Glue
OOPS
City/Region: Kamloops
C-Dory Year: 1998
Vessel Name: OOPS
Photos: OOPS
PostPosted: Sun Jul 01, 2007 11:47 pm    Post subject: Glue Reply with quote
Can anybody tell me what glue to use when gluing starboard to fiberglass???
Rusty
Almas Only
City/Region: Richmond
Vessel Name: Alma's Only
Photos: Alma's Only
PostPosted: Mon Jul 02, 2007 6:35 am    Post subject: Reply with quote
I use one of two methods. One, glue pressure treated wood to the fiberglass, then screw the starboard to the wood, or, two, drill a bunch of small holes, at various angles, into the rough side of the starboard, and then use 4200 to attach it to the fiberglass. This accomplishes the attachment with a mechanical bond, which works in some circumstances. Don't try this with anything which will be submerged, or which will create a problem if the bond fails.
The following site is more on point to your question, but I don't have personal experience with the product discussed. If you get some, let us know how it works.
http://www.kingplastic.com/InfoCenter/glue.aspx
2003 CD22 Cruiser with Honda 90
PostPosted: Mon Jul 02, 2007 10:19 pm    Post subject: Reply with quote
Agree, that I have only used mechanical fasteners, with King Starboard. I do slightly differently, but similar technique. I make multiple oblique cuts with a Dremel disc--at about 45 degrees to the surface, and then smear the surface with 5200. Basically the holes, or cuts will give something for the adhesive/sealant to bite onto. But, I still use screws or bolts.
Page generation time: 0.0289s (PHP: 58% - SQL: 42%) - SQL queries: 16 - GZIP disabled - Debug on
