to be, somehow it "shrinks"!
PostPosted: Wed Jul 11, 2007 12:21 pm    Post subject: Re: Rub Rail Reply with quote
My rubber rail insert sometimes comes out of the metal extrusion when I "kiss" the dock a bit too hard while docking in wind. That's easy to fix, however, as I just push the flange part of the rubber part back into the metal part using a big flat-bladed screwdriver. Work altneranately on the top and bottom part of the flange parts, pushing them inward and under the metal extrusion.
Some folks have done this using a heat gun (or hair dryer), but I've not seen the necessity of using heat to soften the rubber. Maybe during a cold winter, though?
I've thought of adding a flexible sealer like a black windshield calking compound to help glue the rubber part into the metal part, but always been afraid of making a big mess that would be hard to deal with later when something required disassembly of the rail. I suppose it would be smart to do a two foot section first and see what, if any, problems develop.
For replacing the rubber insert and/or metal part, the C-Dory factory has been able to supply the parts necessary. See the following discussion: Rub Rails and End Caps.
Good luck and let us know how it goes!
Joe. Teeth
PostPosted: Wed Jul 11, 2007 12:47 pm    Post subject: Reply with quote
I do the same as Joe--use a large screw driver about a half an inch wide blade--much less likely to cause damage to the rail.
therevdr
City/Region: Lake St. Clair
Vessel Name: DRIFTWOOD DREI
PostPosted: Thu Jul 12, 2007 12:25 pm    Post subject: Reply with quote
Just some input that takes the discussion line in a direction that may be a little different - >
On a previously-owned non-C-Dory boat, I substituted a color-coordinated line for the rubber insert on the rub rail. It looked sharp and it seemed to do the job. The trick is to get line with a large enough diameter so that it is both tight and bulges out enough to act as a bumper.
It really is an old-fashioned rub rail set-up.
therevdr on Driftwood Drei
PostPosted: Thu Jul 12, 2007 3:48 pm    Post subject: Reply with quote
Joe's old link in the old thread doesn't work anymore but this one does. It looks like the same thing.
http://www.tacomarine.com/item--1-1-2-x-5-8-Aluminum-Rub-Rail--A11-0312.html
The home page for that company has a lot of info on it on installation/etc.
Page generation time: 0.0301s (PHP: 63% - SQL: 37%) - SQL queries: 19 - GZIP disabled - Debug on
