Trolling a Tom Cat at 1 mph
Goto page Previous  1, 2, 3
PostPosted: Mon May 28, 2007 12:11 pm    Post subject: Reply with quote
The Tohatsu/Nissan only steers from the handle. It has a clutch (neutral)--360 degree rotation--so you even get a "stern thruster" in the deal...!
I agree that the dinghy motor is the simplist and cheapest--and that is what we use. The second feature of this is, that since the prop is between the tunnels, you can run the boat in just an inch or two of water deeper than the hulls.
I am not so sure about the linkage--this again gets complex. The main motors have enough rudder effect at a knot or to to allow rough steering. If you have to make radical movements, then fire up the mains, or use the PVC to steer the small outboard.
Doryman
Vessel Name: Lori Ann
Photos: Lori Ann
PostPosted: Mon May 28, 2007 12:19 pm    Post subject: Reply with quote
Joe,
Yes, I have an aft steering station on the TC. I also have an autopilot which I really want to keep operational with the small engine.
I don't believe it will be necessary to tie the Tohatsu to both Yamahas. Those are already tied together. I just need to tie the Tohatsu to one of them and hopefully that will work. I've asked EZ-Steer for more info. Why were you suggesting linking the small engine to both large engines?
For emergencies I can probably overpower the 3.5 with the two 150s until I get out of harm's way (e.g., combat trolling, etc.)
On my Hewescraft, I also experimented with a tiller extension. The problem with it was that the angle of swing was limited by running into the big motor and/or the hull (the longer the extension, the greater the arc of movement required.) However, the KISS principle dictates that an extension may be the best solution. We will see.
Doryman
M/V Lori Ann
Anacortes, WA
PostPosted: Mon May 28, 2007 1:05 pm    Post subject: Reply with quote
Lori Ann wrote:
Joe,
Sorry, just didn't think to realize one link would be enough with the existing cross link between the two motors.
PostPosted: Mon May 28, 2007 1:13 pm    Post subject: Reply with quote
The link between the engines is the liquid tie bar--hydraulic. To me once you start putting mechanical tie bars in, it gets very complicated!
Doryman
Photos: Lori Ann
PostPosted: Mon May 28, 2007 7:49 pm    Post subject: Reply with quote
The 3.5 is so much smaller and lighter than the 150 I don't see how it could have much effect, especially at slow speeds. The mechanical tie bar is between the 3.5 and only one of the 150s. Thus the hydraulic tie between the 150s is not affected.
PostPosted: Mon May 28, 2007 9:59 pm    Post subject: Reply with quote
Agree that you would not involve the liquid tie bar in the link to the 3.5. The EZ steer I believe clamps around the lower legs of the outboards--and thus you have a relitatively complicated linkage--especially with the articulartion which allows the kicker to be raised.
I would envision a linkage on the front--just a plane turnbuckle and rod type of link. Just put a couple of pins and a bar--something like that.
I would try and keep it as simple as possiable.
Also with the two large motors, almost acting as flanking rudders, I suspect that the boat might steer fairly well, with the trolling motor just locked dead center. I would try this first and see. Just make the bracket out of plywood and a couple of bolts--give it a try and see how it works.
Doryman
Photos: Lori Ann
PostPosted: Tue May 29, 2007 2:47 am    Post subject: Reply with quote
That's a great idea. But you know what? Sometimes I am so brilliant I scare myself. Rolling Eyes The latest solution I have come up with is to idle one motor in reverse while running the other at a higher speed in forward. Now, admittedly this introduces problems of excessive fuel consumption and steering, but is that a kick-ass KISS solution or what? Laughing
Back to your idea. I could take it one step further and give one motor or the other some throttle. One way or another I think the 3.5 mounted as you say should do the trick.
drjohn71a
City/Region: Wichita
State or Province: KS
Vessel Name: Tom-a-Hawk
Photos: Tom-a-Hawk
PostPosted: Tue May 29, 2007 9:06 am    Post subject: Reply with quote
Warren,
The TC steers pretty good just by the engine legs, w/o engines "on".
Drift socks are great, just head upwind over potential fishing spots and drift back over them. Very stealthy approach. Good for walleyes.
I think some sort of "dam" or "drag" is far better than having to mess with a third motor.
Backtrolling will REALLY slow you down, and you could hang a rod out the helm window or thru the opening front window.
Doryman
Photos: Lori Ann
PostPosted: Tue May 29, 2007 12:25 pm    Post subject: Reply with quote
Fight a salmon out through a cabin window? Surely you jest!
PostPosted: Tue May 29, 2007 1:08 pm    Post subject: Reply with quote
Warren-
Do you have a windlass?
Get a strong 5 gallon or larger as necessary bucket and substitute it for the anchor. (may have to weigh the bottom a bit to get it to deploy.)
Drag it between the hulls like a drogue.
It can be retrieved in an emergency with the windlass to clear the water with a fish on or move the boat quickly.
Idea Question Question Question Worth a thought?
drjohn71a
Photos: Tom-a-Hawk
PostPosted: Tue May 29, 2007 3:46 pm    Post subject: Reply with quote
Warren... of course, the prey could preclude a window or bow rod position. you can backtroll with rods on the cockpit location also.
We have alot of under 10 pound species up here. John
PostPosted: Tue May 29, 2007 5:13 pm    Post subject: Reply with quote
As I was sitting on the CD 25 working and thinking (very dangerous)--I realized that even a push pull type of steering cable a couple of feet long would be adequate to "steer" the 3.5 hp--of course then you have to set up mounting brackets for the push/pull cable......so back to the simple linkage.
Doesn't everyone fish out the window? Flip those fish back in the cockpit when you hook up...
drjohn71a
Photos: Tom-a-Hawk
PostPosted: Tue May 29, 2007 5:39 pm    Post subject: Reply with quote
OK, you guys.... I have had to do alot of single handling over the years and backtrolling with rods either out the front deck window or the side windows were about the only way I could fish alone. If something big hit, I could step out to the front deck and fight it there. Otherwise a net thru the window worked fine.
You know, it takes a real man to be able to flip those fish back to the cockpit of a houseboat!
Doryman
Photos: Lori Ann
PostPosted: Tue May 29, 2007 11:18 pm    Post subject: Reply with quote
Definitely! Thanks for the thought.
I actually have a second "hatch" (stainless with small spring-loaded cover) next to the windlass. I was told this was the original access to the anchor locker before the windlass was installed. I might be able to utilize that somehow...
Doryman
Photos: Lori Ann
PostPosted: Tue May 29, 2007 11:21 pm    Post subject: Reply with quote
This is the main reason I got the aft steering station, since I often go out alone also. Or used to. Now that I live in Anacortes I may have more potential fishing buddies. But sometimes I just prefer to go by myself and do my old man and the sea bit.
Page 3 of 3
Page generation time: 0.0451s (PHP: 67% - SQL: 33%) - SQL queries: 28 - GZIP disabled - Debug on
