Trolling a Tom Cat at 1 mph
Wefings
Dealer
City/Region: Panhandle
Photos: Cruise Ship #4
PostPosted: Fri May 25, 2007 1:00 pm    Post subject: Reply with quote
A word of warning . Do NOT buy Lenco Trollin Tabs !!!! EVERY set we have ever dealt with failed early and often . FYI
Marc
Wefings Marine Website
Since 1909
PostPosted: Fri May 25, 2007 1:12 pm    Post subject: Reply with quote
Marc
And they're disproportionately expensive compared to other brands!
Doryman
Vessel Name: Lori Ann
Photos: Lori Ann
PostPosted: Fri May 25, 2007 2:11 pm    Post subject: Reply with quote
Sea Wolf wrote:
At very low speeds, the standard mechanics of pitch vs. speed through the water don't hold very well, at least with big outboards at low rpm.
There's so much slippage with an ordinary prop and a big heavy boat, that going down in pitch just makes it easier for the prop to waste less energy in slippage, and, since the same energy is being applied by the engine, the speed stays largely the same.
Thus at these speeds, cutting the prop pitch in half won't have much effect, and then you'll be grossly underpropped (and over-reving) at cruise speeds.
OK -- makes sense, good to know. Well, so much for that idea!
Thanks!
Doryman
M/V Lori Ann
Anacortes, WA
Doryman
Photos: Lori Ann
PostPosted: Fri May 25, 2007 11:10 pm    Post subject: Reply with quote
Sea Wolf wrote:
[The motor rests quite a bit higher than the cavitation plate on which it is mounted
Joe, is this a Minnkota freshwater engine-mount trolling motor? Looks like it comparing your photo with the Minnkota web site.
Very interesting alternative.
PostPosted: Sat May 26, 2007 4:20 am    Post subject: Reply with quote
Yes, it's a MinnKota 44 lb thrust Fresh water motor.
Many companies make them in salt water versions, too.
Some have a single "bullet", some a double, some a tripple.
One version comes in a 55 lb single, a 110 lb double, and a 165 lb triple.
The 44 lb thrust fills in the 0-2 mph range in no-current/light wind situations on my 22.
If I need more thrust, I start the Yamaha 90 EFI.
I went to four group 27 batteries for heavy duty use with it, and can charge them with a Honda EU 1000i generator, or the Yamaha 90. The generator charges through a 40 amp charger.
See the thread above on Engine Mounted Electric Trolling Motor.
PostPosted: Sat May 26, 2007 9:09 pm    Post subject: Reply with quote
I agree with Joe on the repitching--if you go way down in pitch, you can troll at a slow speed, but the boat may not be able to reach a speed where it will plane and you risk over reving (unless a rev limiter is present) the outboard.)
As for steering, I just use a piece of PVC pipe which slips over the handle for steering. I used this same 3.5 Tohatsu motor to push a 28 foot express cruiser over our sand bar for about 4 years--if it was really windy, it was a bit of a problem with control--but even the main engine was a potential problem with a high freeboard foreward.
I agree that there are better trim tabs than Lenco--but my express cruiser had them and we had no problems--but the boat was lift kept and run in fresh water the last few minutes of each run.
I think that the Torqueedo is an interesting engine--I use a 43 Lb thrust trolling motor regularly on our 12 foot Aluminum skiff--but I have two Golf cart batteries and charge them with a 110 v chager regularly. I don't think I would buy one for cruising applications currently, but at some point I think they will come into their own and do offer advanced technology.
Doryman
Photos: Lori Ann
PostPosted: Sun May 27, 2007 1:43 pm    Post subject: Reply with quote
Sea Wolf wrote:
[it's a MinnKota 44 lb thrust Fresh water motor.
According to the C-Dory website, your 22 on the trailer weighs about 3500#. My TC on the trailer weighs north of 9000#. I'm thinking that I should get 2 of the 80# thrust saltwater motors to get equivalent or slightly better performance to yours. What do you think?
PostPosted: Sun May 27, 2007 4:31 pm    Post subject: Reply with quote
The Tom Cat will also have more "water resistance" than the CD 22, because of the bridge deck draggin in the water. if the hulls were competely clear, I suspect that the weight would not make a lot of difference. (I have found pushing big boats, what water line, and hull shape means more than weight. For example pushing the 60,000 lb boat with about a 45 foot water line with 4.5 hp was about equivilant speed with a 40,000 lb boat with 40 foot LWL.
Don't forget that you will need 24 volts for the 80 lb thrust trolling motors.
There are ways of charging the batteries with 12 volts and a 110 V Charger, but not as convient as charging 12 volt batteries. (I have run both 24 volt windlass and 24 volt thrusters on 12 volt system boats, and had to deal with this problem).
Doryman
Photos: Lori Ann
PostPosted: Sun May 27, 2007 7:34 pm    Post subject: Reply with quote
So I would have to have a separate set of batteries for the trolling motors?
PostPosted: Sun May 27, 2007 8:46 pm    Post subject: Reply with quote
Warren-
160# should be adequate for the Tomcat 255, unless the drag from the tunnel is really significant. I'm not as familiar with the Tomcat, of course.
I'd discuss the plan with a technical representative from the electric motor manufacturer.
Also, I don't know if you were asking me or Bob, but if the 80# motors require 24 volts, you'll be best off with separate batteries for them. Getting 24 volts out of your existing batteries would require some pretty fancy diode hookups and present similar charging problems. Since you need the extra amperage anyway for the trolling motors, a additional set of batteries would be in order.
This is getting beyond what I am familiar with, and I'd suggest you talk to the technical rep about how this problem of creating and (mostly) charging the 24 volt system is best done.
PostPosted: Sun May 27, 2007 9:26 pm    Post subject: Reply with quote
Yes, I would recommend separate batteries for the 24 volt trolling motors. Even if you put in the 40 lb thrus trolling motors, I probably would put in separate batteries. The trolling motors can use quite a bit of power at higher thrust levels, where I think you will be. I have a 28 lb thrust motor which I might have a chance to try on my tom cat and see what it does--I pulled some debris with the 43 lb thrust motor after the hurricane. But after a few experiences which took a long time, I started using the 3.5 hp Nissan for any major "logging" operations.
Charging the 24 volt system can be done several ways. I charged each 12 volt battery by taking them out of series and putting them in parallel with a simple switch. when charging, back in series when running the windlass or thruster. There is a relitatively simple device for about $90 which will do this for you automatically available currently:
http://www.defender.com/product.jsp?path=-1|328|51495|606044&id=672772
Doryman
Photos: Lori Ann
PostPosted: Sun May 27, 2007 10:58 pm    Post subject: Reply with quote
This is getting way too complicated, not to mention the challenges of finding space for the batteries, and setting up the charging system.
I think I am first going to try the various methods suggested for slowing down the boat (drift socks, buckets, etc.)
Thanks, everyone.
Byrdman
Photos: FreeByrd and C-Byrd
PostPosted: Mon May 28, 2007 6:53 am    Post subject: Reply with quote
Lori Ann: You may consider tossing the sock/buckets over the front of the boat using the center forward cleat, and letting the sock troll under/between the sponsons ...maybe? That would keep the sock out of the fishing lines, but, for sure you would want a good tie up front to keep it forward of the motors.. You have the sock. You have the rope....but, bad news if the sock gets free and into the single prop that is running. Looking at all of this... a real small "portable" kicker might be the rig with a piece of PVC pipe for speed adjustments and not have to get out of your chair in the cockpit.
Byrdman
Patrick Byrd "Byrdman"
Miss B - CD22A, Aug 2018
Aloysius, Hull # 440 RF-246
TC24, Hull #51, Sold Feb06
CD16A, Sold Dec03
Doryman
Photos: Lori Ann
PostPosted: Mon May 28, 2007 11:15 am    Post subject: Reply with quote
Well, since I am going to buy a Tohatsu 3.5hp for the dinghy anyway, I think it behooves me to see how I can make it work with what I have. Thataway Bob attached his to his swim step bracket, so what I am thinking about now is investigating whether I could do the same and tie the motor in with the big motors using an EZ Steer linkage. I had one on my Hewescraft (130 & 9.9 Hondas) and it worked well.
Thanks for the center cleat idea. I'll have to see if the tunnel collapses the sock or not.
PostPosted: Mon May 28, 2007 11:46 am    Post subject: Reply with quote
Warren-
The small Tohatsu seems like a great idea, considering the complexity of some of the alternatives. The KISS Principle wins again!
I've never seen an arrangement with a small motor between two large ones linked with an E-Z Steer system, but one could be devised with stainless cables linking two E-Z Steer motor brackets on the large engines with one on the the back of the Tohatsu. The one on the small motor would have to be extended out so that the radius of it's swing was similar to that of the big motors.
Do you have a second steering station in the cockpit?
You won't have throttle, shift (none on motor, probably), or shut off control over the motor from the helm anyway, so maybe Bob's $2.00 piece of PVC pipe is starting took better and better!
Page 2 of 3
Page generation time: 0.0582s (PHP: 70% - SQL: 30%) - SQL queries: 28 - GZIP disabled - Debug on
