Trolling a Tom Cat at 1 mph
Goto page 1, 2, 3  Next
Doryman
Vessel Name: Lori Ann
Photos: Lori Ann
PostPosted: Thu May 24, 2007 12:31 pm    Post subject: Trolling a Tom Cat at 1 mph Reply with quote
The slowest speed my Tom Cat will run, with one of the 150 Yamahas running at idle, is about 2.6 mph. I want to have the ability to slow the boat down to about 1 mph for certain salmon trolling situations. So far I have identified four solutions, none completely satisfactory.
1. Install a 8 hp Yamaha high torque motor with power tilt and remote controls. This is the most serious solution, but it would make it difficult, if not impossible, to continue to use the boarding ladder (which I use often on land.) Plus, there is the problem of getting the expense ($3500+) past the Minister of Finance. On the other hand, to paraphrase a great American, "Extremisim in the pursuit of fish is no vice."
2. HappiTroll(s). (Need 2 to equalize running times for both engines.) I have Permatrims installed and doubt if the HappiTroll would fit. Plus, I suspect it would negatively affect the water flow around the engines.
3. Drift sock. I have one and need to try it out. Am worried about fouling the fishing lines and/or props.
4. (This is my latest idea). Re-prop the engines for fishing. That is, install high-torque props that would not provide as much top-end speed but would slow the boat down at idle. I've not changed a prop before (never needed to, knock on wood) but it doesn't look too hard to do.
Any ideas about these approaches, or ideas for other solutions?
Thanks!
Doryman
M/V Lori Ann
Anacortes, WA
drjohn71a
City/Region: Wichita
State or Province: KS
Vessel Name: Tom-a-Hawk
Photos: Tom-a-Hawk
PostPosted: Thu May 24, 2007 1:47 pm    Post subject: Reply with quote
Hi Warren...
These may not be the best answers, but here is what I've been doing:
Using one engine and tilt it up a bit
Backtroll, by simply going backwards using one or both engines.
or,most frequently, trolling in very large "S" patterns which allow the bait/lure to drop except when crossing over.
We have used drift socks on other boats for Walleye fishing and they work well. You have to locate and adjust them for a sideways drift.
Goodluck,
PostPosted: Thu May 24, 2007 5:29 pm    Post subject: Reply with quote
Warren-
Here's what I do on a CD-22 to troll real slow. Requires some battery power and rechargine expansion, though.
Engine Mounted Electric Trolling Motor
PostPosted: Thu May 24, 2007 6:31 pm    Post subject: Reply with quote
The engine mounted trolling motors certainly make a lot of sense--there are also trim tab mounted trolling motors. (either could be mounted on the top of the Permatrims.
We have the 3.5 hp dinghy motor and the bracket which holds it on the railing, modified to fit in the dive ladder bracket. Max speed with this is about 3 mph and it will easily drop to half a knot. For us that is the best slow solution--it is a motor we have already and the bracket we made takes a 2 minute modification to use as a trolling motor bracket. I don't think I would use more than a 3 to 4 hp motor this way, however.
See photo # 75 thru #77 to see the bracket.
C-Hawk
Vessel Name: C-Hawk
Photos: C-Hawk
PostPosted: Thu May 24, 2007 6:34 pm    Post subject: Reply with quote
2008- CD22- "C-Hawk" Sold
KJ6VVB
A Brat I am, At sea I be
PostPosted: Thu May 24, 2007 6:43 pm    Post subject: Reply with quote
What does it do to those little motors (any of 'em) when you run WOT on the main? Would think it'd do some damage to them in the long run.. Cry
PostPosted: Thu May 24, 2007 7:35 pm    Post subject: Reply with quote
Charlie, all of these trim tab motors and the motors which mount on the back of the cavitation plate will be out of the water when the main engines are running at a speed where the boat is on a plane. Thus no damage to the small trolling motors. When running at high displacement speeds, these motors are in an area of turbulance, so they don't spin real fast. I don't think it would damage them. They are designed for this use.
I use a trolling motor as the primary propulsion on a 12 foot skiff, and it turns pretty fast. I suspose that since these are PM motors that they would basically be a generator when free wheeling. The prop blades are nylon re-enforced or plastic and seem pretty tough. I towed in some kids last week who had one blade out of three left on their trolling motor--the boat was still moving--and after I charged up their battery one of the kids left for home with the single blade--I was amazed that the parent didn't at least buy them a new prop. I would have purchased one for them, if I had thought that they were going to try and run home (at least 3 miles) with only one blade working! So these motors's bearings seem pretty tough!.
PostPosted: Thu May 24, 2007 8:24 pm    Post subject: Reply with quote
Bob, don't understand how the motors that are connected to the cav plates on the main engines will be out of the water at high speeds. Are they out of the water? I can understand that the ones above the trim tabs might be.
squidslayer
City/Region: El Sobrante
Vessel Name: ShirleyMae
Photos: Shirley Mae
PostPosted: Thu May 24, 2007 8:34 pm    Post subject: Slow troll low tech fix Reply with quote
On my TC I use one engine........hook two 5 gallon buckets with a few holes in the bottom with rope one on each side...low tech but adjustable..one or two.. no cost...
Dick
Orinda.Ca
PostPosted: Thu May 24, 2007 9:43 pm    Post subject: Reply with quote
Charlie- The motor rests quite a bit higher than the cavitation plate on which it is mounted:
Doryman
Photos: Lori Ann
PostPosted: Fri May 25, 2007 4:57 am    Post subject: Re: Slow troll low tech fix Reply with quote
Dick, do you mean one on each side of the boat or one on each side of the engine being used? Also, how do you keep the ropes from fouling the prop?
Doryman
Photos: Lori Ann
PostPosted: Fri May 25, 2007 5:01 am    Post subject: Reply with quote
As it happens, based on a conversation with Les about a motor for my dinghy, I have decided against going with the Torqueedo and with a 3.5hp Tohatsu instead.
How do you steer your 3.5? Is there a mechanism to lock it in a given direction (i.e., straight ahead, etc.)?
Doryman
Photos: Lori Ann
PostPosted: Fri May 25, 2007 5:04 am    Post subject: Reply with quote
Thanks to all for the very helpful suggestions.
I find it interesting that no one has endorsed nor argued against my idea for re-propping the engines. To me, it makes a lot of sense but I am not sure how to implement it, or whether it can be implemented at all.
Dora~Jean
City/Region: Simi Valley
Vessel Name: Dora~Jean
Photos: Dora~Jean
PostPosted: Fri May 25, 2007 10:52 am    Post subject: Reply with quote
You could always go to like a Pro Pulse prop that's adjustable, WM has them. I carry one as a spare, haven't used it yet for performance comparisons, but others have I believe.
Steve & Carmen
MacGregor 26X 1988-1996
Glaspar Seafair Sedan 18 (2)
StarCraft 19 & 22
Catalina 17 & 22
Crestliner 19
PostPosted: Fri May 25, 2007 12:07 pm    Post subject: Reply with quote
Warren-
To the best of my understanding the following is true:
At very low speeds, the standard mechanics of pitch vs. speed through the water don't hold very well, at least with big outboards at low rpm.
There's so much slippage with an ordinary prop and a big heavy boat, that going down in pitch just makes it easier for the prop to waste less energy in slippage, and, since the same energy is being applied by the engine, the speed stays largely the same.
Thus at these speeds, cutting the prop pitch in half won't have much effect, and then you'll be grossly underpropped (and over-reving) at cruise speeds.
Maybe "Professor Prop Poop" (DogonDan) can add to this or correct me if I'm wrong!
Joe.Teeth
Page 1 of 3
Page generation time: 0.0361s (PHP: 79% - SQL: 21%) - SQL queries: 28 - GZIP disabled - Debug on
