maryswensen
Joined: 03 May 2007 Posts: 26 City/Region: Greenport, LI
State or Province: NY
Vessel Name: Mary C.
Posted: Sun May 06, 2007 7:22 pm Post subject: Radar wedge - a further explanation |
Having not received a reply to my original request regarding the radar wedge, I am going to hopefully clarify my question. We have a new C Dory 22 and have read that the bow does rise quite a bit. We are adding a radar unit and wonder whether or not a wedge is required to compensate for the bow rise. The antenna will be a roof mount on a five inch stand.
All thought will be appreciated!
Best
Mary C. _________________ Mary C. |
Sneaks
Joined: 06 Jun 2004 Posts: 2020 City/Region: San Diego (Encinitas)
Vessel Name: C-Brat
Photos: Jenny B and C-Brat
Posted: Sun May 06, 2007 7:38 pm Post subject: |
Technically a wedge will improve forward looking radar on the C-22. Mine is 4 degrees and is built into my radar mount. Personally I don't think it makes much difference within a mile or two though, and that's my major concern. If memory serves me, the transmitted lobe on a typical 2k radome is 5 degrees in the vertical plane but it's a lobe, so you're gonna get most everything you need from the power contained in a fairly wide section contained in the lower half of the lobe. I've observed the small Coast Guard boats operating around here and tied up to my marina pier and none have a wedge. YMMV
Don _________________ Mary & Don Anderson
Brat #483
"C-Brat" 1993 C-16 angler/50 hp |
Not For Hire
Joined: 20 May 2004 Posts: 347 City/Region: Cadillac, MI
Vessel Name: Not For Hire
Photos: Not For Hire
Posted: Sun May 06, 2007 8:38 pm Post subject: |
This has been discussed quite a bit in the past. The experts are probably cruising at the moment. Check the discussion HERE and lots more HERE. Your tower may well have 3 to 5 degrees of dip built in, many do. Whether it does or doesn't, it will work fine.
Regards,
Mark _________________ Mark S
Cadillac, Michigan |
timflan
Photos: Two Lucky Fish
Posted: Sun May 06, 2007 9:38 pm Post subject: |
And just as a point of comparison, sailboats routinely mount the radome on a fixed mount, and then sail heeled over 10 to 15 degrees without any significant degradation in radar performance. _________________ Timothy R. R. Flanagan |
El and Bill
Joined: 08 Nov 2003 Posts: 3200 City/Region: Lakewood, CO
Vessel Name: Halcyon
Photos: Halcyon
Posted: Mon May 07, 2007 8:45 am Post subject: |
We also have about a five degree wedge with our radar, but as the others have said, for short range work it is probably unnecessary. Also, we have two uses for our radar -- night or fog, and then we are usually traveling slowly and the wedge is probably not needed since the boat is near level -- and the second use is in storm, and then we're slow by definition but pitching about like on a bucking horse, and that five degree wedge is up there on the cabin roof chuckling at us. _________________ El and Bill (former live-aboards)
http://cruisingamerica-halcyondays.com/ |
Dora~Jean
Joined: 09 Mar 2004 Posts: 1514 City/Region: Simi Valley
Vessel Name: Dora~Jean
Photos: Dora~Jean
Posted: Mon May 07, 2007 11:04 am Post subject: |
The 5 deg wedge, if nothing else, makes it look 'proper'! Didn't do a comparison with/without the tilt, but I can see those low bouy markers in the marina channels 50 ft in front of us while going out or coming back! Of course like El/Bill said, you're mostly level at slow speeds so the antenna's vertical beam should provide enough to see what's ahead. I'd just rather give the antenna all the chance it can get to see straight ahead without relying on beam width, etc. _________________ Steve & Carmen
MacGregor 26X 1988-1996
Glaspar Seafair Sedan 18 (2)
StarCraft 19 & 22
Catalina 17 & 22
Crestliner 19
+4 Previous, 1/2 sail, 1/2 power |
maryswensen
Posted: Thu May 10, 2007 7:45 pm Post subject: Radar Wedge |
Many thanks for your replies. I believe we will "split the difference" and add a few washers to the aft bolts.
Many thanks!
Mary C. |
Joined: 02 Nov 2003 Posts: 21358 City/Region: Pensacola
Posted: Thu May 10, 2007 10:08 pm Post subject: |
The vertical beam of a radar is between 25 and 30 degrees. I have never used a wedge in any of my boats, including the 3 C Dories I have owned. Some boats which run at a 10 degree angle, would definately benefit. But consider that in limited visability your speed will probably be slow (at least it should be)--and the boat will be running fairly level). _________________ Bob Austin
